Can I please have some information on my Cannondale?
Bikes: 1984 Maruishi RX-4 Sport 12 speed, 1985 Schwinn Sprint 12 Speed, 1987 Cannondale ST-500 14 speed
My uncle gave me this Cannondale yesterday. It doesn't seem to have a factory model decal. It's a 14 speed with very reliable and smooth Suntour components. The frame is fatter than most road bikes I've ever seen but its very light. It also has San Mistral M13 630 aluminum wheels with quick release hubs. Frame is small but fits me just right. Can someone give me any info? I could not find any info online. The serial number on the bottom of the rear dropout reads: 21040987137 and the down tube says 58925.
I also need help on how to air up the tires. It has a valve stem that has a screwable piece.
I don't know vintage Cannondales very well but I'd guess that you have an 80s era touring model. They have fat tubes because they are aluminum and big diameter with thin walls works well for stiffness and light weight. You have Presta valves on your tire tubes. They are smaller than schraeder valves, the same as on a car. Picture 2 shows the adapter that allows a schraeder pump head to pump up a presta valve. Your pump head will determine whether to use the adapter or not. Either way, the very top of the presta valve is a tiny threaded fitting. Unscrew it. As you pump the tire, greater pressure in the pump will push the small fitting down and open a valve letting air into the tire. The pressure in the tire will close the valve. When done inflating the tire, screw the small fitting back down.
Small Frame Guy
Bikes: 2015 Bianchi Tipo Corsa, Pegoretti Palasanto,Trek,2019 Bianchi specialissama, 2014 Bianchi infiniti, Madone 5.2, Comotion Speedster (all campy equiped), 93 Masi 3V, Bridgestone RB1
Nice bike just my size :-)
Here is a link to vintage cannondale catalogs. The screw on piece is an adapter for schrader (like cars) to presta (fancy bicycles) valve heads. You can screw it off. I would go down to a bike shop and I am sure they can help you out with the correct pump if you don't have one now.
Vintage Cannondale - Cannondale Catalogs
2019 Bianchi Specialissama - - 2013 Trek Madone 5.2 - - Masi team 3V - Pegoretti Palasanto - Bridgestone RB-1 - Comotion Speedster - Bianchi Genius - Giordana XL superleggero - Trek superfly
Quoted: 659 Post(s)
Liked 595 Times
I see an 87 in your SN you listed. Though I expected maybe '84-ish because of the non-aero brake levers that have the cables out the top of the rubber hoods. Go to Vintage Cannondale - Information and Catalogs for Cannondales and click on "catalog" and then click '87 year. You definately have a touring model and will see those bikes down below the racers that are listed near the top. Nice bike! The paint looks to be in uncharacteristically great shape! Frames are very light, very strong and very stiff. And that's why many of us here are in a cult of sorts.
Bikes: to many to list
Quoted: 296 Post(s)
Liked 1,064 Times
That looks like an 87 ST400
Touring frame, inexpensive suntour, SR and dia compe componants. I don't think the rims are stock. I think they came with Rigida. It existed to reach a pricepoint under $500 at the time.
From Illinois. Collector of many fine bicycles from all over the world. Subscribe to my Youtube channel. Just search John's vintage road bike garage
aka: Dr. Cannondale
Quoted: 2152 Post(s)
Liked 3,402 Times
Yep, serial number confirms it's an 87 ST frame. Parts may have been juggled around since it was originally purchased, but a good, solid bike.
Bikes: 1986 Alan Record Carbonio, 1985 Vitus Plus Carbone 7, 1984 Peugeot PSV, 1972 Line Seeker, 1986(est.) Medici Aerodynamic (Project), 1985(est.) Peugeot PY10FC
Quoted: 150 Post(s)
Liked 34 Times
The biggest advantage with Presta valves, over Schrader valves, is with the smaller ID opening on them, it is easier to achieve higher than 100psi pressures with bicycle frame and floor pumps. The locking valve also provides more security with the valve's seal during harsh racing conditions...
Extraordinary Magnitude
Quoted: 2608 Post(s)
Liked 1,699 Times
You've been on a tear, looking at and finding all kinds of bikes!
This Cannondale looks like a good, quality bike.
Best wishes!
Best wishes!
Commence to jigglin’ huh?!?!
Thanks guys! I found out it's actually an SR-500.
the tubes are larger because they are aluminum. Cannondale has always been known for its wonderful advancements w/alum and awesome ride quality.
the fork looks to be steel. Unless you are planning on putting some panniers on the front you may want to look into replacing it w/ carbon. Nashbar has a few inexpensive options that would probably make that ride even better. Make sure you buy the right diameter if you get one, probably 1 inch not 1 1/8.
Nashbar - Road Bike Forks
the valves are called presta. most good pumps will have a flip flop head or an adapter to switch between presta and schrader (car tire style).
He gave you the bike?? so you still have the cash you were planning on spending on a bike. Id use it to, replace the foam on the bars w a good wrap. I like fizik's products.
Id invest in clipless pedals and shoes, a second water bottle cage, a seat bag and basic tool kit for on the road repairs, A few extra inner tubes, a frame pump, a floor pump, helmet, blinking light for the rear, gloves, bibs, bottle of chain lube........
depending on how they look, tires, brake pads, new chain, cables/housings
enjoy and ride safe.
2010 Kestrel RT900SL, 800k carbon, chorus/record, speedplay, zonda
2000 litespeed Unicoi Ti, XTR,XT, Campy crank, time atac, carbon forks
Semper Fi
Quoted: 1172 Post(s)
Liked 358 Times
Please check on this year, the serial number is as noted above, an ST model tourer. The fork has bosses for a rack and the rear drops have 2 fender and rack mounting holes on them. The SR are great crit bicycles, I had a '91 SR300 and loved it dearly. Just don't want you getting bad information. Its a nice bicycle, too.
Bill
Bill
Semper Fi, USMC, 1975-1977
Expired Member
Quoted: 3660 Post(s)
Liked 5,408 Times
Yes, ST not SR.
