A quick tire question
Quoted: 1743 Post(s)
Liked 1,281 Times
Last year I went from 700/23 to 700/25 tires and like them a lot. Tomorrow my gf and I are going out for an hour or two just to get some early season miles. LSD of course. She's riding 700/23s and I want to put some 25s on her bike for the ride. Problem is I only have one 25 here. Can I put that 25 on her rear wheel and leave a 23 on the front with no ill effects? I'm guessing I can but have never done it and thought I'd seek out some 50+ wisdom. FWIW I have some Vittoria 25s coming from Competitive Cyclist but not 'til next week. TIA
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4337 Post(s)
Liked 2,980 Times
Of course, proceed with zero doubt, everything will be fine.
Liked 6 Times
I actually run one of my bikes that way. It gets used for shopping and when the bags in the rear are full, there's lots of additional weight on the rear wheel. Never had an issue doing this.
A conclusion is the place where you got tired of thinking. - S. Wright
Favorite rides in the stable: Indy Fab CJ Ti - Colnago MXL - S-Works Roubaix - Habanero Team Issue - Jamis Eclipse carbon/831
don't try this at home.
Quoted: 973 Post(s)
Liked 511 Times
Are you trying to get a smoother, but still efficient ride?
The usual method is to put 10 psi less pressure in the front than the back (with both tires the same size). With the 25c in the back and 23c in front, use about the same lower pressure in both.
At 170 lbs, I use 90-95 front, 105-110 rear in 23c. And 85-90 front, 100-105 rear in 25c, and could probably lower the front to 80.
A lightweight rider could start with 85 in the front 23c, and 95 in the rear 25c.
I started using GP4000 25c tires last year. They are still fast, but better on the rough roads than the same tires in 23c.
Semper Fi
Quoted: 1172 Post(s)
Liked 358 Times
Sure you can do that one, Bruce, Continental even sells a model that' s sized that way. shouldn't be a problem. The switch to 25 is one of the best moves I have done in a while.
Bill
Bill
Semper Fi, USMC, 1975-1977
