Where to put bike head and tail lights??
Hello all!
I have a Dahon Vitesse D7HG, and I've been itching to find a bike light that I can put on the bike without getting in the way of the fold! So far all the lights I've come across come with rubber shims that once set, cannot be moved, effectively getting in the way of the bike's folding mechanics and not allowing it to be as compact as possible!
Thanks!
Thanks!
I have a Shimano narrow Hub dynamo on my Brompton ,
B&M Eyc headlght on fork crown, Busch & Müller: LUMOTEC IQ2 Eyc
and toplight line Plus taillight, replacing the reflector ..
Busch & Müller: TOPLIGHT Line plus
Shrink tube, tape and zip ties secure the wiring ..
maybe N/A with your ' Dahon Vitesse D7HG', there are Hub dynamos made for Dahons too .
I no longer think about lights ..wheel turns, the lights light.
Low lights also are well under the rain cape's bottom edge so it still works in the rain..
Though I've seen Cycle rain capes with a clear window in them so the handle bar light will shine through .
Re the Dyno hub on DaHon's
Thor sells them, he posts here.. maybe he has a plug and play Dynohub upgrade for your particular bike..
Bikes: 3 folders, 2 recumbents (1 is electric), 1 recumbent trike, 1 touring, 1 mountain, 1 road bike -- So many bicycles, so little time.
Hello all!
Thanks!
Thanks!
https://www.ebay.com/itm/New-53-LED-B...item232fa53957.
Bikes: Brompton H6L-X, Dahon Curve D3
Quoted: 56 Post(s)
Mine are the regular (not the "extended" bracket) ones. The bike folds just fine. These lights are great, passive "be seen" lights. You will likely also need a separate headlight if you need to light up the road.
-HANK RYAN-
Norman, Oklahoma USA
LET'S ROLL
I use a Hotshot rear light mounted on the seatpost; there's about 3/4 of an inch
of the post that sticks out since the light mount is preventing me from pushing the
post all the way down. For the front I use a Magicshine clone, Singfire SF90. The
light head mounts on top of the bars using o rings and the battery pack is on the
stem. Sometimes for the front I use a Xeccon Geinea which has a smaller head.
It's so tiny; it's difficult to see in these photos. But it's the gold round thing by the
bars. All of these lights don't get in the way when folding:
One day: www.youtube.com/watch?v=20X43026ukY&list=UUHyRS8bRu6zPoymgKaIoDLA&index=1
master of bottom licks
Quoted: 111 Post(s)
Video cam on right, very bright Cree LED on left.
Planet Bike Superflash tailights. Both set on "blink". The tool bag/lights unit gets moved from bike to bike.
Planet Bike Blaze. Both set on "blink". They mount onto a quick disconnect base that I can move from one bike to another in a matter of seconds and the lights "slip and clip" to the base but I remove them from the bases and put them in the tool pouch before folding the bike (Bike Friday NWT, Brompton or Citizen Miami).
All of the lights on the bike use rechargeable batteries (AA and AAA size) and this setup has been going strong for at least 3 years of almost daily year round riding. The Cree LED is about a half year old and is ridiculously bright for it's size, weight and cost. It cost me $16 (with two batteries and a charger) and uses rechargeable #18650 (18mm X 65mm) 3.7v 2400mAh Li-ion batteries as found ganged in some laptop and notebook battery packs.
that locker room shot, the reflector is missing , the bracket is still there .. ? brompton-spanninga battery lights fit ..
or one of these .. https://www.bumm.de/produkte/akku-rue...ht-flat-s.html
Additionally , with my Bike fridyI also mounted by lights Low , so wearing my rain cape they were still under the cape bottom edge
rear one went behind the back of the seat tube waterbottle cage. front one at the bottom of the handlebar stanchion ..
CompleteStreets
9
10-22-16 06:57 PM
CompleteStreets
8
06-03-14 02:09 PM
