Attaching Milk Crate to Rear Bike Rack
I have a technical problem for all you mechanically oriented cyclists. I'm looking to use some sort of "quick release" system for solidly attaching a standard milk crate to most standard rear bike racks. Zip ties work great for a permanent a solution, but I'm looking for a technique to be able to quickly attach the crate and then quickly remove it after I am done. We have a "Meals on 2 Wheels" program delivering meals to the elderly. A quick release system would mean our volunteers would not have to permanently modify their bike. Any ideas would be greatly appreciated. Thanks!
Quoted: 5224 Post(s)
Liked 3,581 Times
the only things I think of involve a permanent modification to the bike rack allowing the quick removal and replacement of the milk crate. maybe there are temporary zip ties? the kind that are reusable but still hold tight until you choose to release them?
Quoted: 1572 Post(s)
Liked 643 Times
How about a few small C-clamps?
Most racks have a forward portion which curves or is bent up at the front to keep cargo from sliding forward. Attach a board to the bottom of the crate which will slide into that loop. Then, at the rear, maybe a simple metal bracket with drilled holes which line up just ahead of a rear support, tight to the bottom of the rack, through which an actual quick release could be placed. It wouldn't be a universal solution, applicable for different racks, but if you have a rack in mind or already on the bike, it could work for that.
Alternately, Bontrager racks and I think Topeak as well (probably others) have quick release attachment systems for gear going onto their racks. If you can find a used or junked system like that, you could scavenge the quick release setup and attach it to the bottom of a milk crate.
Bikes: '04 LeMond Buenos Aires, '82 Bianchi Nuova Racing, De Rosa SLX, Bridgestone MB-1, Guerciotti TSX, Torpado Aelle, LeMond Tourmalet 853, Bridgestone Radac
Quoted: 101 Post(s)
Liked 46 Times
It may not the the quickest of quick release, but hose clamps are available in very small sizes and some don't even require tools.
Koehler/EZ hose clamp (EZ20BK) | Hose Clamp | AutoZone.com
Señor Member
Quoted: 649 Post(s)
Liked 292 Times
worm drive hose clamps have
fastened many a milk crate
to many a rack
Quoted: 19 Post(s)
Liked 7 Times
rixen and kaul Carrier Adapter and Coupling Set GTA
Bikes: Bianchi San Mateo and a few others
Quoted: 634 Post(s)
Liked 13 Times
Quoted: 19 Post(s)
Liked 7 Times
Lots of QR fasteners are available to make your own bracket.
Zipties .. there are a bunch of them used to pack every bike for shipping ,
so would be free when you ask the LBS for a few..
QR ? cut them off then use new recycled ones next time .
'standard' milk crates are marked Property of (X) Dairy ..
bill nyecycles
Quoted: 789 Post(s)
Liked 350 Times
Get this:
Topeak MTX explorer Rack
Then one of or both of these:
https://www.topeak.com/products/Basket-Rear
or
i hope all those pics worked.
or
Liked 3,581 Times
re Topeak stuff, wow seems perfect
Bikes: Schwinn Broadway, Specialized Secteur Sport(crashed) Spec. Roubaix Sport, Spec. Crux
Quoted: 179 Post(s)
Liked 169 Times
550 cord and an ability to tie good knots.
Sir Mark, Knight of Sufferlandria
bill nyecycles
Quoted: 789 Post(s)
Liked 350 Times
you want quick release; bam.
you want solid on the rack; bam.
the slide in rail system with the giant clip is super sturdy.
I have the rack, and one of the trunk/fold out pannier bags. Used it for commuting for months. Solid, everyday.
Plus for this, that big crate has wheels, and a extending handle. AND it folds up flat - even while on the bike!!
How is that not perfect?
Disco Infiltrator
Quoted: 3126 Post(s)
Liked 2,105 Times
Here's an idea I just had since we are out perambulating today:
Get a baby car seat which should be easy because they are sort of disposable (no one wants a used one). Cut off all the seat parts and fasten base to rack.
Quoted: 101 Post(s)
Liked 46 Times
Here is a photo of a Bell rack from Walmart on my LeMond. Even with it's downward angle, the trunk bag JUST fits under the seat.
