Tire Liners
Bikes: Salsa Ti Warbird- 2014/ November RAIL52s
Quoted: 67 Post(s)
I'm not surprised that Orange Seal outperformed all the others by a wide margin.
Nevertheless, running tubeless sealant in a tube is an absolutely ridiculous notion. lmfao
I am definitely NOT in the camp that loves tire liners. I tried some, they worked great for a couple hundred miles before they cut a hole in the tube. I installed them properly, even covered the ends with tape.
Bikes: Old steel GT's, for touring and commuting
Quoted: 39 Post(s)
Sometimes there are situations where tire liners are the only solution in beefing up a flat prone tire.
I've recently changed to Maxxis Detonator tires which are a perfect fit for my type of riding and commute, but are notorious for flats because of the very soft compound. Since I'm overweight, I have to run these tires at maximum pressure (100 psi) which means that any type of slime solution is out of the question, so I'm looking at installing tire liners.
Would this type of setup work, or would I end up having more flat's because of the edges of the liners?
I weigh more than that now, but have moved on to expensive tires with the flat protection built in (Panaracer T-Serv Pro-Tex's and Vittoria Randoneur Pros), but am tempted to remount the Mr. Tuffy's to get the rest of the life out of a couple of tires that started to get flats because they got sore tore up from all the tiny sharp rocks and shards of glass.
I don't know how much they cost in Greece, but I seem to recall Mr. Tuffy's going for less 10 dollars for a set. IMO worth a try with your tires.
Bikes: Schwinn Continental, Schwinn Paramount, Schwinn High Plains, Schwinn World Sport, Trek 420, Trek 930,Trek 660, Novara X-R, Giant Iguana. Fuji Sagres mixte.
Quoted: 35 Post(s)
Liked 22 Times
Try switching to Panaracer T-servs or Pasela PTs (new name for Pasela Tourguards).
Location: In The Middle Of "Out There" / Downtown "Lost Angels"
Bikes: 2001 Trek 520 - Hvy Hauler, Epic Adventure Bike / 2011 Fuji Newest 1.0 - Sporty Quick Bike
Quoted: 16 Post(s)
They work
But you do have to round the right angle edges(scissors)-and tape the edges and ends
I use duck tape
and you have to get the hang of reinstalling tubes-and pushing the liners to re-center them.
For those who say they don't work-gotta ask WHY?
If the answer is the sharp edge and ends- DUH- no kidding!!
Tape them-fabric rim tape-old fashion 1st aid tape-or duck tape or even package tape -gotta take the edge off them-and tape them
I use duck tape
Tire Liners: Personal experience, as well as many friends.
Sing Praises IF - Tires are FAT, Pressures are LOW (less than 50-60 psi), Tubes are THICK (aka heavy duty/thorn proof).
Scream CURSES IF - Tires are SKINNY, Pressures are HIGH (more than 80-90 psi), Tubes are THIN (aka road/light weight).
Tube sealants: Personal experience, as well as many friends.
Pretty much same as above.
New Orleans
Quoted: 157 Post(s)
I use 2.1 and 1.95 tires-generally running 60 psi-but between weekly pumpings drops to 40 psi-so 50 psi- DEAD ON.
Now I use normal tubes-occasionally ones that are "light"-meaning 150 grams or so 26"'-
But your explanation-sure fits my good experience with then-and yes I have had some suspicious flats that might have been from the sharp edged vinyl if it wasn't taped well
I have used a "puncture resistant" michelin or maybe schalbe(sic) didn't seem to work any better than normal tires-this was pre tire liner
Thanks
Charlie
