How to destroy a perfectly good cycling road
Veteran, Pacifist
Quoted: 3876 Post(s)
Liked 4,782 Times
..... tar and gravel it.
as far as you can see in both directions.
Peloton Shelter Dog
Calm down fredly. I've been riding the tar and chip every summer up here for 17 years, on the road bike and my motorcycle. I haven't gone down on it yet.
https://www.cotsiscad.com
pan y agua
Quoted: 1428 Post(s)
Liked 697 Times
it's just a matter of time. Its gets better as pressure and heat compress it. Eventually it becomes a pretty smooth surface to ride on, which is just about the time, they start the process over.
One time on a century we had to do a descent on tar and chip that had just moments before finished. It was that or add 25 miles to the ride. We chose the gravel.
You could get lost and die.
You could hit a tree and die.
Quoted: 26 Post(s)
Liked 17 Times
You can get used to it if you ride on it often but when you are used to mostly smooth tarmac and you get on some it can be a bit of an adjustment. We go over and ride in eastern Washington every year and every once in a while you'll be riding along and look down at your computer and wonder why your speed seems so low and realize they put down fresh chip seal. It makes a big difference on long climbs IMO.
Worst, as mentioned, can be descending when it is fresh. Had a few scary moments this year coming off Washington Pass when I had to move into the shoulder for traffic to end up on loose rocks. I'm a timid descender normally but this made me white knuckle it a bit more than usual.
VFL For Life
Bikes: Velo Volmobile
Quoted: 28444 Post(s)
Liked 1,832 Times
Bikes: Specialized Roubaix Comp, Soma ES
The road has to be in good shape before they can chip seal it. They don't do it to roads that are all busted up. As counties start running low of funds, you'll see this more and more. It's longer lasting than regular pavement.
Demented internet tail wagging imbicile.
Other Worldly Member
Quoted: 194 Post(s)
Liked 136 Times
Chip seal adds ~10 years to the pavement life. Usually done within 5 years (or less) of new overlay. Waste of money on a worn out alligatored and raveled road. The former looks like blocky chunks of asphalt, the latter looks like a rough sand paper surface as the tar has been worn from the gravel.
Make ******* Grate Cheese Again
just another gosling
Quoted: 3873 Post(s)
Liked 1,920 Times
On one county road here that I ride all the time, they finally put on beautiful new blacktop. Wow! Quiet, smooth, relaxing, just wonderful. Then the next week they chip sealed it. They completely chip sealed the North Cascades highway in the pass section while the pavement was still perfect. That was a bummer. But we adapt: wider rims and tires, lower pressure, just get used to the lower speed. Carbon helps a lot. Need a special chip seal grinder bike.
I hear our chip seal up here is nothing compared to Texas chip seal. I guess everything is bigger in Texas, including the chips. Went on a tour in Montana this summer. Saw some Montana chip seal. That stuff was so big, you couldn't even see the rumble strips they cut in it. Sharp, too. Lots of flats.
Bikes: Crumpton SL Crumpton Type 5 Berk on order
As fate has it my favorite route was tarred and chipped sealed today. Super bummer
Quoted: 6556 Post(s)
Liked 58 Times
Super Moderator
Quoted: 1173 Post(s)
Liked 924 Times
CT stuff isn't too bad after a week or so of getting settled. Still is a bummer to have a freshly paved road chip sealed without much time to enjoy it.
Bikes: 2006 Raleigh Cadent 2.0, 2016 Trek Emonda ALR 6, 2015 Propel Advanced SL 2, 2000 K2 Zed SE
Quoted: 115 Post(s)
The roads around my house are getting new chip and seal surfaces this week. Ours "chip" material is all glacied or river pebbles, so at least it's not like riding on broken glass.
Until they clean up the excess you do end up with 3" of the stuff outside the car ruts, but that just makes life a bit more exciting.
Bikes: BH, Cervelo, Cube, Canyon
Quoted: 212 Post(s)
Liked 6 Times
I ride a CX bike now.
Bikes: Nothing amazing... cheap old 21 speed mtb
Back in New Zealand Tar and gravel are the norm. When I came to Korea this smooth road surface thing was a surprise. Tar has issues on the hottest days. It melts and gets sticky.
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 12637 Post(s)
Liked 7,529 Times
Chip seal is great. Get some 28mm tires and embrace it.
There are a couple of roads around here where they were nice enough to leave the paved shoulder alone but usually they do the whole road.
Bikes: A MTB and something else with 2 pedals.
I don't see any prob. But then I don't ride road bikes with bologna skins for tires either. Jmo.
Quoted: 1722 Post(s)
Liked 1,272 Times
I live in Lebanon, CT and chip seal here sucks. And, the idiots here put the chip seal warning sign after you've made the corner on the chip sealed road. So, come around at speed on a bike or motorcycle and you could find your self on the ground looking up at the sign.
Bikes: Focus Arriba, Specialized Roubaix Expert, Bianchi Impulso Allroad
Quoted: 109 Post(s)
Liked 82 Times
Welcome to rural PA roads. Worst is when it's first laid, with all the loose gravel collecting on the sides and center.
Surprised there is not a Chip-Seal Grinder thread.
Lately though a lot of the back roads are getting blacktopped. I think the gas companies are doing it on their routes to the new well builds. They are actually doing a nice job. The state doesn't fix the potholes, they just tar and chip overtop of the potholes. On one road I ride which is a numbered state route, I have to ride on the yellow line because of all the broken up pavement. Eventually they will come and just tar and chip over all the broken pavement and holes and it will still be rough to ride or drive on and get broken up within months. All the roads that are getting blacktopped by the gas companies are smooth as glass.
Still kicking.
Ok, no political statements outside of PnR. Chip and tar isn't all that bad especially when it's done right, you just need to know how to deal with it.
Appreciate the old bikes more than the new.
Bikes: Schwinn Broadway, Specialized Secteur Sport(crashed) Spec. Roubaix Sport, Spec. Crux
Quoted: 178 Post(s)
Liked 161 Times
And you're an engineer employed by a DOT?
Chip seal comes as has been mentioned in this thread a number of different variety. Some roads, called oiled roads start a out as chip seal and that is all they ever are. There are different screen sizes for the chips that go on the asphalt oil or emulsion that sticks it to the surface of the road being done. If you think chipseal is bad try roads that are not maintained or concrete cracks every 10 or so feet. Chipseal is a lower cost option to extend the life of a roadway or a way to make a roadway. It is what I get to ride on most of the time, hey it beats cobblestone!
Sir Mark, Knight of Sufferlandria
Bikes: 2014 Trek Domane 2.0
Bikes: 2014 CDale EVO, 2007 System Six, 2004 Litespeed Solano, 2002 Burley Duet
Quoted: 92 Post(s)
