Mammoth Fall Century.
Certifiably crazy!
Bikes: Felt Z5, Edict 9
Has anyone ridden in it? How is it? I like climbing, so that's not a big deal. What is a big deal is the elevation. I've mountain biked at 6k feet and got acclimated in a bit. How do I train for the elevation at Mammoth? Looking at the profile, it hits 8k feet a couple of times and doesn't go below 6k much. I'm used to riding at sea level for the most part.
Thanks!
Thanks!
Bikes: 2008 Cannondale CAAD9 5, 1995 Cannondale CAD F300 hardtail
I will be there, the only thing I can suggest is, sleep a night or two at elevation to get acclimated. That and ride at elevation around here as much as you can to get use to the shortness of breath. When I did Eastern Sierra Double I felt the elevation only at the very top of the climbing in Mammoth and on the east side of 120. It was very manageable. I will be riding this in preparation for White Mountain Double the following week which hits 10,000ft +
Shredding Grandma!
Bikes: I don't own any bikes
Quoted: 46 Post(s)
Probably one of the most scenic centuries around. Roads are generally in good shape and once off 395, lightly travelled. It is not an easy Century; alot of very steep climbing and the whoop-de-dos after Mono Lake are annoying (fun... at first... then just annoying). There are a few steep descents to keep one alert.
It's well worth the effort...
______________________________________________________________
Private docent led mountain bike rides through Limestone Canyon. Go to letsgooutside.org and register today! Also available: hikes, equestrian rides and family events as well as trail maintenance and science study.
Seat Sniffer
Quoted: 944 Post(s)
Liked 1,980 Times
The only thing better is the Eastern Sierra Double.
Good advice up there. Acclimating, even for a day or two, helps a lot. But if you don't have the time, I wouldn't let that stop you. I the Eastern Sierra. Here's the view you'll get riding back to the starting point at the end of the day:
Has a magic bike
Quoted: 4456 Post(s)
Liked 425 Times
I am also considering this ride but am unsure about the elevation. I could MAYBE arrive Thurs late night but Friday would be easier.
I was thinking of testing the water with the Tour de Big Bear about a month before. This ride is 75 mi, 4800 ft climbing and I think at around 6000 ft of elevation.
How much gain is there in actually training some at elevation vs just training more at my home elevation (around 1200 ft)? I understand the going early part to acclimatize before a ride. But does intermittently riding at altitude make enough of a difference to be worth the trouble? In my case, driving to train mat elevation would be at least a 2 hr round trip, would I be better off just riding 2 hrs longer at home?
H
H
Ok I am not mistaken training at altitude will get you used to shortness of breath. But staying at altitude will reduce the shortness of breath.
Bikes: 2019 KonaLibre- 2003 Litespeed Vortex -2016 Intense Spider Factory Build -2008 Wilier Mortorolio- Specialized Stumpjumper Hardtail converted to bafang 750 mid drive -1986 Paramount 2014 - --- Pivot Mach 429c
Quoted: 43 Post(s)
Liked 15 Times
drink before your thirsty eat before your hungry is especially true at altitude. I have a hard time with it as well.
Shredding Grandma!
Quoted: 46 Post(s)
I understand taking aspirin every few hours helps the headaches but isn't all that good if there is an injury (bleeding!). I used aspirin to climb Mt. Whitney, the one place I have struggled from the altitude and it helped.
The thing about Mammoth, its a century, with steep tough climbing. Add that on top of the attitude. If your fitness is good, most likely it will be easier but then again, like I said, my friends in good shape suffer. For some reason this big ole fat lady does OK.
Seat Sniffer
Quoted: 944 Post(s)
Liked 1,980 Times
I should probably also throw a few other thoughts out there.
Until last year, the route started and ended at the Whitmore ball field on Benton Crossing Road. That meant that the ride distance was only about 93 miles instead of 100. Starting last year, the route begins at the Village, heads down the 203 to US395 and ends going back UP the 203 to the Village.
Descending to start and ascending at the end has some disadvantages ... Namely that it is likely to start with a chilly descent and end with a headwindy ascent. But at least the basic route is now 100+ miles.
If I have one criticism of the route, its that they bypass the June Lake Loop. The route has you climbing up to the June Lake Junction and heading straight down a 4 mile descent to the 120. A MUCH better route is to make a left at the June Lake Junction and take that to Highway 120. That adds at least 10 miles to the route and will probably add at least an hour to your time (for those that care about such things), but it is more than worth it.
There is a little climb to Oh! Ridge. So named because this is the view on the other side:
You then roll through the burg of June Lake (home of the Tiger Bar, an official Clamper watering hole), then descend through groves of apsens on a twisty road ... with a view of Horsetail Falls.
You scoot by Silver Lake (and the oldest continuous running resort in the Eastern Sierra):
Then pass by the much drier (and man made) Grant Lake:
All that is mostly flat or downhill ... you'll use your elevation gain sparingly instead of all at once if you follow the main route. And from Grant Lake, you do a fast sweet descent down to US395 with a great view of Mono Lake, and head south only a few hundred yards and you're back to the Fall Century route.
Soooo. If you're disposed to add about 10 miles to the route, definitely take in the June Lake Loop. They'll be the most memorable miles of the ride, and well worth it. If you'd rather not, the June Lake Loop makes for a great warmup or training ride the day before. Start at the northern terminus, ride south on US395 (about a 4 mile climb), and then make a right at the June Lake Junction.
There is also a nice headwind once you hit Grant Lake all the way out.
Seat Sniffer
Quoted: 944 Post(s)
Liked 1,980 Times
I've hit tailwinds more often through there. Funny thing ... that descent from Grant Lake to US395 is where I hit my top speed ever ... 57 MPH. It's not all that steep, but I had a rippin tail wind!
I hit mine going into Benton 55, and you would think I would have a higher number with Mt Baldy so close.
Seat Sniffer
Quoted: 944 Post(s)
Liked 1,980 Times
I love that descent through Blind Springs Valley and into Benton. And that brings up another worthwhile detour from the High Sierra Fall Century route. The view from the top of that descent is AWESOME and worth the short (1/4 mile or less) climb.
shut up and ride
Bikes: supersix hi-mod,burley duet tandem,woodrup track,cannondale cross,specialized road
aclimitization takes two to three weeks, if you can't do that you want to show up closer to the event.
Has a magic bike
Liked 425 Times
you mean altitude as opposed to elevation. right or wrong when we refer to elevation we mean the amount of vertical gain on the ride whereas altitude refers more to how high the ride occurs.
What do you mean "show up closer to the event"?
H
shut up and ride
you are better off showing up fri night rather than thurs if the event is sat morn.
I did the ride last year, solely on the inspiratoin provided by some of Biker395's pics. Let me tell you, his pics are great, but the actual scenery is even better. There is a "hugeness" out there that you have to experience first hand. Big mountains, big climbs, big descents. I hit the headwind coming back into town from the ball field, and that was grueling, particularly having to fight the wind next to cars and trucks screaming by on 395. That was probably the worst 10 miles of my life, but totally worth it because of the 90 miles that came before it. Coming from the bay area I didnt think the hills were particularly steep, they just went on forever.
I came up from sea level on Friday, and based on B395's recommendations did the June lake loop that afternoon. It was great. I started and ended at the junction, and didn't have any altitude problems(headache and some dizzyness) until the last section of the climb back up to the junction, and while altitude probably contributed to the fatigue I was feeling at the end of the ride, the wind was probably the main culprit.
I've already signed up again for this year. This time I'm planning on coming up some time the week before and getting in some of the bucket list climbs (horseshoe, white mountain, whitney etc.) dont know if that will make the century easier or harder, but the scenery alone will be worth it.
One note, unlike many other centuries, this one does not have a bail out point. Once you go over the first pass, you need to commit mentally to completing the ride.
shut up and ride
it takes two to three weeks for your body to adjust to the altitude. once you arrive at altitude you body starts the process of acclimatizing, you are worse off fitness wise in the middle off the process than before it begins. so your best options are arriving weeks ahead of time or the night before
Has a magic bike
Liked 425 Times
H
shut up and ride
the saying in training circles is 'live high, train low'. living at altitude will build more red blood cells but you can't train as hard since there is less oxygen so you can't work your muscles as hard. this is why they sell altitude tents to sleep in, very expensive and now not legal for racing.
so the occasional trip to altitude won't help, it's a long, slow process
Seat Sniffer
Quoted: 944 Post(s)
Liked 1,980 Times
I've read the same, but I have to say that my personal experience differs with that. I feel the effects of altitude most seriously the day after I arrive, but spending a few days at altitude helps me tremendously ... it doesn't take nearly 3 weeks to feel a benefit.
www.ocrebels.com
Bikes: Several bikes, Road, Mountain, Commute, etc.
Quoted: 83 Post(s)
Liked 5 Times
I rode it two years ago, drove up on Fri., didn't have any problems with the altitude at all. I know it's an individual thing, but for me (thankfully) pretty much a non-issue.
Overall it's a beautiful and well-organized event. Easy to find your way on the well marked route and of course (as noted above) wonderful scenery. Yes, there are lots of climbs but nothing brutal.
Rick / OCRR
Rick / OCRR
Shredding Grandma!
Quoted: 46 Post(s)
Last time I did the Century we finished (and started) at the ballfield past Crowley Lake. I have to say, not certain I would want to do that climb up to the Village to end my ride. It was sucky enough doing it first thing - but early, traffic was light and the climb warmed you up - I get why they change the route but I do think it was better before.
Shredding Grandma!
Quoted: 46 Post(s)
Says you and Biker395 the double century guys... boys its all relative... the climbs are tough for normal people... you guys are supermen!
