can't Decide - Nelson LF vs. Camer LF
Bikes: 2017 Kona TI, 2016 Bike Friday Haul-A-Day, 2015 Bike Friday New World Tourist (for sale), 2011 Mezzo D9, 2004 Marin Mount Vision Pro - for now :)
Quoted: 103 Post(s)
Liked 5 Times
Carridice Nelson vs. Camper (not camer - I would like a saddle bag that can carry my gear for multiple day trips. I pack light and normally do not need much for cold weather. I will be carrying my overnight gear on my front rack (bridge hammock and poles, fly, air mattress) so no need for room in the seat bag for that stuff. My fleece will likely go under the longflap (somewhat bulky so it would take up too much room inside).
What I expect to put in the saddlebag:
1 windbreaker
1 pair socks
1 pair riding shorts
1 pair undies
2 lightweight jerseys
1 wool long sleeve shirt
1 lightweight long pants
1 small Jetboil stove
2-3 freeze dried meals
1 small ditty kit
1 compact down sleeping bag
For those of you that have one, or have experience with them would you recommend the Nelson Longflap, or the Camper LF? Nelson is 18 liters and Camper is 24 (without flap extended). The overall size is quite similiar with the Nelson at 35cm wide, 21 cm deep, and 20 cm tall - the Camper is 35x24x23.
Probbaly not a ton of difference, but....
1 windbreaker
1 pair socks
1 pair undies
1 small ditty kit
I own a Nelson Longflap. It held all of the tools, clothes, and toiletries from this list with all of the straps at their tightest setting and still had room to spare. Whether it would work for you probably depends on how bulky your sleeping bag is and whether you end up adding anything that isn't already on your list (Cook kit? Off-bike shoes? Tools & spares?).
I like the Super C better for it's side release buckles instead of the straps, and buckles.
theres D rings on top to stow your rain gear when you don't wear it.
Quoted: 103 Post(s)
Liked 5 Times
I would guess that a light bungee or piece of line would hold my fleece as well as a "long flap," as the Super C does not have. I like the Super C, but for the lack of flap - but never thought of it so simple as lashing on top. Hmmmm.
Quoted: 103 Post(s)
Liked 5 Times
Quoted: 103 Post(s)
Liked 5 Times
Well thank you sstorkel for the link and to fietsbob for the advice. I looked at that link, many pictures of loaded bikes, and went through a number of other things in me head to help. In the end, I looked over at the beautiful Velo Orange Camper standing next to me (kickstand that is) and decided that I didn't have enough room between the back of the seat and top of the fender to go with the larger Camper (24 liters and almost even measurement on height and depth) or Super C (23 liters, but even taller than the camper 28cm vs. 24cm). It's a 57cm frame, but I have the seat only about 7 inches above the top tube. Most bikes I see have more seat tube sticking out. I'm old school and prefer larger frame with less seat extension. There might be about 12 inches from the back of the seat to the top of the fender. With the support of the Bagman Expedition QR I should be just at or above the rear fender with the bag.
Also, I am a minimalist and this Nelson will probably provide plenty of room. If it does not I will be even more of a minimalist
I use the Camper Longflap, and find it just right for carrying, tent, bag, mat, cook set and clothes in the main compartment. If you are worried about space between the bag and the rear wheel look at the Bagman support. I have to use that support if I put the Camper on my Ramouillet, but I don't need it when I use the Cervelo RS. One advantage of using a relaxed geometry modern bike over a classic sport tourer geometry is you end up with lots of room between the saddle and the rear wheel.
Definitely get a bag with a longflap and it give you options to carry stuff like bulky food. You can also strap stuff to the top of the bag using the metal rings on the top.
Quoted: 103 Post(s)
Liked 5 Times
Looks like this must be a known issue, because I see that the Bagman 2 has additional supports running from the rack to the seat stays.
I owned both a Camper and a Super C at the same time, and sold off the Camper. I didn't find the Camper significantly bigger in actual use (I think the actual LxWxH dimensions are very similar, I don't really trust their capacity ratings), and I really hated dealing with the buckle straps on it. I much prefer the quick click buckles on the Super C.
Bikes: Old steel GT's, for touring and commuting
Quoted: 39 Post(s)
Carradice also makes a cape roll which attaches to the top of the bag. I have one mounted on my large saddlebag (Zimbale 18L) and use it occasionally to hold my sweater.
Quoted: 103 Post(s)
Liked 5 Times
I went with the Nelson LF and if it proves too fussy to use the buckles - and - if there is room for the taller Super C I will return and reorder.
Thanks.
Thanks.
ThePritchett
Singlespeed & Fixed Gear
36
11-08-10 08:31 PM
