Can you help me located a rack for a 2013 Cannondale Bad Girl 3?
King of Typos
Bikes: Trek 7.1 FX
Can you help me locate some racks that are compatible with a Cannondale Badgirl 3?
Any links would be appreciated.
Looks like you're gonna have to try the aftermarket, since the BadGirl 3 doesn't have rack or fender mounts...
Try these:
Racks
www.topeak.com/products/racks
Try these:
Racks
Thunder Whisperer
Bikes: '06 Kona Smoke
Quoted: 275 Post(s)
Liked 6 Times
Weird looking geo (and the one piece handlebar and stem? seriously??), but it looks like it doesn't have the upper points (that I could see), and I couldn't see one lower, either- but the disc brake mounted inside the rear triangle will help get a rack on there.
If if has the lower holes and not the upper, you can get a seat post binder that has the eyelets and mount just about any rack that way.
Community guidelines
Try your neighborhood bike shop? they can test fit something over your bike..
I see from googling pictures It has seat stay fittings for the upper front.
and back by the rear axle , the bonus of doing your shopping there ..
is they will help you and perhaps even install it there.
DancesWithSUVs
Quoted: 7 Post(s)
Yeah,you're def going to need to do some test fitting. At least the brake caliper is out of the way on the chainstay so a regular rack should fit.
Found this with Google:
So it shouldn't be a big issue as long as the rack is tall enough to clear the wheel and the stays can reach the upper mounts.
C'dale BBU('05 and '09)/Super Six/Hooligan8and 3,Kona Dew Deluxe,Novara Buzz/Safari,Surly Big Dummy,Marin Pt Reyes,Giant Defy 1,Schwinn DBX SuperSport,Dahon Speed Pro TT,Brompton S6L/S2E-X
badger_biker
Touring
6
02-07-13 09:03 AM
ahultin
Tandem Cycling
12
12-23-12 04:53 PM
