Chainring tooth profiling question - Specialites TA Alize
Old 04-26-14, 03:05 PM
Bikes: 8
Quoted: 7607 Post(s)
Bz on would be fine with a 52~3t road chainring , which it was probably built to use.
fietsbob is offline
Old 04-28-14, 02:35 PM
Clipless in Coeur d'Alene
twocicle's Avatar
Bikes: Tandems: Calfee Dragonfly S&S, Ventana ECDM mtb; Singles: Specialized Tarmac SL4 S-Works, Specialized Stumpjumper Pro, etal.
Quoted: 164 Post(s)
Liked 22 Times in 15 Posts
^^^ As noted, that picture is from the Bicycle Quarterly article, not my install. I always mount my FD closer to the big ring, maybe 2-3mm gap max, so in effect I agree that the FD position in the photo is not optimal.
I've been looking at this a bit more and think my shifting looks more similar to this next photo (also from article linked above). My chain has more skew to the outside I believe because currently there are 1.2mm worth of spacers between the granny & big ring (used so that the chain completely clears the 130bcd chainring bolts). I believe this extra spacing exacerbates the issue by causing even more diagonal chain skew than in the picture below.:
On my 48/30 chainrings, the chain links do appear to be at the correct meshing points where you would expect it to fall between the ring teeth. However when the more extreme diagonal chain path is present, a newer chain cannot twist back enough to correctly settle between the teeth, hence it is riding on the tops of the teeth, twisted over.
I'm going to experiment further with reducing the granny spacers to .6mm and perhaps some other ring types, sizes and combos.
twocicle is offline
mountaincoffee
Bicycle Mechanics
16
12-31-17 05:50 PM
jwizard
Bicycle Mechanics
3
08-11-14 08:12 AM
TallRider
Bicycle Mechanics
17
02-05-14 12:08 AM
rbautch
Bicycle Mechanics
3
10-10-10 05:03 PM
eacolin
Bicycle Mechanics
15
03-02-10 12:26 PM
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
