Weird chain line, wobbly chain and strange wear on chain ring
Bikes: Dolan FXE
So I decided to check my chain line since there was noise coming from the drive chain. The noise is only there on part of the stroke and then comes back in the same pedal position.
Here's an album of the chain line:
Chain line album
The chain line seems to be straight but the chain is wobbly.
I've also noticed strange wear on the chain ring. Here's an album of that: Chain ring albumr [2]
As you can see it is not worn the same way all around the chain ring.
Anyone knows whats up? Is the chain toast perhaps?
Chain line album
Grumpy Old Bugga
Bikes: Hillbrick, Malvern Star Oppy S2, Europa (R.I.P.)
Quoted: 370 Post(s)
Liked 8 Times
To my eye, that chainline is not straight, but not enough out to cause troubles.
Second, your chain seems to be as dry as anything - it needs lubricant.
Have your checked your chain for sideways flex? Even on a 1/8 chain there'll be a little but if a link or two is tight, you may not get it - this would also cause a tight spot in the chain.
Quite frankly, I this is a lubricate and live with it job.
Bikes: Dolan FXE
Should there be sideways flex or just a little? What am I looking for?
Grumpy Old Bugga
Quoted: 370 Post(s)
Liked 8 Times
1/8 chains are designed for straight chain lines so aren't designed to flex sideways, unlike a 10sp chain which you can tie in knots. However, a chain is made up of lots of little bits so you'll get a little sideways flex. All you're looking for is one point that's tighter than the rest of the chain though to be honest, this'll be more obvious in vertical flex ie, the sort of thing you get when rejoining a chain and the side plates are pushed tight against the roller. The cure will be the same, use your chain breaker to push the side plates slightly apart.
I'm still not convinced you've got a problem though, just something that seems like one.
Bikes: Dolan FXE
Grumpy Old Bugga
Quoted: 370 Post(s)
Liked 8 Times
Seeing you're looking for problems (always a fun game to play on a wet and windy afternoon like it is here), check to see if there is any warping in the chainring or maybe a bent tooth, particularly the ones with funny wear patterns. Probably best to take off the chain and just spin the pedals, watching the chainring from one end.
Zip tie Karen
Quoted: 1465 Post(s)
Liked 1,542 Times
fixed it...
...check to see if there is any warping in the chainring or maybe a bent tooth, particularly the ones with funny wear patterns. Probably best to take off the chain and just spin the pedals, measuringthe chainring separation in millimeters from a fixed reference point like the seat tube.
Fresh Garbage
Yep. This is all pretty normal.
Is the noise coming from the tight spot? https://sheldonbrown.com/fixed.html#tension
Calamari Marionette Ph.D
That looks wonky as heck. Measure the chainline front and rear so you know if it's correct, and if not, you'll know by how much.
What is your gear ratio? It is possible that the same piece of chain hits the same place on the chainring over and over. If you have a warped ring or an overly tight spot in the chain, the sound will repeat uniformly.
Bikes: Dolan FXE
Is the noise coming from the tight spot? Fixed Gear Bicycles for the Road
Anyhow, I lubed up the chain and went for a 30 mile ride and it doesn't sound much at all. I can still see that the chain is wobbly when looking straight at it. Haven't been able to see if the chain ring is straight, but my guess is that it is. Unless it was damaged in the mail when I received the bike, since the sound have been there from the start. I'll just order a spare chain and see what happens.
Thanks guys for the help
tahoeeddie
Road Cycling
24
05-08-13 04:00 PM
