chain off
chain off
Tonight's ride home I decided to stop at the bank and take a longer route home. After stopping at the bank and heading on home, on a rural road my pedals stopped turning. I got off the bike looked at it quickly and could not figure out what was wrong. I started walking my bike home the seven miles I had left, that lasted at best two minutes. I was going to call a taxi, when I realized I had the bike shops phone number in my cellphone from last nights flat tire incident. I called the bike shop explained what happened. He told me what he thought it was, and he was right, the chain was off the rear cog at the very small end. He told me how to put it back on and that my hands would get dirty. I hung up the phone and put the chain back on, then finished my ride home. So all in all a very good learning experience for me. I have never had the chain come off of my bike before.
I'm glad you didn't have to walk the seven miles!
Chains come off sometimes -- so it's great to know how to fix it yourself. I'm glad the bike shop was able to help, and now you know what to do if it happens again!
Good job!
Good job!
Do your part to keep BikeForums rolling.
Become a donating member today.
Learn more
Learn more
Make sure you figure out why that happened - maybe take it to the shop and have them check it out. That's the last thing you want to have happen if you're pedaling with any gusto!
how many miles do you have on the chain and the cogs? I had a bike that started skipping teeth while pedaling and found out that it needed to have the cogs (cassette) and chain replaced.
also could be that the chain is gunked up and you need to clean it. you can get a chain cleaner online or from your lbs...
I hope you are not trolling...
if you are commuting by bike, I encourage you to take the time to learn the basic functioning of the bike. A chain coming off is about as simple as it gets. Learning the very basics will help you be self-reliant and you can also save a ton of money by learning basic maintenance.
Bikes: Surly Long Haul Disc Trucker
Quoted: 1015 Post(s)
You probably need to adjust the stop on your derailer. You must have started cycling lately? You didn't ride as a child? Enroll in a beginners class at your lbs. You need learn some basics. Like fixing a flat tire.
I plan to take it to the bike shop tomorrow as they suggested that while they helped me. It very well may need a new cassette and chain, I do not watch the mileage on a daily basis but the odometer just turned to 4200miles and I have had the bike about 2 1/2years.
Liked 6 Times
See if they'll let you watch what they're doing so you can learn some new tricks. It's not uncommon for a rear derailleur to need an adjustment to keep the chain from kicking off the smallest cog. BTW, I always carry a few small individual wipes in my rear seat bag just in case my hands get dirty from an unexpected repair.
A conclusion is the place where you got tired of thinking. - S. Wright
Favorite rides in the stable: Indy Fab CJ Ti - Colnago MXL - S-Works Roubaix - Habanero Team Issue - Jamis Eclipse carbon/831
Bikes: 2012 Trek Allant, 2016 Bianchi Volpe Disc
My chain came off both gears once when starting up a red light. Bang! Down to the ground I went. Luckily the cement mixer behind me saw me go down and stopped before flattening me.
I agree with the posters above: you probably need a new chain, especially after 4000 miles and especially if it's not cleaned regularly.
incazzare.
You may need a new chain/cassette, but you may just need to adjust the stops on the rear derailleur so it doesn't go past the cog.
1964 JRJ (Bob Jackson), 1973 Wes Mason, 1974 Raleigh Gran Sport, 1986 Schwinn High Sierra, 2000ish Colian (Colin Laing), 2011 Dick Chafe, 2013 Velo Orange Pass Hunter
Agree. Components *may* need to be replaced. But the chain coming off doesn't indicate that. I've never seen a chain do like that just because it's worn out. The problem is the chain-stop. Then maybe more too but there's no clear indication of that.
ride for a change
Bikes: Surly Cross-check & Moonlander, Pivot Mach 429, Ted Wojcik Sof-Trac, Ridley Orion. Santa Cruz Stigmata
All due respect, It's great that you have a decent relationship with your LBS, that's key. But knowledge is power. Enjoyable, reliable, and safe commuting is greatly enhanced by a modicum of basic mechanical knowledge. It's a worthy investment of your time.
Quoted: 2495 Post(s)
Liked 738 Times
H
DancesWithSUVs
Quoted: 7 Post(s)
He's not much of a mechanic,then. Take two sticks,or two leaves,or two pieces of paper,or whatever you find laying around. Using one object,push the rear derailleur forward to slack the chain. Using the second object,lift the chain up and maneuver it onto the closest ring or cog. Then just lift the rear of the bike and spin the cranks to reseat the chain. Nothing get son your hands.
In the future,carry a set of latex/non-latex gloves to keep your hands clean. I also carry a little 1oz squirt bottle from REI that I filled with GoJo hand cleaner and wrapped with paper towels.
C'dale BBU('05 and '09)/Super Six/Hooligan8and 3,Kona Dew Deluxe,Novara Buzz/Safari,Surly Big Dummy,Marin Pt Reyes,Giant Defy 1,Schwinn DBX SuperSport,Dahon Speed Pro TT,Brompton S6L/S2E-X
Bikes: All City Macho Man frameset with a 1x10 Shimano Zee back end and Truvative Descendant cranks 38 tooth front. Riser bar, big fat Schwalbe Marathon Supreme 700x50c tyres, Paul Motolites, and some other bits.
Derailer limit screw...
Quoted: 77 Post(s)
Liked 19 Times
You've got a GREAT LBS!
Now learn how to do things for yourself. Take a class on 'how' to fix your bike.
Bikes: 2015 Kona Rove AL, 2016 Giant Escape 2, 1995 Giant attraction SS,
I agree with the last poster. It does pay for itself to learn how to do and fix everything on your bike. It's not that difficult. It might also be a good idea to haul some tools with you.
This great experience with a LBS on the phone got me thinking: how about some bike repair hotlines 24/7 just giving oral directions to newbies if that could solve a problem for someone on the road, with some toll charge or subscription?
I have taken a basic maintainance and flat fix course at the bike shop. I tend to panic right away, especially where I was riding that day. It was a different way home and also very rural so no way for help had it been more serious.
What I did learn that day was that when the pedals don't turn look at the chain much closer just because it is not slack does not mean it is not off the cogs.
Thank-you for all the great ideas. I do have latex gloves in my bag but due to panic in the moment of trying to get my bike back to riding form, forget that I carry them.
Dirtylocks
Mountain Biking
28
02-13-13 10:03 PM
