Help with Triban 5 Btwin
Hi, bought a new Triban5 and went out on it this morning. When I'm in the top 2 gears of the mid range gears, I can hear the chain hitting something but can't see what, feels like the gears aren't aligned properly. Is this something I can fix easily or should I take it back to the shop? Any help very gratefully received.
Thanks,
Carl
Thanks,
Carl
Quoted: 1572 Post(s)
Liked 643 Times
It's a new bike. It should work. That's what you paid your money for.
If it's displeasing you in a way that you can't figure out on your own, take it back to the guy who sold it to you.
Quoted: 2026 Post(s)
Liked 1,096 Times
What you may be hearing is the chain dragging on the inside of the large chainring. The dealer may be able to adjust your bike so this doesn't happen but it's is often a permanent problem depending on the drivetrain and frame dimensions. As a general rule, you should not be in those gears anyway. It's called "cross chaining" and the angle is hard on the chain. You can get the same gear ratio in the large chainring and larger cogs.
Bikes: Raleigh Companion, Nashbar Touring, Novara DiVano, Trek FX 7.1, Giant Upland
Quoted: 22 Post(s)
It's probably hitting the outer plate of the derailleur cage. you need to trim your FD by upshifting but not enough to shift the the big chainring. This document is for Tiagra 9-speed but AFAIK Sora 9-speed works the same way. https://techdocs.shimano.com/media/te...9830670793.pdf.
Liked 1,096 Times
InsaneScout
Bicycle Mechanics
26
01-05-14 05:47 PM
