Tire pressure questions
Abuse Magnet
Bikes: '91 Mtn Tek Vertical, '74 Raleigh Sports, '72 Raleigh Twenty, '84 Univega Gran Turismo, '09 Surly Karate Monkey, '92 Burley Rock-n-Roll, '86 Miyata 310, '76 Raleigh Shopper
Quoted: 151 Post(s)
Liked 174 Times
What determines the best tire pressure to have? Is there a good rule of thumb, or is it kind of subjective?
I ask because I'm pretty heavy, and I'm inclined to inflate to the tires' max pressure. Is this good or bad?
Bikes: 1983 Trek 620, 2010 Roubaix
Google "tire drop" if you want. Experiment yourself if you don't like those recommendations.
as long as you don't get pinch flats, you have enough air.
Tire er size is at least as important as tire inflation, especially for heavier folks like you and me. The tire drop article shows that graphically.
My $0.02.
My $0.02.
Quoted: 5779 Post(s)
Liked 2,576 Times
IMO, pressure is the secondary consideration. Start by selecting an appropriate tire width, subject to your frame's tire clearance, then determine the best pressure.
If you look at the car and truck world, heavier vehicles use wider tires with almost no exception. If you go to the tire drop article, look for tires wide enough that optimum pressure is under 100psi, and consider these the narrow limit.
FB
Chain-L site
FB
Chain-L site
Quoted: 1438 Post(s)
Liked 1,092 Times
Here are a few links to get you started. IMO many folks use tires which are too small and overinflated in a misguided attempt to get "more speed"; the resulting harsh ride may not improve speed at all and can be fatiguing as well as unpleasant.
https://www.dorkypantsr.us/bike-tire-...alculator.html
https://www.bccclub.org/documents/Tireinflation.pdf
https://www.bikequarterly.com/images/TireDrop.pdf
Abuse Magnet
Quoted: 151 Post(s)
Liked 174 Times
Those were some good articles. I honestly hadn't taken those sorts of things into consideration. Thank you.
rpenmanparker
Road Cycling
96
03-23-20 12:29 PM
