2005 Spec'd Sirrus Tire Width
Toyota Racing Dev.
Bikes: 2004 Kona Hoss Dee-Lux
Would it be possible to run a 35C or maybe even a 38C tire on this frame? Is there a way that I can check this myself without having to ask others?
2-Cyl, 1/2 HP @ 90 RPM
Bikes: 04' Specialized Hardrock Sport, 03' Giant OCR2 (SOLD!), 04' Litespeed Firenze, 04' Giant OCR Touring, 07' Specialized Langster Comp
I don't know if the sirrus has room in the front fork for 38's, last time I checked at the LBS, the 04' sirrus disc was pretty tight.
Toyota Racing Dev.
looks like I will be having to take a visit to the LBS
I thought u were having a road bike built up for you. Why the sudden interest in a flat bar bike?
Toyota Racing Dev.
Whoa.. how much $$ did you lose in that deal?
Why would you go with the sirrus and not the allez? The difference is only like 150 bucks or so. I can't believe the shop didn't try to do something else to accomodate you.
One Tough Cookie.
Bikes: Too many and not ENOUGH!
The Specialized "Sirrus" WILL NOT accomodate a tire wider than a 30/32! A "small" 30/32 at that!!!
I have Bontrager "Jones CX"'s on my Sirrus disc now--they JUST fit...WITHOUT the front clip-on fender (which I had to remove 'cause the tire rubbed too much! ).
The "widest" tire the Sirrus is designed to handle, comfortably, is a "28".
Sorry!!
Sorry!!
A bad day on the bike is better than a good day at work!!
My discussion board, another resource for the "utility" and commuter cyclist: "Two Wheeled Commuter: The Everyday Cyclist"
Toyota Racing Dev.
Probably not... you'll probably need something like a cyclocross bike or touring bike.
If I were you, and no offense to your weight, and several hundred pounds, I'll probably need a 36 spoke (at least) rim with 35-38 tires and disc brakes if you intend on being able to stop a lot w/o heating up the rims or anything.
Have I told you how much I'm in love with my giant ocr touring?
Toyota Racing Dev.
Toyota Racing Dev.
god that makes me cry...that monk was almost perfect...36H rhynolite to XT Disc hubs (700c), Avid BB Road Brakes... *cries*
I wonder why you didn't just get the OCR touring to begin with.
It's a road bike, avid bb disc brakes, 36H front and rear deore disc hubs, extra spoke holder in case you break any on the way...
Toyota Racing Dev.
Originally Posted by PWRDbyTRD
how big of a tire can fit in it
Measuring it, the distance for front and back is 2.125 inches. So you can go as wide as that.
Hell if you want, as long as the rotor's the same size and the cassette's the same speed, take the wheels off your mountain bike and mount it on the ocr touring and go mtb'ing with it.
https://www.giant-bicycle.com/us/030....04&model=10807
It's last year's model though. How about a cannondale cyclocross bike?
https://www.cannondale.com/bikes/05/cusa/model-5XR1.html
The giant if you can find it onsale as last year's model you can get it for $1100 or so.
The cannondale you can get for $1600 or so.
I drink your MILKSHAKE
Bikes: 2003 Specialized Rockhopper FSR Comp, 1999 Specialized Hardrock Comp FS, 1971 Schwinn Varsity
OMG that cannondale is frackin' sexy
https://www.konaworld.com/shopping_ca...4&parentid=182
I know right, it's everything you're hoping for in life lol.
I would've gotten that if only it weren't for the $700 diff. between that and the ocr touring at my lbs.
I think he wanted discs in case he's on a long descent and the rims heat up too much or if he hits a bump and warps his wheel, the brakes still work. Honestly, at his weight, i'd recommend discs too.
I should get a commission from cannondale for selling this.
Toyota Racing Dev.
crack n fail.........hahahahahah actually the avid shorty 4's or whatever seem to do pretty good on me...I tried em out on the bianchi axis. I'm still sorting my options over *sighs* The JTS is another good option...I just have to keep looking and looking til I'm deadset
