Buy or (re)build?
What, me worry?
Bikes: Corratec / Jamis
Quoted: 5 Post(s)
Buy or (re)build?
This is probably going to be a long post, so if you're interested in the subject, please bear with me!
It's been a couple of years since I've been bitten by the bicycle touring bug, and since then, I managed to purchase and transform a European trekking bike into a credit-card/week-end tourer which can handle my weight (275 lbs) plus around 25 lbs of items. A European trekking bike basically consists of a robust (heavy) aluminum frame with mtb gearing (usually mid to low range to tackle hills) fully outfitted with mudguards, dyno-hub lighting and a heavy front suspension fork with 50-60mm of travel.
The bike itself weighs a ton, but my most pressing concern is the very harsh ride which paired with tires which are inflated to max pressure (because of my weight) makes even the smoothest of road surfaces feel like a off-road experience.
And here's my question to all you seasoned tourers: Is it worth buying a outright touring bike (which is very expensive and only on special order where I live) or should I take apart my current bike which has decent quality/low mileage parts and add them to a metal touring frame? (Below is a list of components with their mileage)
I would really appreciate your input and any recommendations, especially from people which are close to my weight group, or are heavy tourers.
Equipment list
Wheels & Tires (around 500 miles)
Here's a picture of the bike with older tires and trekking handlebars which have been replaced
Equipment list
- Custom built Mavic A719 rims with 36 DT-Swiss Competition spokes and Shimano Deore rear hub and Shimano 3N-30 front Dyno-hub.
- Schwalbe Marathon Green-Guard tires 622-37 with Continental touring inner-tubes
- Shimano Deore Hollowtech II (42-32-26) front crank with HG-71 chain and Shimano rear cassette with 32 tooth low gear.
- Shimano Deore v-brakes with replaceable brake inserts
- Shimano 3x8 integrated gear and brake levers
- Shimano Deore rear 8-speed derailleur and Alivio front derailleur
- B&M CyoT Senso front light and B&M Selectra Plus rear light, both with standlight functions.
- SKS Chromoplastic fenders with built-in electrical wiring for the lights
- Race-Face Ride handlebars
- ZZYZX Rear rack which can carry up to 55lbs of gear
first off, how much more stuff, if any, do you wanna carry?
maybe you could try repositioning the load?
with your weight, maybe forget the rear panniers. put some of the
load in front bags, and the rest in a trailer.
if my calculations are correct, you have 700x35 tires. what's the
maximum width you can fit in that frame? try some fatter tires....
.....700x40 or even 700x44.
Bikes: Specialized Tarmac Expert, 2002 TREK 520, Schwinn Mesa WINTER BIKE, Huffy Rock Creek 29er, 1970s-era Ross ten speed. All my bikes are highly modified(except the Tarmac) yet functional, and generally look beat to ****. .
Quoted: 68 Post(s)
Liked 88 Times
I'm not believing that a steel frame would make that much difference. There's a whole lot of other things I'd try before buying a whole new bike, and possibly being disappointed.
Larger tires, a different saddle, possibly a suspension seatpost, fork spring modification, are a few things that come to mind.
I read a statement made by a RAAM rider once, who claimed that with identical geometry and components, he probably wouldn't be able to tell the difference between a steel and aluminum frame on a dark night.
What, me worry?
Quoted: 5 Post(s)
I've also tried moving the weight forward by putting the panniers on the front fork (as stated above), but that just made the bike very unstable, and the ride even harsher and much heavier as well. Another option was/is to swap out the front suspension fork for a rigid steel one, and I have found one that "almost" fits (slightly shorter), but I'm a bit hesitant in going ahead and swapping it out since I would also need to change stems and all adjoining hardware and I still won't be sure if the end resulting geometry would provide a stable softer ride.
Telly, Most, if not all of your parts will probably transfer to another frame set. You'll need to know if wheel size and rear drop out spacing is compatible.
Any good touring/trekking frame regardless of construction material is going to be stiff, it's just required for hauling and controlling a load. I don't know that there will be a difference worth the expense of a different frame set. I suggest larger tires. This can help, in particular with higher frequency vibration.
Brad
Brad
anyway, before changing frame or components........how does the bike ride unloaded (unladened?)?
is the naked bike comfortable and cruisey enough that you can do 50 miles or 100 miles or whatever
distance? is it the added weight causing problems? or is it increased distance?
Telly, I was multi tasking on my reply when your post 5 arrived. The bike shouldn't be unstable and a rigid fork that's too short will only amplify the stability problem. My guess is that the suspension fork isn't sprung for your weight. Can the fork's travel be locked into one position? Are there higher rated springs or are there preload shims available (if no preload adjustment available)? Preload shims can be made from inexpensive PVC pipe if need be.
Brad
Brad
What, me worry?
Quoted: 5 Post(s)
I did a short ride this morning (around 15-20 miles) with the thinner 700x35 tires and one near empty small pannier which had a couple of light personal items and the ride was harsh and uncomfortable. The suspension, either totally locked-out or set somewhere near 50% softness did little in soaking up road vibration and compared to my daily commuter (a Jamis Commuter 1 with rigid fork), it felt like riding a tractor! The thicker tires did help, but not by much and the difference in rolling resistance compared to the 700x35 is a deal breaker.
I'd bet that your bike should ride about as well as a touring bike WRT the harsh ride you complain of. I suspect that what you really need is to harden up a bit. Also the very upright posture you apparently use puts all of your weight on the seat and lets the road shock and vibration go right up your spine. A more bent forward posture might help. I find that for me having the bars well below the saddle helps in that regard. You may try lowering the bars a bit. Go a little at a time and put in plenty of saddle time at each position so your body adapts. Your legs should carry most of your weight rather than have it all bearing down on your butt. This requires some physical conditioning to maximize core strength.
Also, in addition to tire width the suppleness of the sidewalls of your tires is a factor. Maximum cushion would be big fat tires with supple sidewalls and thin tubes. The material of the frame of the bike will be a very small factor when compared to tire choice.
Edit:
I just read your last post... Have you considered that you Jamis might be a better bike to tour on? The flat bars and upright posture wouldn't cut it for me, but you have that on the other bike as well.
Edit:
What, me worry?
Quoted: 5 Post(s)
Same thing just happened to me! lol
The bike's suspension (RST Neon TnL 50mm) does have a soft-to-lockout adjustment on one fork, and a rebound on the other and when locked-out the fork becomes rigid and I've had it checked at the local dealership and was told that it came with the highest rated spring available and was in good condition.
As you said in a previous post, it's the road vibration (higher frequencies) that makes it a harsh ride, and it's natural instability which has me fighting to keep in steady, especially at relatively low speeds. Oh and before anyone asks, the bike is 100% straight with no crashes and I've ridden a similar bike with the same suspension which handled exactly the same as mine; with the exception that the owner placed a stabilizer after my ride and has stated that it helped overcome the instability.
Brad
Brad
What, me worry?
Quoted: 5 Post(s)
Edit:
Edit:
Just so that you don't misunderstand my problem; I don't mind riding long distances and uphills, etc... but unlike other bikes I've ridden, including the Jamis which would be a great touring bike *if* it didn't have a Nexus 3-speed without provisions for derailleurs, etc), my current tourer's harsh ride tires me out, and it becomes worse when loaded, especially if the load is on the front fork.
Edit: BTW, I goofed on ordering the Marathons since I wanted 700x38's and the German site only had ERTO sizing which was 622x37.
Quoted: 68 Post(s)
Liked 88 Times
I've swapped out the butterfly bars for straight bars and have tried them at various heights (now set exactly the same as the saddle) with what you mentioned in mind, since I too prefer riding at a lower stance than upright. Unfortunately there was little to no difference in ride quality.
Bikes: Nothing amazing... cheap old 21 speed mtb
Tried a better suspension fork? I run a rockshox tora. Down to 85kg now but when I first built my tourer I was closer to 100kg. Stable even loaded down and good for 300km plus non stop.
Thats my girl. Wouldn't swap her for anything.
What, me worry?
Quoted: 5 Post(s)
Just for comparison sake, my daily commuter (Jamis Commuter 1 with Nexus 3-speed) has 700x32 tires at max pressure (90-100 psi), and is all aluminum with a rigid aluminum fork, and the ride quality cannot compare to the tourer since there is little or no road vibration felt; even with 20 lbs of stuff loaded onto rear panniers.
so maybe try a suspension corrected rigid steel fork.
nashbar has a 700c fork with some rake:
Nashbar Disc/V-Brake Compatible Cyclocross/Touring/Hybrid Bike Fork - Road Bike Forks
and aren't 29er's just a fancy name for 700c?
https://www.ebay.com/itm/eXotic-Rigid...item2ecddf7191
What, me worry?
Quoted: 5 Post(s)
I opened this thread *before* I started purchasing more parts since my small apartment now looks like a bike shop, and I would prefer to spend a bit more on purchasing something which is specifically built for what I need (frame -or- bike) than trying out combinations of parts which might or might-not work.
What, me worry?
Quoted: 5 Post(s)
something like this (but this one's 26")
On-One CroMo 26er MTB Fork V-Brake & Disc | On - One
or a 700c fork with some rake:
Found one locally, and have it on hold, but as stated above in a previous post, being shorter it would probably make the bike more unstable that it already is.
Thanks. Built her from scratch myself with just the parts I wanted. Deore 27 speed, 80-120mm locjable, height adustable on the fly fork, gps, 1200 lumens of light, slx hubs, deore hydrolic discs. Based on a fuji offroad frame I got for 60 bucks.
Cost a bundle to build even using second hand parts but I've done 30000km on her and she is still going strong.
I'd just short circuit all the doubt and discussion and order something like a Thorn Club Tour frame. We are very happy with ours to the point where they have become our preferred bike for longer distances at the moment. Stable when loaded, with all the braze-ons you would need and a good quality steel frame at a good price.
What, me worry?
Quoted: 5 Post(s)
SJS has a sale on the Club Tour frame, but the specs don't state if it's for 700c wheels *and* if the bottom bracket design can accept my Hollowtech II crankset since it's concentric.
I'm at work, but will look into some of their frames; I'm pretty sure they must have something for 700c wheels with standard BB and derailleurs.
