That's what I was afraid of
Bikes: 2021 Trek Checkpoint SL (GRX Di2), 2020 Domane SLR 9 (very green), 2016 Trek Emonda SL, 2009 Bianchi 928, 1972 Atala Record Pro
Quoted: 85 Post(s)
Liked 143 Times
Went out yesterday for the season's first hard day of climbing, about 5000 ft. over 50 miles, including a sustained 3500 ft. climb over 9 miles. During the ride, the pain was pretty much confined to my bottom side, but two hours after it ended, everything hurt.
Ordinarily, I wouldn't complain at all, but I am well north of 2500 miles year to date including a ton of brutal trainer time. Most of it has been in 20 to 25 mile, pretty intense bursts though. The translation to longer distances just does not seem to be there. Crap.
You know what to do about it -- start increasing the distance once or twice per week! 100 ft/mile is sort of the gold standard for hard rides; so I think you did pretty well.
Seat Sniffer
Quoted: 945 Post(s)
Liked 1,986 Times
5000 feet in 50 miles is a healthy dose of climbing. That 100 ft/mile standard is so pervasive in the rides we do, I've stopped really caring whether I have an altimeter or not. Unless we go out of our way to maximize the climbing (repeats, for example), it almost always comes out pretty close to that.
Quoted: 14 Post(s)
Liked 13 Times
Yeah. I find shorter high intensity training through winter helps strength, aerobic capacity and all that, but I still need to adapt to the longer ride times and distances once spring arrives.
www.ocrebels.com
Bikes: Several bikes, Road, Mountain, Commute, etc.
Quoted: 83 Post(s)
Liked 5 Times
And here I was thinking that the Devil Mountain Double (last Saturday) had a lot of climbing with 20,000 feet of altitude gain in 200 miles . . . but really, that's the same ratio. Yikes!
Rick / OCRR
Rick / OCRR
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4338 Post(s)
Liked 2,980 Times
Quoted: 85 Post(s)
Liked 143 Times
Oops, went back and manually recalculated the big climb. It was only 2800 over 9, not 3500. Must have posted while I was still sore and wanted it to be more.
The advice received still holds though, and is appreciated. I had kidded myself into thinking that if I worked hard enough now, tomorrow would be a piece of cake. I keep relearning the lesson that nothing worthwhile is a piece of cake, it's just worthwhile.
Semper Fi
Quoted: 1172 Post(s)
Liked 358 Times
Heck, with all you have overcome in your life, a little bit of slack time isn't so serious a problem this early in the season. Even though I was able to ride as I wanted to this harsh winter, I still feel like I am just starting over in building some climbing legs and sufficient hard pushes when I am out. Granted I am a slug at best so take my advice with a salt block. Best of luck with the rides and the start of the season for you.
Bill
Bill
Semper Fi, USMC, 1975-1977
Calder Benson
General Cycling Discussion
60
10-13-15 05:25 PM
