Tapping Bottle Cage mount
Bikes: Kickbike, Raleigh M60, Electra Cruiser, Marin Nail Trail, Schwinn Hinge
Have any of you tried taping the frame to add a bottle cage? I've read mostly MTB folks saying not to. I'm trying to avoid zip ties or those clamp mounts. If it's not safe I'll just go another route. The LBS says I'd have to get it done at a machine shop but I'm confident I could do it.
Bikes: 1983 Fuji Touring Series IV, Masi Volumetrica 3VC
Ultimately, it depends upon the bike, and where you plan to drill. You haven't provided that information. So I'll say there is a 95% probability that the answer is NO, unless your frame is carbon, in which case the answer is 100% NO.
Nearly every bike that has bottle cage mounts uses reinforced bosses brazed, welded or molded into the frame. This provides reinforcement to compensate for the increased stress around the holes. And it provides enough material thickness to have enough threads to avoid stripping them when tightening the cage bolts. If you just drill and tap into the frame, there is a good chance the threads won't hold, and the possibility that your frame will develop fatigue cracks at some point, especially if it is aluminum or titanium.
It's steel and I was thinking about tapping in the typical area on the seat tube.
I reused an old reflector mount but the bottle shakes a lot.
If you drill a bigger hole , then you can expand a Riv-Nut in the hole, its threaded . (a common way of doing such fittings in Aluminum)
+ there are several ways to temporarily strap on a bottle cage, two Fish uses a velcro strap and a half round rubber block.
If it's steel, and you use Rivnuts or similar threaded fasteners, you've improved your chances of success. Not having threads cut directly into the frame reduces the stress concentration considerably, though the enlarged hole offsets that to some degree. I'm no expert on the stress distribution in a bicycle frame, but I'd imagine the seat tube is a better place to experiment than the down tube. Two things to watch out for when using Rivnuts: choose the same material for the Rivnut as the frame to avoid galvanic corrosion; and avoid drilling the hole oversize to avoid having the Rivnut work loose and spin in the hole.
EDIT: I watched the video. The use of JB Weld Epoxy on the Rivnut is probably good insurance to keep moisture out of the frame and reduce the risk of the insert working loose. Thanks for posting that.
Pretty cool thanks for the video!
Calamari Marionette Ph.D
I'm sure the Riv Nuts would work, but........ something in my head says that stressed bike frame tubes aint the place for drilling and crimping. I could be wrong, and it could last safely for years, but um.....
Membership Not Required
Bikes: Giant Excursion, Raleigh Sports, Raleigh R.S.W. Compact, Motobecane? and about 20 more! OMG
Quoted: 70 Post(s)
Liked 15 Times
Riv nuts... I did one bike about 20 years ago and it is still chugging along. Steel frame.
Aaron
Aaron
Webshots is bailing out, if you find any of my posts with corrupt picture files and want to see them corrected please let me know. :(
ISO: A late 1980's Giant Iguana MTB frameset (or complete bike) 23" Red with yellow graphics.
"Cycling should be a way of life, not a hobby.
RIDE, YOU FOOL, RIDE!"_Nicodemus
"Steel: nearly a thousand years of metallurgical development
Aluminum: barely a hundred
Which one would you rather have under your butt at 30mph?"_krazygluon
the crimping, shortening, in length is making it do an expansion in diameter.. pushes out into the hole.
So is the rivnut threaded?
Yes. Rivnuts work somewhat like pop rivets. The installation tool has a threaded mandrel that the Rivnut is threaded onto. Once the Rivnut is inserted and compressed, the part of the Rivnut on the "back" side of the hole flares to lock it in place. Then, the mandrel is unthreaded from the installed Rivnut. Unlike pop rivets, the OD of the Rivnut typically does not expand to fill the hole. If it did, the threaded ID would also grow, which would make for very loose threads. This is why the hole needs to be drilled accurately. In a former career, I used quite a lot of Rivnuts on steel sheetmetal work. The best we could achieve was about a 90% success rate of having them installed without spinning in the hole. Odds on a round-section bike tube may be higher, as the shape of the tube might act as a key to keep them from working loose. The epoxy idea might help there, as well.
Quoted: 5781 Post(s)
Liked 2,576 Times
Builders don't have any magic formulas,or secret methods for drilling holes, and you can do the same as them --- if you do it right.
FB
Chain-L site
FB
Chain-L site
Quoted: 70 Post(s)
Liked 15 Times
Yes...
I also like the idea of setting them in epoxy (JB Weld). I did not do that with mine, but they grabbed hold and held tight. I don't own that bike any more but I still see it occasionally.
Aaron
Aaron
Liked 2,576 Times
If the application ever comes up again, coat the back of the sheet stock with coarse lapping compound. When the riv-nut begins to compress it presses the grit into the rim and sheet stock, forming a mechanical lock which will keep it from spinning.
FB
Chain-L site
FB
Chain-L site
Quoted: 346 Post(s)
Liked 396 Times
HERE IS A GREAT SOLUTION THAT INVOLVES NO DRILLING AND THIS BOTTLE CAGE WILL REMAIN SECURE AS LONG AS YOU use "Super Weatherstripping Adhesive" (comes in small tube, available at auto parts stores such as Auto Zone, O'Reilly's, NAPA, Advance, and others.....specific brand names will be 3M -or- Permatex..., possibly others....YOU DEFINITELY DO WANT THE PRODUCT THAT SPECIFICALLY STATES "super weatherstripping adhesive" !! )
This is the Specific Bottle Cage that you want to buy, it is inexpensive and Walmart & Target have been known to carry it. I have installed this exact particular Zefal pulse UNIVERSAL Mount BOTTLE CAGE With VELCRO STRAP upc code 7 68661 55039 4
on to more than twenty bicycles using "SUPER WEATHERSTRIPPING ADHESIVE" applied to the thick rubber universal mounting block that is part of this Zefal cage.
It is my opinion that if you simply try to use and install this Zefal cage with only the velcro straps tightened & WITHOUT ANY SUPER WEATHERSTRIP ADHESIVE, you will get generally poor results as the cage will move & slide under most riding conditions!!
IF YOU APPLY "super weatherstripping adhesive" before you attach it to the bike and then pull the velcro straps tight......the cage mount WILL NOT MOVE!
You can also choose if you wish to use a different cage than the black zefal one that is supplied. On several KOOL LEMON colored early seventies Women's step through COLLEGIATES, I obtained matching yellow colored cages frrom various web sources, and the appearance result was fantastic. This Zefal product has two 3mm Allen key headed screws that you can unscrew to remove the supplied black cage, and then probably swap many other cages.
The thick rubber universal mounting block is very well made and looks great when installed and the excess velcro strap is cut down such that only enough remains to secure it without any excess overhang. NOW ON THIS zefal PRODUCT'S CARBOARD PACKAGING it says "FITS MOST BIKE FRAMES".............my guess is that it might do fine or okay as supplied WITHOUT "super weatherstripping adhesive" on possibly bicycles with fat diameter tubing, but it is my experience that for classic old steel bikes with narrower diameter tubing, YOU WILL DEFINITELY NEED TO BUY "super weather adhesive" and APPLY THAT TO THE RUBBER UNIVERSAL MOUNTING BLOCK before cinching tight the velcro straps.
You can probably find this Zefal pulse Universal Mount Bottle Cage with Velcro Strap on Amazon too. I bought all of the ones that I installed from my local Target & Walmart stores. Three different people asked me recently about what & how I attached the bottle cages to some of my vintage bicycles. I thought I would mention this solution again here on bikeforums. You do need the small tube of "super weatherstripping adhesive" from one of your local auto parts stores!!!
Quoted: 346 Post(s)
Liked 396 Times
https://www.walmart.com/ip/Zefal-Pul...lack/239504228
https://www.3m.com/3M/en_US/p/d/b40069430/
Bottles & Cages ? Zéfal USA
********* SEE POST #18 ***********
Likes For Vintage Schwinn:
DaveQ24
Fifty Plus (50+)
16
11-04-17 02:21 AM
courtesi
Bicycle Mechanics
22
10-29-10 12:43 AM
TimmyBoston
General Cycling Discussion
13
05-01-10 07:36 PM
