Where to focus efforts for fastest commute
This tactic works well on really short, rolling terrain. Sustained climbs and descents of as little as a hundred yards or more are better to work on the uphill, rest on the down.
This is Gleneyre Dr. in Newport Beach. I like to hammer down the short decent in the foreground so that inertia carries me through the following steep rise, that I stand for. This gives me enough speed coming out the top that I can settle in an cruise to the next little roller. You can see there are a couple more like it further down.
Bikes: Surly Long Haul Disc Trucker
Quoted: 1015 Post(s)
I've read something similar although what I read was more in context of racing where it seems to be more beneficial to drop someone on the hills (it certainly would be from a psychological perspective), the effort in fact is disproportionate to the total speed gain. The author went on to say that if you're simply challenging yourself, conserve your energy going uphill and then put in the effort downhill and on the flats.
If you're going fast (i.e. downhill) then more effort gives you only a marginal gain in speed because the effect of wind resistance above about 10 mph becomes more and more exponential. But when you're going slow (i.e. uphill) more effort gives you what's close to a proportionate increase in speed.
Downhill, double the effort and you might go 25% faster. Uphill, double the effort and you might go 90% faster. The specific gain/drag depends on the exact speeds and inclines involved. But this effect is undeniable.
These concepts relate directly to my training as an airplane pilot where we approached this a little more formally. At less than supersonic speeds, there are primarily only two components in wind drag. These are known as Parasite Drag and Form Drag (for airplanes there is also Induced Drag but that is not relevant to bicycles).
The form drag is caused by the compression of air molecules in front of a moving object. The object pushes the molecules directly in front of the object, those molecules then push on the molecules in front of them, and so on. So the object is not just pushing the air out of the way, the air in front of that air is getting pushed too, and so on to a diminishing extent as you move out in front of the object. The drag is caused by the energy required to compress the air in front of you. The faster you go, the more ALL the air in front of you is asking to be so-compressed before it gets out of your way. This gives the form drag an exponential effect, where the drag increases with the square of velocity.
Then there's parasite drag. Parasite drag is basically the friction of the air molecules as an object moves thru the air. Parasite drag is all over the object, not just in front of it. Parasite drag is proportional to the speed of the object.
So both of these types of drag are in play. But because the form drag is exponential, it becomes a stronger and stronger component of the drag as speed goes up. At low speeds, the parasite drag is much more significant. But the faster you go, the more the drag will seem to be only exponential in nature.
There's more slowing you down than just air resistance. So overall drag is not increasing as the square of speed necessarily. That's just what the form drag component of your overall drag is doing. But the faster you go, the less significant these other components become because they increase linearly instead of as the square of speed.
Well, in that case, I'm going supersonic!!!
Thanks for the explanation!!
Maybe I missed someone else suggesting it, but for real speed, you should also consider one of those four-wheeled behemoth things with an engine. An automa-something-or-other. I see them when I'm out riding. They are much faster than most bikes.
Liked 5 Times
Anybody that says conserve on the uphill and put the effort into the downhill has it totally backwards.
But you're not going to go 25% faster going downhill by doubling your power because you're already getting a lot of power from converting potential energy to kinetic energy. So when you double your input from say, 100W to 200W, the total power making you go forward goes from, say, 1600W to 1700W. So you only add a few percentage points to your speed even if you hammer hard enough to blow yourself up. Because you actually went from 1500W making you go while coasting to 1800W while hammering away.
And while drag is proportional to speed squared, the power to overcome drag is proportional to speed cubed, because power is force times speed. The force is proportional to the speed squared, and then the power is proportion to the force times the speed. That's where doubling your power on the flats only increases you speed by 25%. The cube root of 2 is about 1.25.
And yeah, I'm using just form drag because at higher speeds that's by far the most dominant impediment to going faster.
Quoted: 2952 Post(s)
Liked 3,106 Times
Quoted: 4227 Post(s)
Liked 2,488 Times
If you want to ride faster then you need to increase horsepower in you engine ( IOW get fit ).. A different bike frame geometry can also help ( road vs MTB ) but not always, I've seen some very fast riders on MTB's with knobby tires.
curmudgineer
Bikes: 2 many 2 fit here
Quoted: 263 Post(s)
Liked 112 Times
I should add, my comments are based on my experience with widely separated lights having no timed relationship. In a situation where lights are close together and a known timed relationship exists, then obviously you can try to adjust your speed to take best advantage of this.
Quoted: 1186 Post(s)
Liked 289 Times
Because very strong riders can ride quickly on a MTB you conclude that it doesn't always make one faster? I'll give you a tip - a road bike will always make you faster than a MTB with knobby tires regardless of your power level.
Liked 3,106 Times
That works best if you can sprint to beat a red light. Slowing down to hit a light as it goes green saves a marginal amount time vs getting there too early and having to accelerate again; however the energy saved is non-trivial, if your goal is to conserve energy.
Bikes: 61 Bianchi Specialissima 71 Peugeot G50 7? P'geot PX10 74 Raleigh GranSport 75 P'geot UO8 78? Raleigh Team Pro 82 P'geot PSV 86 P'geot PX 91 Bridgestone MB0 92 B'stone XO1 97 Rans VRex 92 Cannondale R1000 94 B'stone MB5 97 Vitus 997
Quoted: 392 Post(s)
Liked 49 Times
I developed a rule of thumb that works in my sample of n=1. At a constant effort, cruise speed on a MTB with slicks is 2 mph faster than MTB with knobbies, and road bike is 2 mph faster than MTB w/ slicks. So 16 mph vs 18 mph vs 20 mph, if that is one's cruise speed.
curmudgineer
Quoted: 263 Post(s)
Liked 112 Times
I'm sure that's true, for your commute. As I mentioned, I was referring to my commute. If you have a method for avoiding red lights, that are separated by over 2 miles in some cases, that doesn't involve sprinting when you get close enough to actually see the light and be able to assess when it's going to change, I'd like to learn about it. This is pertaining to lights with no timed relationship. Due to the distance between lights, elapsed riding time between lights is heavily influenced by wind, at any rate.
Liked 289 Times
You can see this with an example: riding 23kph into a 20kph headwind requires about 200W. The net wind speed in this example is 43kph. If you increase your speed by 10% from 20 to 22kph the net wind speed goes up by 4.6% and the aero drag will only go up by about 9% instead of the 20% you would see without a headwind.
Downhills are different as most of the power to overcome aero drag is coming from gravity.
Bikes: Nashbar Road
Quoted: 2934 Post(s)
Liked 341 Times
Also, try to time things where you aren't using your brakes (wasted energy).
The OP is pedaling a CARGO bike. Start with the bike.
Liked 5 Times
Aero drag is proportional to the net wind speed squared. Without a headwind an x% increase in speed results in about 2x higher aero drag (i.e. 2% increase in speed => 4% increase in aero drag). With a headwind, an x% increase in ground speed will result in less than 2x increase in aero drag.
If it takes you 400W to go 30 mph with no wind, it's not going to take 400W to go 20 mph into a 10 mph headwind, or 10 mph into a 20 mph headwind. Both of those cases, it'd take less than 400W to maintain that 30 mph relative wind speed.
If that doesn't make sense, look at it this way: how much power do you have to generate to stand still in a 30 mph headwind? Yep - zero.
While most of the force needed to make you go fast is relative to the square of how fast you're going through the air, the power required to make you go that fast is determined by that force times how fast you're going relative to what you're pushing against - the ground.
Prefers Cicero
I go up a big hill in the morning, and down it in the evening. I find that working harder on the downhill part might shave off 10 or 20 seconds. Working harder uphill seems like it can make about a minute difference.
I have found I am more likely to pass or be passed on the climb, and typically the passer (me or the much more in shape climber) will continue to pull away. I have seen a lot less passing downhill.
One thing I notice uphill is that if you work to maintain momentum you an keep a higher speed the entire climb. Once you start slowing down on the climb its easy to keep slowing down and harder to build up speed again.
Honestly the flats an make a difference too. I have a couple long flat areas, not stops, probably making up over 1/3 of my overall commute. It can make a noticeable difference if I push myself and go a few mph faster on these sections vs ride a a more leisurely pace.
Quoted: 5772 Post(s)
Liked 2,568 Times
However, if you look at absolute speed, rather than proportionate, your argument weakens. If you're going 5mph up a steep hill and double your effort (and speed), you only get an extra 5 mph. If you're going downhill at 40 mph and doubling your effort gives you a 25% increase, that's an extra 10 mph.
FB
Chain-L site
FB
Chain-L site
Bikes: quite a few
I agree with all the replies saying uphill or into the wind is where you make the best gains. Oh, and of course, traffic lights if you know their timing.
Bikes: quite a few
Shaved legs don't make the list - I don't think they do anything measurable.
