if you could make two upgrades what would they be?
Bikes: 2020 Masi Giramondo 700c; 2013 Lynskey Peloton; 1992 Giant Rincon; 1989 Dawes needs parts; 1985 Trek 660; 1985 Fuji Club; 1984 Schwinn Voyager; 1984 Miyata 612; 1977 Raleigh Competition GS
Quoted: 1125 Post(s)
Liked 249 Times
I've mostly added to my bike - rack, lights, bell, bar ends. The only parts I have upgraded are the pedals and the tires. The hard soled cycling shoes ended the pain in my foot (I usually wear soft soled shoes - after a few months of cycling in those, the arch of my foot had started hurting). The tires (Panaracer Pasela) made a huge difference to how the bike feels - it really feels like a different, better bike. The Paselas (non-TG) were $20 apiece from Jenson USA, with free shipping since my friend and I clubbed our orders together.
I made an error in my recommendation due to confusion on my part on the remembering the specs for the Pasela T-Serve, this tire is NOT designed with a better flat protection belt than the Pasela TG thus I would not recommend the T-Serve tire for touring.
Again though if flats is a concern while touring I would install a Panaracer FlatAway flat liner at least in the rear tire because a flat there while touring is a big hassle due to the panniers, fenders, and mechanicals, and rear tires are more subject to flats than the front. Getting a flat on the front tire is a smaller issue and I wouldn't put a flat liner in the front unless you absolutely hate flats of any kind...though you should be prepared know how to deal with flats and have the means to fix them regardless.
Bikes: 1992 Trek 800 Antelope, 1971 Triumph
Here are my choices:
Brooks saddle and wheelset
Tires and bar end shifters
bar end shifters and front rack
cant you make it three upgrades please?
Señor Member
Quoted: 649 Post(s)
Liked 292 Times
At your weight, the ride would be more comfortable with tires wider than 28mm. Room for anything larger, which could be run at lower pressure for the same or even improved performance? Someone mentioned Panaracer Pasela - they come in 32 and 35 widths, with or without Tourguard puncture protection. Touring tires, not racing tires.
and are lightweight well made tires
for the price there is no better tire
the non folding not tourguard versions are twenty bucks
but have a lightweight casing and give an excellent ride
and could make a good low budget racing tire
the narrow high pressure versions are also available with tourgaurd
which make them an incredible training tire
Bikes: Fuji Espree, Sun EZ-1 Recumbent Bike
If I had the money or the skill, I'd add a nice dyno-hub and light to my Raleigh One Way, but I have neither...lol
Possibly tires and saddle
Depending on your bike, if your doing long distance get a comfy road bike. I tend to get tired with a hybrid, it is supposed to fare good at road cycling and off road but it does not do any of the two things good.
Bikes: Felt Fc, Litespeed Ghisallo, beach cruiser
My knees.
If that doesn't count as two, then add clothes/layers.
Anyway, to get back on topic: saddle, bar tape and tires. You DO have a helmet and a good pair of padded cycling gloves, right? Add to that a rear blinky light. And I never ride without either my reflective mesh safety vest or a neon lime t-shirt for visibility to bored or distracted drivers...
As for the tires - I can feel the difference between riding a tire at 85psi and one at 105psi. The rolling resistance is soooo much lower if you run tires inflated higher. That adds up on a long ride/tour! I still ride on 27x1-1/8 tires (that works out to a 28mm width). I'm faster and less fatigued with those than the larger 1-1/4" (32mm) tires. The downside of high-pressure tires is that you feel every bump and pavement irregularity. Which is why new cork bar wrap and padded cycling gloves are important - as well as a comfy saddle!
I did... 1)Hub Dynamo LED Lights and 2)a Thudbuster seatpost ..
now both the 20 & 26" wheel bikes..
Quoted: 1572 Post(s)
Liked 643 Times
Tradeing stock?
I have not a Thudbuster but a Moxie that's similar in design. 25.0 diameter but I have a 31.6 mm custom shim for it. I'd be willing to let that go for other bike stuff that you think is equitable.
RG .. sorry , I got mine thru QBP They have weight range interchangeable elastomers ..
The past tense is Did , as in Done , rather than will as in future tense ..
BTW I have 2 shims from USE, both 25.0 ID 27.0 &27.2 OD
and a new PS shim QBP messed up on the order 30.9 > 31.6 ... sell them ..
also have elastomers for the ST for under my weight range (14st) + one thats stiffer ..
the prior one in the parts bin, now, was the Koga WTR OEM pick , a German Made Airwings tour ..
28.2,+ a shim to 31.4 ...
I got the Thudbuster ST, in 27.2 mm and shim sleeve for it to the frame's 31.4 ID..
Bikes: Specialized Roubaix Comp, Soma ES
Just start riding longer distances. You'll figure out real quick what you need to change. But it probably won't be anything not related to comfort. When you get over about 80 miles, you'll start noticing things that aren't working for you any longer. Maybe saddle, but only you can know that one. Maybe how the bike is fit to you. You'll need to tinker with the fit to get it right and nobody here could help you with that. Clipless pedals/shoes are nice, but not necessary. Now that I have them, it's weird to ride a bike without them. There are training rides for the STP, make sure you do them and you'll get everything sorted out over time.
Demented internet tail wagging imbicile.
Bikes: Masi, Giant TCR, Eisentraut (retired), Jamis Aurora Elite, Zullo, Cannondale, 84 & 93 Stumpjumpers, Waterford, Tern D8, Bianchi, Gunner Roadie, Serotta, Serotta Duette, was gifted a Diamond Back
Quoted: 305 Post(s)
Liked 2,038 Times
Last bike I got, the first thing that I did was get a large saddle or handlebar bag and switched the pedals to sod's.
I would also add bar ends for additional hand positions.
Quoted: 305 Post(s)
Liked 2,038 Times
but others that are interested may read these posts and find the answers interesting.
skycyclepilot
Fitting Your Bike
5
08-04-14 05:10 PM
Wikipedia
Road Cycling
26
07-14-10 05:48 PM
