Does Frame Saver Stop Existing Rust?
Extraordinary Magnitude
Quoted: 2608 Post(s)
Liked 1,699 Times
I've read in various places on the internet that JP Weigle's Frame Saver will stop existing rust.
This is something I'd like to believe, however, it doesn't really make sense and my common sense tells me it's not true. I don't see a JP Weigle web page- so I don't see anything official from the company- just people talking.
I recently bought a bike that looks quite pretty on the outside, but has some rust issues in the seat tube- I assume it's in the other tubes as well.
So is this truth or fiction?
Commence to jigglin’ huh?!?!
Friendship is Magic
Bikes: old ones
Quoted: 26413 Post(s)
Liked 10,378 Times
....ahem. Since rust on steel is an oxidative process, almost anything that
excludes oxygen from the surface will slow rust down quite a bit.
I'm not certain you can altogether stop rust on anything, once it has begun.
A lot depends on the conditions to which your newly treated surface will be exposed.
Here in Sacratomato, it's pretty dry a lot of the year, so rust is less of an issue for me.
Thanks for this opportunity to once again hold forth in the most supercilious of manners.
Quoted: 965 Post(s)
Liked 1,629 Times
There was a Huffy bicycle at the end of a bicycle parking stand out side of the medical school at UTMB Galveston (its right on Galveston Bay) - Only major components of the frame and crank were left - The aluminium wheels and chain powdered remnants on the side walk - No one dared to move it and we often stared at it as a fine piece of art - In 1990 it had been there only 4 years and by 1998 it was completely dissolved and only a rust stain on the side walk - As we transitioned in and out of the school we became like it a myth - Lesson being - That's what happens to metal when bathed in sea mist twice a day...
I also remember the remnants of what appeared to be a 1950's schwinn bicycle chained to a Barbed wire fence in an empty field outside of the old ER in Ft Stockten Tx - The staff said it has been there before the hospital or even the highway had been built (40 yrs?) - That's what happens to metal in South West Texas...
Why am I even writing about this...
I guess a small bit of rust is not a big thing in Ft Stockten Tx but I think I would really chase down clean and seal off as much rust as I could in Galveston...
Quoted: 5779 Post(s)
Liked 2,576 Times
But, new or old, polished, or rough, unrusted, or some rust, block the oxygen and the process stops.
So Framesaver will stop rust, but because the surface is rough, you have to be sure that the coverage is 100%.
FB
Chain-L site
FB
Chain-L site
Quoted: 9 Post(s)
The old adage amongst custom car builders, restorers, and bodymen is... "rust never sleeps." You can slow the process, but somewhere along the line oxygen will find the way- not matter what. In your case, it's only a bicycle. Do the best you can, and when rust takes over, retire it.
Quoted: 637 Post(s)
Liked 1,281 Times
Never used the product in question but there are several rust inhibitors in the automotive market that work exceptionally well and if applied properly would probably add a few decades to the life of a "mildly" rusty frame. POR-15 is one of the best, it won't hold up to UV so if exposed to UV it must be painted over but inside a bike frame it would be fine. I live in the Rust Belt and it works very well here but, as stated above, "Rust never sleeps". Just a guess but Frame Saver is probably very similar, what do you have to lose?
Bikes: 2011 Lynskey Sportive, 1988 Cannondale SM400
Quoted: 20 Post(s)
POR-15 changes the chemical composition of the rust. FrameSaver is really just a sticky oil that clings to the metal and keeps the oxygen out.
Quoted: 1438 Post(s)
Liked 1,092 Times
HinderRust seems to get some good reviews; I haven't used it myself but it was developed by the inventor of Tufoil, which I swear by. https://www.hinderrust.com/
As noted above, rust is an oxidative process. It is not a living thing like cancer which will no longer grow if completely removed, it will grow on its own given the right conditions. Keep the oxygen away and it will not grow. Existing rust does not spawn rust, oxygen and iron does. Water and salts will hasten the process.
rust = oxidation, block access to oxygen and rust ceases .
the plan , like paint .. is to cover the surface
and have a barrier to the gas in the atmosphere.
Quoted: 6556 Post(s)
Liked 58 Times
Quoted: 83 Post(s)
When you use a coating like frame saver, some amount of oxygen remains trapped in the coated rust (rust is like an oxygen sponge). That trapped oxygen will continue to oxidize the underlying steel until the oxygen is used up. At that point the rusting would theoretically stop. However, the problem with iron oxide (rust) is that it has lousy structural properties. In other words, it crumbles and/or flakes off (from shock, vibration, temperature changes, etc.). When it does, it takes the coating with it allowing oxygen to once again seep through the remaining rust and further attack the underlying steel.
If you can reduce the thickness of the rust coating (wire brushing, sanding, media blasting, chemical dipping, etc.) and then apply a rust inhibitor, it will work pretty well. Unfortunately, none of those processes (except dipping which is messy/dangerous/expensive) are really feasible inside a bike frame. Using the coatings on an already rusted frame may slow the oxidation process down some, and with repeated applications at regular intervals could even (theoretically) extend the life of the frame. But they'll never stop the rust completely. Given the amount of work involved, you're probably better off to just ride it as is and put your time/effort/money into finding a replacement.
On a new steel frame, it's a bit of a different story. Since the rust is still very thin, the inhibitor is far more effective.
I used por 15 on my 67 galaxie's rusty frame and it worked really well on that. It is very thick so you would have to thin it out a lot to use it on the inside of a bike frame. Also WEAR GLOVES while working with por 15. If you get any on you you will be wearing it for a long time.
Bikes: 2003 Lemond Zurich; 1987 Schwinn Tempo; 1968 PX10; 1978 PX10LE, Peugeot Course; A-D Vent Noir
If you really want to stop rust, you need to remove the rust from the frame and then coat it with some sort of rust ******ant. Frame Saver is meant to be applied to the inside of your frame tubes. It displaces moisture and probably slows down rust formation. Probably works fine if there is no rust inside to begin with, but if there is some you will only slow down the progression of rust. If you could clear the inside of the frame of rust (say by brushing it out), it would work really well.
Quoted: 2026 Post(s)
Liked 1,096 Times
Frame Saver, and it's alter ego Amsoil HDMP, do contain rust inhibitors so they are more than a "sticky oil" (actually a wax) that coats the frame tubes. I wouldn't rely on it to salvage a badly rusted frame but it is great on a new frame and will greatly extend the life of one that has some rust already in place. They are more effective than boiled linseed oil or similar coatings that are nothing more than a barrier film.
I've used Permatex Rust Treatment on cars with pretty good success. This stuff is available in small bottles, enough to do a bike frame, at almost all the big chain auto parts stores. It's not very expensive either, I think I paid less than $10 https://www.permatex.com/products-2/p...eatment-detail
Liked 1,699 Times
This isn't a badly rusted frame- I see NO indications of rust anywhere on the exterior of the bike. It is, however a 30 year old (pretty much unused) frame, and any rust would probably be from condensation moisture.
I know steel rusts- it's a part of what steel is- but I don't know how much is normal for an uncoated 30 year old frame interior. This is a really nice bike and a really nice, quality frame- so I think it is worth any effort into it. Most of what scares me is the corrosion on the seatpost- Although it wasn't stuck- I don't think it was greased very well when it was put in... 30 years ago.
Thanks again everyone.
Friendship is Magic
Bikes: old ones
Liked 10,378 Times
...on very nice bikes, such as the one you describe, it is not unusual to see more corrosion
along the seat tube/seat post interface due to the combination of regular atmospheric effects
and the galvanic difference between the (usually) aluminum alloy seat post and the (usually)
steel seat tubing of the frame. I encounter this all the time here in NorCal.
So I routinely treat the interiors of all the tubes I can get into with this stuff I get at Home Depot:
I've read the material safety data sheet for this, and also for the Amsoil product,
and they seem similar enough to me that I'm comfortable recommending and using it.
It has to dry for a couple of days after application, and you really ought to strip the
bike of all components in order to apply it easily and thoroughly.
I am also a believer in the use of anti-seize grease on dissimilar metal surface contacts,
which includes seat posts and small machine screws that go into alloy parts. Not everyone
agrees, and I have learned not to argue the point here on teh Biekfrorums.
Liked 1,699 Times
Are there really people that argue against greasing seatposts and stems?
Liked 1,096 Times
No, what 3alarmer uses is anti-seize grease, (Never-Seez and Permatex are two common brands) which is not plain grease, but is formulated to prevent dissimilar metals from corroding together. Generally anti-seize is required in very hot and demanding service, like steel spark plug threads in an aluminum engine head, but is not essential for the low demands of bicycle fasteners. It certainly is a good and effective product to use but is overkill for most bike applications. It's only real downside is that it's very messy and will stain any clothing it touches so be sure to carefully wipe off any excess if you use it.
Liked 1,699 Times
The amount of corrosion on the seatpost of the Voyageur SP is pretty scary to me- I did some scrubbing with BarKeeper's Friend and a blue Scotch Brite- took most of it off- but the seatpost is pretty scarred.
seat posts , take them out and re apply the wipe of grease, occasionally ,
its the removal breaking any developing bonds, as much as the grease, that helps.
Quoted: 83 Post(s)
Anti-seize typically contains fine metal particles (copper or zinc) that serve as a sacrificial anode. This prevents galvanic welding of dissimilar metals (eg. Al and Steel). Heat + water vapor (like you get at the interface between a spark plug and cylinder head) is one example where this occurs. Liquid water + salt (from sweat) dripping down the seatpost is another. Anti-seize is definitely not overkill for bicycle applications. It's a little more expensive than plain grease, but a little goes a LONG way (I'm about half way through the tube of Permatex anti-seize I bought in the late '90s) and it can significantly extend the maintenance interval where it is used.
Wolf Dust
Classic & Vintage
37
04-28-15 04:31 PM
