Which touring bike frame size is appropriate for me?
Hi. I planing to buy touring bike(Surly Long Haul Trucker).
I'm 5,5(168cm) tall and 130lb(59kg) also my leg length is 30inch(76cm).
I have no idea which bike frame size is appropriate for me.
50cm? 52cm? 54cm?
Give me some advise guys..
Thank you.
50cm? 52cm? 54cm?
Thank you.
Bikes: Jamis Endura Sport Femme, Raleigh Sojourn, Comotion Pangea w/Rolhoff
Hi! I'd really recommend getting fitted (or at least measured by someone who knows what they're doing). That being said, your body can adjust to just about anything, so it's really personal preference. I just got fitted yesterday for a bike, and I'm a similar size. (5'6", 31" inseam) I'm going with the 52. One thing to consider is "standover height". You want to comfortably be able to stand over the bar without having to lean the bike over (makes a difference especially when you're loaded down.) Hope that helps!
Quoted: 18320 Post(s)
Liked 15,299 Times
Standover height is not the only important measurement. Many believe that top tube length is actually more important, although you obviously need to be able to straddle the bike comfortably. The LHT has a longer than normal top tube. Keep that in mind.
As noted you should get fitted. The geometry for each LHT frame size in shown on Surly's web site.
52 should be spot on but dont take my word for it. i'm the same size as you i hada thorn sherpa size 51s i now have a thorn audax 52cm my 28 year old Raleigh is 21.5ins they all fit me perfect.
Bikes: Workcycles FR8, 2016 Jamis Coda Comp, 2008 Surly Long Haul Trucker
Liked 6 Times
I know there was once a surly size google group which helped me choose a size. For reference I'm 5'9 and ride the 54cm size with 26 inch wheels. I did have to put on a shorter stem than what came with the bike.
Quoted: 1182 Post(s)
Liked 830 Times
My daughter is 5" 5" and rides a 50 cm LHT. It fits her pretty nice. She has long legs and shorter torso. However, test riding is the only way you'll know for sure.
I completely agree. I ignore stand over height and seat tube length when sizing my bikes. I look at horizontal top tube length. I'm 5'10" with a 31" PBH and I if I get a bike with an equivalent horizontal top tube length between 55 and 56 cm I know I will be comfortable.
