Mounting a Burley Piccolo to a Tubus Airy?
Me and my kid have been oogling tag-alongs for a while, but it just doesn't feel safe mounting one to my thin alu seatpost. So a Piccolo perhaps would be better and it also seems popular on the internets. It does however only fit Burley's own Moose Rack.
Being in love with my Tubus Air rack, I'd hate to have to switch it out for some weight-weenie heresy. Most of the time I use the bike just by myself anyways, mostly for fast paced commuting.
Do you think it would be difficult to mod the attachment device to fit? The Tubus is really narrow, only 66 mm wide @ the top.
More importantly, would you consider it safe to use a rack not designed for it? The Tubus is quite strong, designed to carry 30kg and never wobbly even with my panniers stuffed with groceries; but still?
Hasty pic of the bike (Backroad tourer frame):
The Recumbent Quant
If you're concerned, get a steel seatpost. But I think it's likely you'd be making the situation more dangerous, not less (and significantly so).
Solution : N+1
get a less racy bicycle and get the Piccolo rear rack for the bike.
you have more forces to deal with from that passenger on the back with a mind of their own..
and so just bite the bullet and work from the Piccolo rack mounting
requirements on selecting the family typical bike , that is less go fast . ..
rear rack can also haul grocerys to feed that little auxiliary power unit ..
don't try this at home.
Quoted: 973 Post(s)
Liked 511 Times
Your seatpost has to hold up a 300 pound rider without breaking. It's strong.
The rack is attached with small bolts like this:
Thanks to all above, I appreciate your input and have decided you most definitely are smarter than me. I'll get a secondary bike or a tag-along designed to fit the seatpost, even if it means I'll miss out on the praised Burley.
SGMongoose
Singlespeed & Fixed Gear
21
11-24-14 04:17 PM
