Bike computer/GPS: what would be best for me?
I'm somewhat "new" to cycling, having just ordered a brand new bike (first bike in 10 years).
One thing I am debating getting is a dedicated bike computer/GPS. Right now my only GPS is a waterproof Garmin 78 which I use for kayaking. I thought about using it for a bike, but it's a bit clunky to use (no touch screen) and the screen size is small. For a kayak, it works perfectly well, but I'm not sure about using it on a bike.
My primary use would be for navigation. As a result, I'm wondering if all of the dedicated bike computer features would be overkill for what I need. I was looking at hiking GPSs that can also double as car GPSs, and think I might get more bang for my buck with one of those.
Is there anything specific about bike-oriented GPSs I might miss if I opted for a different kind of GPS?
Thanks in advance.
Edited to add: I have no smartphone currently. I want a stand alone GPS.
Thanks in advance.
Quoted: 29 Post(s)
Personally, I use a Garmin eTrex 30 (after replacing an eTrex 20 because I wanted to add HRM and cadence sensors/displays). It's not specifically a cycling computer/GPS as it has many hiking/geocaching features also. It's all but waterproof, lightweight, uses AAA batteries and has manageable/upgradable maps. Offline track analysis tools and route planning tools are freely available. You can use Garmin maps or OSM maps, 3rd party topographic overlays and create-your-own maps & overlays (again with freely available tools online).
I haven't found a feature I wanted that this doesn't have. I have used it as a car GPS but the screen is really too small for that when compared to 4" and larger car-GPS's.
YMMV
The bike-specific GPS computers with Navigation are not cheap. Garmin is an obvious one, but the ones with navigation are pretty pricey.
Magellan cyclo modes look pretty interesting - also not cheap but probably better value than Garmin.
If you have a smartphone you could consider using that with a mount as well to see how you like it before investing in a GPS.
Not sure there is an app that does everything you want though...bike computer stats plus navigation. You can get one or the other but a decent app that gives you both..?...might be one out there that gives both and if so I'm sure others will chime in. I will say this though that I already know that the iphones have the better set-up for working with bike computer apps ( when linked to wireless cadence/speed monitors ) although I'm sure the newer android based devices will catch up at some point.
My Garmin 705 does all that I could want. Basic bike computer plus maps plus navigation. While you can usually pick up a used Garmin cheap the better ones still cost. If I were to buy another Garmin I'd likely get an 800 or an 810 but only because they are a little more versatile and since there are newer models, Garmin should of had time to have gotten most of the glitches out of the software ( I would hope ).
All said, there are more and more options and apps becoming available to the smart phone users who want to use their phones for bike "stats" plus navigation functions. There are better mounting options, better apps, more options for Blue tooth and/or ANT+ wireless applications. At this point hard to say which one might be better but in my opinion either way you go you should get something that works well if you shop wisely.
Quoted: 4245 Post(s)
Liked 1,350 Times
If you frequent mountainous areas where a GPS enabled cell phone might not be able to update a map you might be better off with something like a Garmin or Magellan. I should also mention that cell phones can function well for what you want too as long as you have an SD card big enough to store an off-line map ( if needed ).
Quoted: 29 Post(s)
Screen size is something I had not considered with respect to a car-GPS. The two GPSs I have mainly been looking at are the Garmin Oregon 650 and Montana 650. They have 3 inch and 4 inch screens, respectively.
Screen size-wise, I mentioned using it as a car GPS solely for comparison. On-bike, the screen size is more than sufficient for a couple reasons - speed of travel vs distance traveled and I'm closer to the display screen on the bike than when in the car so I can see it better. The amount of detail needed on bike is less for a given period of time/distance traveled than in the car. And I sit farther away from the screen in the car. The Oregon/Montana screens are pretty good screens, both in resolution and size. A 4 inch screen, for me though, would be a bit large on bike. That's just me.
The big difference between having data available while cycling and not having it is you can't use the data if you don't have it. I've cycled too fast and hard in high heat/humidity when I shouldn't have and knowing my HR was going north of where it should (exceeding max HRM data warning) was instrumental in me not suffering a heat injury (I slowed down and sought shade until my HR dropped some). Knowing my cadence has dropped to below 60 reminds me to shift and not blow out my knees (again). That sort of thing. You don't HAVE to use the data - but it's there if you want to use it. And the difference in price between an eTrex 20 and 30 is minor.
Again, just my opinion. I started with a simple cycle computer - speed and distance. I could go back to that... I just don't want to.
YMMV
Added: Just looked at a feature list/performance review for the Garmin 78 you say you already have (sorry, I was unfamiliar with it til now.) Since you already own it, see if you can find a bike mount for it and use it for a couple months to see what it does and doesn't offer in terms of cycling usability. I mean, if you don't want or need HRM, cadence and cycling-specific data, that's fine. Practically any GPS that can show maps, tracks, routes should work for you - IF the screen is sufficiently readable and can be securely mounted. A couple dollars for a mount and a bit of time. And you're already familiar with that specific unit. What have you got to lose?
That's how&why I moved from the eTrex 20 to the 30 - I found I preferred to have 2 data fields not available on the 20 displayed on my GPS screen all the time (cadence and HR). Of course, I had to buy&sync the appropriate sensors for the 30, but the additional cost was worth it to me.
FWIW, The thumb-joystick on the eTrex series is very functional when cycling - whether riding my diamond frame, my recumbent or my Dad's trike.
Added 2: You might want to check out this comparison page.
https://gpstracklog.com/compare/garmi...mparison-chart
24-Speed Machine
Bikes: 2003 Specialized Allez 24-Speed Road Bike
I started with the Blackburn Delphi 5.0, upgrading to the Blackburn Delphi 6.0 for its' altimeter. Then I went to the Garmin Edge 200. It was a downgrade from the Blackburn Delphi 6.0. Then I upgraded to the Garmin Edge 500. Which is the best of all the bike computers I have owned.
A non-issue: get an app that uses off-line maps. There are many of them. If you are using a phone for navigation, I'd strongly suggest doing this even if your preferred navigation program uses on-line maps (it's cheap insurance)....
At this point, any reasonable phone will have 16 GB of memory. That's much more than you need to download maps. You could even do with 8 GB. You don't need an SD card at all....
The 705 (and 605) are still quite usable. You aren't going to get much of an enhancement for navigation with a 800/810.
Good to hear the 705 is comparable to the newer Garmins when navigating. I like the mounting options for the 800-1000 series better though. The 800 ( and up ) series are suppose to be a bit faster at booting and calculating ( so I'm told ). They are also a bit more compact. Personally I'm satisfied with the 705 as I really only need it when I don't have an on-line map. Now if I can find a way to purchase a copy of Opencyclemap of the entire USA preloaded on an SD card for a Motorola Android phone I'll be set. RWGPS will sell you a version of OSM ( pre-loaded SD card ) for a Garmin but I don't know if they will do that for cell phones. Now if these things are interchangeable between devices I really wouldn't know although I'm sure the person more knowledgeable in this area will likely let me know.
So far I've had no problems using on-line maps but sooner or later there is bound to be a problem once I get out into the boonies. BTW, the Locus app is working great for navigating.
Liked 1,350 Times
As I write this I am downloading a map to my phone using the Locus app. Wish I had wifi, it would be much faster. No, you don't need an SD card but it would be a good option if your computer has an SD card reader and you could find a way to download the map to the SC card by using your PC. ( nope I haven't figured that one out yet )
SRAM has a $5 adaptor that converts the 705 mount to the better quarter turn mount (used by the 800 and others). For $20, you can get that adaptor with the "out front" mount (the mount I use).
I use the following to get maps. I like that you can select the exact region you need.
Free worldwide Garmin maps from OpenStreetMap
No, they don't (and probably never will).
There isn't any technical reason you can't use the same map files on all/any Android map. It just doesn't seem that it's that convenient yet. There are a few standard formats but it's a fair amount of work to create the maps in those formats.
If I have the gpx route file, I load it to the phone (as well as to the 800).
I haven't used my phone for active (on the bike) navigation. I have no doubt that Locus (and other apps) work very well.
As navigation apps go Locus is pretty comprehensive. So far I used it successfully on a number of rides without a hitch. I haven't upgraded to the Pro version yet but I plan to when the season ends. I'd do it now but I don't want to take the chance of screwing something up while I have the current version working so well. When it gets cold again I'll do the upgrade.
New to Cycling
Bikes: 2014 Specialized Comp Carbon
I'm new to cycling as well and bought my first bike computer/GPS last week. After lots of research and talking with cycling friends I selected the Garmin Edge 510 with performance bundle. So far after half a dozen rides I'm very impressed. Once finished the Edge 510 automatically uploads your ride info to Garmin Connect via Bluetooth with your smartphone. Otherwise just connect to your PC and Garmin Express will upload the ride. I then upload my ride via USB connected to Strava.com.
With the Edge 510 you can create courses/routes on your PC and then turn by turn directions while riding. However the 510 has no maps, you just see the route on the screen. If you also want maps you need to upgrade to the Edge 810. For my riding that seemed overkill.
The performance bundle came with a cadence/speed sensor along with a heart rate monitor. Both are working flawlessly. The GPS lock on the Edge 510 is fast and very accurate from my experience.
map. At least with the map you can usually tell where you need to be and that is a great help when you're not quite sure what you did wrong )
Quoted: 14 Post(s)
Liked 13 Times
With a 500, you can download a TXC track that will display on the screen along with your position along it. Since there is no map, no roads, trails or points of interest will be displayed, just the meandering track. If you're on it, OK. If your not, you can see your relationship to it will need to figure out how to get back on it. If you get some distance from it, the 500 will alert you with a beep and text message that you are off track.
Another feature of TCX tracks is that the file can contain cues if the website or program used to create enables this. These cues are text messages that pop up near their GPS coordinates and can alert of upcoming turns, the name of the road/train, or anything else.
Units with maps (800, 810, 1000, Touring) will display roads, intersections, points of interests, etc. Like car GPS units they can create routes between points of interest and provide turn-by-turn instructions for these routes, but you have little control over the route it selects. Usually it's best to lay out a route the way you want on your computer (software or website) and download it to your device. Once downloaded to your device, the device matches it up with roads in its map and then provides turn instructions based on its map data.
Bikes: This list got too long: several ‘bents, an urban utility e-bike, and a dahon D7 that my daughter has absconded with.
Quoted: 363 Post(s)
Liked 66 Times
I got an etrex 20, based on recommendations here, a couple of years ago. I am generally happy with t. However, if I were to replace it I would get one of the Garmin touring (probably the plus because I was given a heart rate strap) computers.
I also have a simple GPS that is similar to the Edge 200. To be frank, it doesn't see much use anymore. Even when I know where I am going, I like the map display while riding.
Thanks for all the replies. After reading everything and more research, I decided to buy a very basic bike computer for speed/odometer and take dual650c's advice and try my existing Garmin 78 for navigation. Unfortunately there aren't bike mounts for the Garmin 78 (although it's pretty huge, so I'm not sure it would be ideal on a bike). But I can at least tote it in a pack and use it to track my location and trip when needed.
I'll see how this goes and the revisit getting a dedicated bike GPS in the future...
TimothyH
2
06-22-17 07:32 PM
AngryScientist
Road Cycling
15
12-23-09 02:44 PM
