do you clean stained water bottles?
commu*ist spy
by stain, I mean probably some kind of fungus that's entrenched on the bottom of the bottle. I've tried soap, scrubber, vinegar, even detergent, with decent results on one, but no luck on the other one ( and I scrubbed hard). I wonder if the stain is just residue that's latched onto the material, which is probably something close to low density PE, and not really harmful. I'm just curious to see if others clean theirs, re-purpose them or just toss them.
Quoted: 929 Post(s)
Liked 1,595 Times
Full strength Clorox
If undiluted bleach doesn't clean it, I would toss or re-purpose.
BTW, "even detergent"? What do you wash your bottles with before they get all stained?
Whatever dishwasher soap we use seems to have a little bleach in it as my bottles always come out squeaky clean.
Bikes: Trek Domane 6.2 Project One
Quoted: 5 Post(s)
I've spend thousands of dollars on my bike, so when a bottle gets that funky, what's a few bucks on a new one?
Quoted: 52 Post(s)
Try OxiClean and hot water. I found out how effective OxiClean was in my home brewing operation and it has carried over into everything else.
Bikes: Schwinn Broadway, Specialized Secteur Sport(crashed) Spec. Roubaix Sport, Spec. Crux
Quoted: 178 Post(s)
Liked 161 Times
Prevention is the best cure. Bottles are cheap.
Sir Mark, Knight of Sufferlandria
Quoted: 2952 Post(s)
Liked 3,106 Times
Bleach does the trick for me.
Bikes: 2 many
Quoted: 1266 Post(s)
Liked 323 Times
If you're not really cheap, but a new bottle.
If you wash them after each use then dry them upside down, they don't get moldy.
Bikes: Volagi, daVinci Joint Venture
Buy Camelbak, rinse well after each use with hot water and occasionally run through the dishwasher.
Lover of Old Chrome Moly
Quoted: 143 Post(s)
Liked 23 Times
A quarter inch or so of regular chlorine bleach in the bottom of the bottle, cap, shake, let sit for a few minutes, shake again, squeeze bleach (carefully) out of drinking spout into sink. Triple rinse with hot water, including rinsing the spout. The best preventative is to rinse bottles that contained any sort of sweetened sports drink ASAP and let air dry upside down. You still need to wash them once in a while, but rinsed and dried will at least keep the funk at bay.
Bikes: S5 VWD & SL-7 S works Red.
Quoted: 52 Post(s)
Bikes: 2009 Cannondale CAAD9-6 2014 Trek Domaine 5.9
Bikes: 2017 Tarmac Pro, 2014 S-Works Tarmac, 2011 Trek Madone 6.2, 2014 Trek Madone 5.9 & 2009 Specialized Hardtail
Quoted: 28 Post(s)
What about cleaning the valves on the camelback podium bottles?
Quoted: 52 Post(s)
Farmer tan
