27" Wheels on a Steel Frame to a Rad Fixed Gear?
Where the hell did you find a girlfriend who suggests converting to a front disk brake to mitigate the brake problem. That's totally what I would do if you need a new wheel.
either way, marry her.
Grumpy Old Bugga
Bikes: Hillbrick, Malvern Star Oppy S2, Europa (R.I.P.)
Quoted: 370 Post(s)
Liked 8 Times
That's actually fairly poor thinking. The modern dual pivot brakes are much, much better than any previous offering and Tektro make very good brakes at very good prices that are readily available. Even without the change in wheel size, you are better off changing to dual pivot brakes. That's not saying the rest of your thinking is wrong, I'm just commenting on the brake issue.
Quoted: 230 Post(s)
Liked 18 Times
I have to wonder how much of that improvement is just feel. Modern brake setups feel firm but I honestly can't say I've ever had trouble with a single pivot weinmann 500.
Bikes: 2015 All-City Spacehorse, 2014 Specialized Allez Race, Mid 80s Takara Acknowledge Fixed Gear
She suggested it to make a really unique and interesting fixed gear, I just didn't want to deal with it now. Maybe in the future when my funds increase, Ill slip a disc brake on the front and do the 700c switch over.
The results:
I've since wrapped the handlebars with white cork tape
Zip tie Karen
Quoted: 1465 Post(s)
Liked 1,542 Times
I like the crankset.
Glad you didn't repaint the frame.
Why not both brake levers? At a minimum, the available hand positions and grip would be symmetric.
The disc brake is not a good idea. You'll need to replace/buy the front wheel (hub and rotor), the fork (meant for disc loading and mounting), the brake caliper (let's say mechanical caliper), and the brake lever (in all likelihood, but I can't confirm from experience between road levers and mechanical disc levers). For what, exactly?
thehammerdog
31
08-10-16 06:41 PM
bairnn
Bicycle Mechanics
42
10-31-10 02:11 AM
