Trek 520, Old vs New
Bikes: 2014 Trek 520, 1990 Trek 2300 Pro, 1999 Trek 2100, 1991 Trek 7900, '83 Trek 610 (on permanent loan)
Quoted: 12 Post(s)
Hey folks,
I'm planning on setting up a touring rig in the next few months. I'm a vintage Trek guy, and I've only ever owned Treks; naturally the 2014 520 got my attention (it is beautiful!).
I do, however, have the ability to build up a (presumably) 1989 properly sized 520 frame instead. Money, vintageness, aesthetics, etc. aside, which is a genuinely better frame? Any input on the subject is appreciated!
Brad
- More brazons on the new frame.
- A brand new Trek warranted frame going to be quality for sure.
- 25 years is a long time.
Bikes: Shogun 400 ('83), Kuwahara Newport
I vote for vintage. But the additions of brazeons on the '14 model is hard to ignore.
Also, older 520s don't have the 130/135mm OLD spacing of modern frames. A bike from before ~1992 with 7 speeds will probably have a 126mm OLD spacing. You have to either go with older (narrower) drivetrains, respace the dropouts, or put up with having to use a little force to change rear wheel. It's a good idea to have the derailleur hanger realigned if you're jamming a 130mm hub into a 126mm OLD frame, to avoid poor gear shifting.
Finally, on any used bike you're buying dozens of used parts that may or may not be safe to use - you don't know until you tear it down and inspect. Corrosion on a bike frame is sometimes hidden - you don't know the extent until the rust perforates a frame tube. Proper replacement of vintage bike parts is not quick or inexpensive. Often vintage parts cost more than an equivalent new component.
The new 520 would make life easier, and if you're spending that much, I suggest you consider a Surly LHT, as they're about 100 bucks cheaper and probably the better choice at even cost. You can also buy a LHT frameset for 400 and build your own bike from spare parts for less than the cost of a new bike.
Surly gives you a limited term frame warrantee to let material and workmanship flaws appear,
and be covered.
Trek has no time limit. 1st owners lifetime .
OK no Disc 520.. Yet.
and be covered.
KingoftheMountain wannabe
Bikes: V.O. Pass Hunter & Specialized Hardrock
You'll probably have the fewest problems with the new one. A completely brand new bike, and one that has 25 years of technology advancements and changes, has the inherent advantage.
That being said, if you have the ability to re-build the vintage one to your preferred specifications for the same price or cheaper, I'd take the old one. Something magical about the older bikes. You just have to remember that you might have more problems sourcing replacement items, have a frame with more scratches, and it will take more work to get up to speed.
Quoted: 12 Post(s)
Ok guys, thanks a lot-I was pretty set on the new one, but it wasn't made in America and there's no Reynold's sticker so I just wanted to make sure I wasn't going all in on a "cheap" frame.
I like the feel of the 520 better and it fits my expected touring type more than the LHT does. The disc LHT sure is tempting, but just not quite enough to get me away from trek (my mom worked there for a number of years and rode a 520 across the country in the 80's; then she raised me on Treks, and my utility/commuter bikes & road bike are treks as well).
I really appreciate the help, you've eased my thoughts a good bit
I know you said the LHT doesn't fit your intended riding style, but personally, if I were buying a new touring bike, LHT or something else, I would go with disk brakes. No question. I know the old styles of brakes have been around forever and they do stop a bike, but ride some disks if you haven't before and you'll see that they are a huge improvement. There is a reason lots of touring bikes are showing up with them now. I only own my current touring bike(91' Trek) because I got the frame for cheap and it was cheaper for me to build up than buy new, but I'd swap to a disk fork in a second if I knew of one with the unlikely combination of requirements it would need(1" with mid-fork braze-ons).
Goathead magnet
Quoted: 5 Post(s)
^ Haha. I was thinking that too, but to each their own. Nothing trumps brand recognition, and paired with nostalgia for OP. As long as he's happily out biking, that's the important part.
Quoted: 12 Post(s)
Oy. The newest trek I've ridden is 4 years older than I am; is trek no good these days? I don't really step out of the vintage realm ever.
Bikes: Old steel GT's, for touring and commuting
Quoted: 39 Post(s)
I own an 89 Trek 520. it is still used today for gen fitness riding and for short touring. The frame show no signs of giving it up. The bike is still equipped with it's original drivetrain -still going strong. Even i'm surprised, but if it ain't broke...
I also own a 2004 520. That too is a great bike and going strong. Realitive to the 2014 520 it has higher level components. For that reason I'm not a big fan of the new 520. If given the choice i'd build up the old frame with the level of components that will serve your needs, rather than the grab bag Trek has used to hold a price point. Not that there is anything wrong with a 2014, 520, only that for the $1300 or so one will set you back, that money will buy you a higher level bike on a build up.
If the frame is solid you have nothing to fear.
Differences would be that the 89 will have more flex than a new frame. That is not a deal killer. the 89 is not flexi! Just not as stiff as the newer frames.
The 89 took 27 inch wheels and tires. The brakes, I think are the same on both my 520s, gotta look again to be sure.
There are as many brazons on the 89 as on the 04.
There was book written about five years ago about a guy who dusted off his 25 year old touring bike for another big ride. The bike was an 1985 Trek 520. The bike went 2000 miles with little more than a tune up and new tires.
So, the bike is up to the challenge.
No, that's not why disks are showing up on touring bikes. And it's not about the stopping power(other than perhaps the marketing). I guess one benefit to stopping power is reduced hand fatigue if you're doing a lot of braking in the mountains or something, but that's probably not a real issue for most. As you said, a decent brake dialed in right will put you over the handlebars, basically no matter what kind(though disks do indeed have crazy stopping power). I don't think you really understand disk brakes. The modulation benefit of disks is huge. I never realized what a difference it made until I had disks, but it truly is a benefit to have. The ease of replacing a brake disk when it wears out versus a wheel rim is also a great benefit. The brake pads are also much easier to swap out on the cable varieties of disks vs. "standard" brakes. You don't even need tools. And granted prolonged braking in mountain type descents isn't an issue for everyone, but if you are doing a long descent like that, I'd much rather have disks. People don't often have issues with rims overheating and tires blowing or coming off of the rim, but it does happen. It won't happen with disks since you aren't heating up the rim. The last place I want my front tire to go on me is on a long descent with likely a steep drop on at least one side of the road, which is usually on the outside of the turn... I think there's Definitely a real benefit, as do other people who have used disks in day-to-day life and the people designing the bikes, including small, independent, well respected builders who aren't just after marketing hype. I'm not saying it doesn't happen, but I've never heard anyone say they don't see a benefit to disks after they've owned a bike with them. I've heard Many people who have tried disks speak positively of the benefits. And the weight penalty is so minimal it's hardly worth mentioning on a touring bike. Don't carry any extra tubes if you're worried about that little bit of weight. The only real downfall I can think of is possibly warping a disk in the middle of nowhere, but I don't think that outweighs the benefits. And you can get a warped disk straight enough to at least use it(assuming it wasn't really mangled by something) until you can get a new one. I'd Highly recommend trying them out.
Its only pain
Bikes: '18 Salsa Marrakesh, '14 Salsa Colossal, '89 GT Timberline
Quoted: 54 Post(s)
The reason disc brakes are showing up on touring bikes is people are convinced new is better and that they need more stopping power, i.e. the companies are looking to sell you an upgrade you don't need. Disc brakes are over rated, I've never wanted for stopping power with decent cantilevers that are dialed in right, and I'm a big Clyde who can't pack lightly to save his life. Even on an heavily loaded bike while touring, descending, I've got enough braking power. Disc brakes on tourers is adding a weight penalty for no real benefit.
Goathead magnet
Quoted: 5 Post(s)
No brand hate here. I have an '83 500 that I'm quite fond of. Vintage Trek's are great. New Trek's.....well, they're nice and all, but pretty bland in my opinion. But people say that about my Surly's as well, so get what you want. You do get a good bang for buck with the trek.
On the sub topic here of the advantages of disc brakes - having mountain bikes equipped with discs quickly shows many of the advantages mentioned. That said, not having disc brakes shouldn't be a deal killer.
Back on topic - as an owner of an 89 Trek 520, bought brand new, i can highly recommend the bike - complete bike or frame only.
Mad bike riding scientist
Quoted: 6212 Post(s)
Liked 4,211 Times
On the front, you have similar problems with threading a rack around the caliper and you've traded a strong symmetrical wheel for a dished wheel. A dished wheel in the rear causes enough problems, why would you want to put another one on the bike?
I'm of the opinion that many people who think hub mounted disc brakes are superior do so because they probably weren't riding brakes that were set up like a hub mounted disc to begin with. Many shops install rim brakes so that the lever has to travel about half way to the bars before the brakes even touch the rim. Full lock on the brakes is somewhere behind the handlebar so the brakes feel really mushy. Hub mounted discs, on the other hand, have to be adjusted so that there is little lever throw before the pad hits the rotor. If you detune hub mounted discs so that they are set up like most rim brakes, the disc sucks too.
Every brake I own (disc or rim) is set so that by half lever throw, the wheel is locked.. That's why I don't see any "improvement" when I use hub mounted disc. Essentially, my bikes are already dialed in like a disc brake.
Even if you had hub mounted discs, dragging the brakes all the way down a long descent would be a dumb way to use them. The rotors aren't indestructible.
Stuart Black
Stuart Black
Goathead magnet
Quoted: 5 Post(s)
My limited experience with disc and rim brakes. I have both right now, on both road and MTB's. With a good set of pads, either will work great. Where there is the biggest difference is in incliment weather and riding conditions. When things get sloppy, there is a definite advantage with the discs. Overall, I prefer rim brakes, due to the builder being able to make a more compliant fork, better pad life and most importantly () aesthetics.
By the way, I find truing a disc rotor way easier than a wheel. I don't use a tool. Just a slight tug does the trick for me.
Bikes: 2013 Custom SA5w / Rohloff Tourster
Quoted: 1236 Post(s)
Liked 318 Times
I would ride the old 520, no doubt. Might want new rims, IDK. I would get a Phil BB, for sure.
The new 520 is the most fugly tour bike out there.
I never rode much in pouring rain, but I would expect ALL non-hub brakes are going to squeal plenty and LOUD.
Quill stems and longer TTs are nice.
My 1990 Raleigh frame got sawed up last year, it had very minor rust except by cable openings.
My 2013 520 rides just beautifully, and the linear-pull brakes that come stock on it offer plenty of stopping power, even under load, when they're adjusted properly (which should go without saying). One advantage of the new 520 over a pre-owned bike would be that a new one would come with Trek Care, i.e. a lifetime frame warranty for the original owner, plus Trek's loyalty program which offers discounts for replacement/repair parts in the event that such are needed. The rack which comes on the new 520 is pretty nice, too. It's lightweight, but very sturdy. In any case, I hope you enjoy whichever bike you decide on!
Again, the advantages of disk has nothing to do with brake force. That said...
I honestly don't mean any disrespect here - I've read Many of your posts in the past and I know you have lots of knowledge, but on this subject I think you could continue to learn about the new aspect of it. If nothing else, disk brakes seriously do offer better modulation. The system lends itself to it from a mechanical aspect. Disk brakes just aren't as grabby, so you can adjust the braking force more subtly. As for your hydraulic being very on/off, I'd recommend somehow adjusting them or perhaps it's a poorly designed set. I'm not sure. They would be very powerful, so you can't go just grabbing and squeezing the lever like you have to on non-disk brakes, so keep that in mind, but they should offer a very wide range of braking force. Also, that you said all of your brakes are at wheel lock by the half travel point of the lever gives an indication of how you set your brakes up. You probably also have fairly strong hands and use more hand strength vs. mechanical leverage to stop when compared to others. Not that there's anything wrong with that, but it's opposite of the idea behind disk brakes. It's like driving a modern car vs. an old classic with no power brakes. If you grab a hand full of disk brake like you would regular brakes, you are going to go straight from no brakes to wheel lock. Just like if you're used to driving a car without power brakes and then hop in a 2014 Honda, you're going to lock the wheels and come to a screeching halt the first time you try to stop. If you look up Sheldon Brown's article on "the geometry of cantilever brakes" and scroll to the "feel vs. function" section, that will perhaps better explain what I'm saying in terms of why the way you use brakes is so different from the idea behind disk brakes and why you aren't seeing their modulation benefits.
