Trek 5.9 (2012) - Can it take mechanical shifters?
Quoted: 8 Post(s)
Hi All,
I have an opportunity to buy a 2012 5.9 frameset, but I know it was stock with DI2. Does anyone know if it's possible to install mechanical shifters running the cables through internal routing, or if it's only possible to use electronic shifting on this frame?
Thanks in advance!
Thanks in advance!
Quoted: 413 Post(s)
Liked 109 Times
Hi All,
Thanks in advance!
Thanks in advance!
Quoted: 8 Post(s)
Local Trek dealer said yes, the 2012 5-series frame is the same regardless of 5.x, but I will need the necessary cable routing tubes. Fortunately, after checking back with the frame seller, he has all the necessary hardware and is including those along with a few other things he's throwing in for free, so I bought it.
Bikes: Eddy Merckx San Remo 76, Eddy Merckx San Remo 76 - Black Silver and Red, Eddy Merckx Sallanches 64 (2); Eddy Merckx MXL;
Quoted: 143 Post(s)
Hi All,
Thanks in advance!
Thanks in advance!
I work at a Trek shop, and will confirm yes, no problem. Especially if the seller has the bag full of frame widgets to convert it to cables. If not, there's a kit you should be able to order, 1 p/n for everything you need to convert it.
Basically, take out the wiring grommets, remove the battery holder; insert cable stops and bb cable routing plate. One of the battery holder mount screws screw into a loose nut -- You will probably need to use a 10mm wrench to hold it, maybe just your fingertips, but make sure it comes out of the bike or suffer mystery rattle. You'll be happiest if you run your cables before you button up the bb, but it's actually not heinous, fishing cables with the bb plate out, even with the crank in place.
Are you getting bb bearings with the deal? If so, and they are used at all, I'd opt to spend $20 on new. They'll need to know brand of crank -- different bearings depending on crank used, Shimano vs SRAM vs Campy.
Quoted: 8 Post(s)
Now I'm looking at the numbers of selling my 2.1 frameset vs. selling the complete bike, and evaluating which will make the most sense. Kind of like the idea of buying better components for the 5.9 and building up with that, especially new cables all around...also simplifies the teardown from my existing 2.1 and just selling the complete bike instead.
longbeachgary - never tried them, and I'd be perfectly happy to but I don't want to drop the big $$$$ on an electronic setup.
Quoted: 2026 Post(s)
Liked 1,096 Times
Quoted: 8 Post(s)
You need the two inserts at the front (I think they're made of either plastic or aluminum), the cable guide under the bottom bracket (probably already there), and the insert at the rear derailleur exit. These are unique for mechanical shifting because the outer cables must press into these and hold against the cable pull pressure. For DI2, they are just rubber inserts that stay in place mostly from friction, whereas the mechanical inserts fall out without cables holding them there. It helps if you can get your hands on some small plastic tubes (like straws, but much thinner and 2 feet long) to help guide the cables through the downtube and out the chain stay.
I'm surprised Trek can't help, but a Trek dealer should be able to. My local shop was able to help me out with a couple components that were nearly impossible to source. They kept several parts bins full of leftover parts from all kinds of new and old bikes, and it was easy to pick up a few specific things (like a front brake nut, and the crank insert sleeve for the bottom bracket).
lakeside1234
Bicycle Mechanics
2
02-26-19 12:04 AM
