French Campeur bike
French Campeur bike
Here is a bike i have just got and i think it's dated from the late 40s into the 50s.
At some point it has been updated with CYCLO derailleurs.
It has the early M.A.F.A.C cantilever brakes and levers and MAVIC fenders.
It is missing it's JOS lights front and back but still has the dynamo.
The frame looks nicely made and the big rear rack is brazed onto the frame.
The front rack has had the rear part removed or snapped off.
The TA chainrings appear to of been added later as well.
This is how i received the bike and as you can see it needs some work!
Bikes: 1984 Miyata 310, 1986 Schwinn Sierra, 2011 Jamis Quest, 1980 Peugeot TH8 Tandem, 1992 Performance Parabola, 1987 Ross Mt. Hood, 1988 Schwinn LeTour, 1988 Trek 400T, 1981 Fuji S12-S LTD, 197? FW Evans
Quoted: 523 Post(s)
Liked 973 Times
Wow, that is quite a turn around!
Nice start and as always, interesting bikes you find. Shame about the missing headbadge. Any idea of the maker ?
I dig the 4 cog hub but am in love with those MAFAC cantilever brakes. Noticing as well the fancy work on the lugs. Was the shifters originaly on the down tube and the PO moved them to the seat tube or vis-versa ?
More,more
More,more
Bikes: Schwinn Continental, Schwinn Paramount, Schwinn High Plains, Schwinn World Sport, Trek 420, Trek 930,Trek 660, Novara X-R, Giant Iguana. Fuji Sagres mixte.
Quoted: 35 Post(s)
Liked 22 Times
Love those fenders!
More,more
More,more
So i need to study bikes with the same three rivets and frame details.
So far i have found a number 7 under the bottom bracket.
As can be seen in one of the photos the downtube has a braze on for a lever.
There is nothing on the other side. So i suspect it would of had a hand operated front derailleur.
Or perhaps the Cyco front derailleur is original with the lever clamped on the seat tube.
I also got this beautiful Mixte bike this week.
The name F Maillard is hand painted on the down tube and MF painted on the head tube.
I'm fitting a front porteur rack to this one at the moment.
Then i need to get some clamps so i can fit a chain guard.
The original chain guard braze-ons have been broke off.
So separate control locations ?
I noticed another feature I have seen on 80's MTN and road bikes. On the drive side chainstay is a loop that I suppose was meant to protect a cable or the paint ?
Back to look over the pics again.
It looks like the mixte has the tires that the first campeur had. Much better condition too.
Phyllo-buster
Quoted: 2295 Post(s)
Liked 2,042 Times
Why would you think the Cyclo gears were added later? Many bikes of the period had them. It even has a braze on for the spring.
The white tyres were originally on the mixte.
But when i found these red ones i replaced them.
They might end up on the campeur yet!
And yes it's quite common to see these chainstay loops on the older bikes.
I think they are to protect the frame from the chain slapping.
It wasn't just Cyclo using these springs and the Huret that i have fitted uses the same spring.
Also on the frame and chain stay there are two braze-ons for running a single cable to the rear derailleur.
vintage motor
Bikes: 48 Automoto, 49 Stallard, 50 Rotrax, 62 Jack Taylor, 67 Atala, 68 Lejeune, 72-74-75 Motobecanes, 73 RIH, 71 Zieleman, 74 Raleigh, 78 Windsor, 83 Messina (Villata), 84 Brazzo (Losa), 85 Davidson, 90 Diamondback, 92 Kestrel
Quoted: 163 Post(s)
Liked 101 Times
Great bike, nice find. Can you tell if it's chrome moly or high-ten? I often wonder that about the old French tourers.
Phyllo-buster
Liked 2,042 Times
Learn something every day...nice bike, thanks.
Quoted: 554 Post(s)
Liked 3,793 Times
A french campuer is among my wishes. The stuff of dreams for me. Maybe someday it will be realiized
Quoted: 3802 Post(s)
Liked 3,324 Times
campeur:
what is your thinking on changing out the rear mech?
arms look like they may be durax.
is bb spindle a verot competition 55? appears it may be hollow.
is the gear bloc a moyne?
hs appears it may be lightrace.
concur with dating.
f. maillard:
is she fitted with beborex roller cam brakes? those beborex guidonnets are a rare item indeed.
for 3speedslow, here is a picture of the rubber strap which mounts of those chainstay braze-ons to protect the finish from chainslap: https://tinyurl.com/nygpup4
thanks Daveyates for sharing these two fascinating new arrivals.
concur with dating.
f. maillard:
Juvela,
That is my" learn something " item. I think I actually have one of those straps in a box of unidentified parts. Green,Edelweiss name on it. dry rotted though.
Thanks for the enlightenment. Your knowledge of French bike parts on this side of the pond is something, Bravo !
Liked 3,324 Times
Juvela,
while most commonly seen in black they are made in something like half a dozen or more current colours to match or contrast with the cycle as the owner desires.
seeing one stretched onto its standards always reminds me of those t-shaped clothesline posts.
am certainly enjoying these two fine finds by Daveyates
campeur:
concur with dating.
f. maillard:
concur with dating.
f. maillard:
I explained above that the derailleurs are not original to this frame and so that's why i changed them.
I'm not sure which crankarms they are but i would guess no to Durax.
I have not heard of Verot before but i shall check when cleaning.
The freewheel isn't marked with a maker's name, I haven't checked the back yet though.
I'm not sure but isn't Lightrace more 70s?
The brakes on the Maillard are CLBs and the levers are the nicer ones by LAM.
The braze-on is a singular one and not a double for a rubber strap.
The stem is starting to look nicer.
Before
And after a quick polish using sandpaper and then metal polish with wirewool.
Before
Quoted: 554 Post(s)
Liked 3,793 Times
