Spoke Length Help
~OPSEC~
Bikes: GT Timberline (mtb) and Haro Backtrail (bmx)
Spoke Length Help
Could anyone help me out with a good spoke length for Shimano DX Hubs laced to 36h Campagnolo Thorr rims (the 26" MTB ones). Any help would be appreciated. Thanks.
Mike
Mike
~OPSEC~
so I would need to buy 3 sets of spokes to make 1 wheelset? Geez, in the bmx world 1 set of spokes will build 2 wheels almost every time...
~OPSEC~
further questions, if I am buying 3 spoke lenghts why not go for a radial front and a radial non drive side. Can anyone help me with the lenghts for that?
la vache fantôme
Do not radially lace a hub with 36h. Radially lacing puts abnormal stress on the flange, and there isnt a heck of a lot of material between each hole with 36h. No manufacturer will answer to a warranty call if their hub was radially laced. And if your using disc brakes forget it.
C://dos
C://dos.run
run.dos.run
C://dos
C://dos.run
run.dos.run
~OPSEC~
No disc brakes here and the hubs are far from something I would warranty, however if 3 cross is universally recommended, 3 cross it shall be. To add something more, would it be acceptable to go with say, 259mm rear spokes and 261mm front spokes? or should I round up on the spoke lenghts?
la vache fantôme
Go 3 cross, the disadvantages to radially lacing far outweigh the advantages which are hardly worth mentioning, it looks cool, in theory has a very slight aerodynamic advantage and saves a whole 7 grams (approx). Some will probably disagree but I have done this with my builds with no issue, its okay to deviate +/- 1mm from the correct spoke length. So just go ahead and buy all 260mm, you will not have an issue.
C://dos
C://dos.run
run.dos.run
C://dos
C://dos.run
run.dos.run
