Windsor Oxford - bad threads on front wheel axel?
Bikes: 2015 Salsa Vaya 3, 2011 Windsor Oxford, 1974 Schwinn Continental
While riding on a trail last year my wife's bike lost one of the nuts securing the wheel to the fork in tall grass. We never recovered it (barely managed to ride it back, using the interior clip, keeping an eye on it and going slow). Now I got some replacement nuts from a shop (admittedly free used parts) and they get really, really tight on it after a few turns unlike the other nut, which is still original. Is it possible that the thread size is just a smidge off or did something get damaged and what can I do?
Brad
Quoted: 1438 Post(s)
Liked 1,092 Times
If the original nut threads on OK and the replacement does not then it is reasonable to conclude that the new one does not have the correct thread.
Properly-torqued fasteners rarely come loose so you should make sure that all of the fasteners on your wife's bikes are tightened sufficiently. Critical ones like the front wheel should be checked frequently, like before each ride. If I had nutted axles I would carry a suitable wrench on the bike.
The replacements both look a bit rusty, could be some damage there. They both start to thread pretty well though which makes me think pitch is the same... And they don't appear to be locking.
How would I go about finding the correct thread?
Yeah, I just forgot to check the nuts before the ride. I had just set her bike up, but I guess the drive to the trail really loosened things up.
thiocyclist, Take the good nut to a hardware store, find a bolt that it threads onto and then find a matching nut.
Brad
Brad
Super Moderator
Quoted: 1173 Post(s)
Liked 927 Times
You may need a washer as well.
in tall grass.
in tall grass.
the wheel should have been checked before the ride .
from Now on make sure things are Known to be tight enough..
before you or she ride the bike.. any brand bike.
Really Old Senior Member
You may have 9mm or 3/8 threads.
Best to stop by the LBS with your good nut.
Quoted: 6556 Post(s)
Liked 58 Times
First make sure you can move the remaining nut to the other side. If that nut works on either side, it shouldn't be hard to get a replacement for the missing one. LBS, LBS, LBS...
Insane Bicycle Mechanic
Quoted: 805 Post(s)
Liked 706 Times
He'll have a better chance at a bike shop. Front axle threads are either 9 x 1mm or 3/8" x 26tpi.
Jeff Wills
Jeff Wills
Not sure which kind of you are thinking, but I know I'm not missing anything besides the original nut. Still have the clip that goes over the fork and acts similar to a washer, with grooves in the circular portion. That's how we managed to ride back.
I appreciate a good scolding as much as anyone but as you may have guessed I've already realized this was a mistake on my part, now if you have any idea about finding a replacement nut that might help instead of being self-righteous...
After this incident I asked many friends if they'd ever thought to check the front axel/fork nuts and they all said no, and these are people who ride mountain trails each weekend (sometimes multiple times a week... they are typical CO people). So I guess you'd better hit the road and get to spreading your gospel.
I actually got the replacements as freebies from my LBS. Neither works but I did as you said and swapped the working nut to the other side to be sure it wasn't the axel threads. It's the replacement nuts. I may go back there with the one working nut (and pay them for something that works if they have it), hopefully that way we can match threads up as others have suggested.
Liked 58 Times
Take the wheel to the LBS and root around in their junk drawer until you find the right one.
After you tighten the axle nuts properly, paint a line across the axle and the nut. Now you can visually check the tightness. If the lines don't line up, something is wrong.
Il faut de l'audace, encore de l'audace, toujours de l'audace
1980 3Rensho-- 1975 Raleigh Sprite 3spd
1990s Raleigh M20 MTB--2007 Windsor Hour (track)
1988 Ducati 750 F1
1988 Ducati 750 F1
incazzare.
Try the good nut on the side where your nut is missing. Does it thread on? If so, the problem is the replacement nut, not the axle.
1964 JRJ (Bob Jackson), 1973 Wes Mason, 1974 Raleigh Gran Sport, 1986 Schwinn High Sierra, 2000ish Colian (Colin Laing), 2011 Dick Chafe, 2013 Velo Orange Pass Hunter
Bikes direct ?. It's their sales.. ask them .. others say you just ship the whole bike back.
I guess I could contact BD but I'm going to the LBS tomorrow anyway with the working nut, if I have time. Snowy here so I won't be riding (I've wiped out enough that I guess I figured out that I'm not *that* hardcore), but I can walk over there at lunchtime.
Mike J
Bikes: 1975 Peugeot PX-50L, 1971 Peugeot PX-10, 1974 Peugeot PX-8
Quoted: 392 Post(s)
Liked 6 Times
Good idea!
Update, I had to go to the LBS with the existing good nut and they had six kinds of threads that all looked exactly the same but had small differences for bike wheel axels. They IDed mine and ordered me a couple of new ones.
Quoted: 4234 Post(s)
Liked 2,949 Times
When I had a threaded axle like that, I always carried a "dog bone" tool with me. Doesn't do you any good for this problem now, but might be useful in the future. You can find them on ebay shipped to you for a couple bucks. Probably not the highest quality metal, but they worked well for me in emergencies a couple of times when something slipped mid ride.
Bikes: 1996 Eddy Merckx Titanium EX, 1989/90 Colnago Super(issimo?) Piu(?),1990 Concorde Aquila(hit by car while riding), others in build queue "when I get the time"
