Xtr
Wood Licker
Bikes: Trek Fuel EX 8 27.5 +, 2002 Transition Dirtbag, Kona Roast 2002
X.7, I personally found much crisper than xt. I have never used xtr more then on a demo bike and marvelling at the cost (I get the same look as when I look at x.0) I am switching everything to sram now. Shimano doesn't really compare at this point (I really hate rapid rise )
I cant imagine shifting better than the x.7 im running right now. Even through all the mud and snow its seen, after a good cleaning its still running like its NIB
C://dos
C://dos.run
run.dos.run
C://dos
C://dos.run
run.dos.run
Is it because it doesn't shift well or because you haven't gotten used to the reversed trigger pattern?
I have never tried SRAM- sorry zeddybear to be no help in the comparison.
Wood Licker
All things equal (shifting) I just don't like the mindset of rapid rise. It just don't jive man...when I press with my thumb in a panic situation I want pedallling to get easier. If I need to shift a TONNE of gears, going easier works with my mindset. I can never think of a reason to shift a tonne to go into a harder gear, 80% of the time on trails, I get more speed laying of the brake than I would pedalling harder.
Bikes: '04 Specialized Stumpy FSR Pro (Frame and Shock Only)
The funny thing is, I bought the dual-control levers about two months before I changed to RR and I thought they would take a lot of getting used to. One ride into using them however, using them became second nature. With the RR however, it was so counter-intuitive to "pull" on a down-shift that it took months before I was totally used to it. We're so conditioned towards the old system that something new like RR is totally foreign.
DEADBEEF
From: Catching his breath alongside a road near Seattle, WA USA
Bikes: 1999 K2 OzM, 2001 Aegis Aro Svelte
Originally Posted by zeddybear
i currently have a sram x7 on my bike. I have the money, and would it be worth me getting xt or xtr?
1999 K2 OzM
"Be liberal in what you accept, and conservative in what you send." -- Jon Postel, RFC1122
1999 K2 OzM
2001 Aegis Aro Svelte"Be liberal in what you accept, and conservative in what you send." -- Jon Postel, RFC1122
DEADBEEF
1999 K2 OzM
1999 K2 OzM
Don't let it ruin your life. You will end up buying useless things like me.
Toyota Racing Dev.
Bikes: 2004 Kona Hoss Dee-Lux
I have the rapid rise shimano shifters...once I became used to them I'm quite comfortable with them. I haven't used SRAM but I am going to try it at some point just because everyone says it's oh so good
No way! If you want to spend money just for the sake of spending go with X.0. This is what I am running now after XTR and there is no comparison. The only thing that was holdng me back were the X.0 grip shifters until I found out I could use the X.9 triggers. The only thing better than a SRAM drive train is Single Speed!
DJColorado
Bikes: Rockhopper Comp, GT Avalanche, Specialized Sequoia & Crossroads
I have no experience with SRAM except their chains. I have four bikes in the family with different flavors of Shimano MTB components (Alivo through XT). Except for the bike with Alivo components, I could never detect much difference in shifting performance. I regeared one of my MTB's with a new XTR cassette because of a ratio change I wanted, and the improvement in shifting crispness was impressive, definitely the best of the bunch. It was worth the extra $25.
