look ma no hands -- why can't i do it anymore?
flaneur
Bikes: IRO Mark V
When I was a kid I could do it, on my old purple italian ten-speed, on my dad's twinkie alloy cannondale, on every beater mountain bike I've ever ridden.
I could do it on my raleigh mountain bike that got stolen on waverly place. I could do it on my schwinn ten-speed that a cab totalled. I could do it on my ****ty conversion that i finally ditched for my beautiful mark v.
So why can't I do it anymore? Is it the geometry? How do I re-learn? Do I just have to keep practicing?
J.A.M
Bikes: Pista
move your arms like your running when you do it. it will help balance you out
The Bianchi That Could
troglodyte
Did you just start riding fixed? Once you smooth your cadence out more, it might help. If you're wobbling side to side in the saddle its going to make a difference. On a fixed you can't just chill there. I believe headtube angle also plays a factor in ease of riding no-handed, although maybe not in your case.
flaneur
Bikes: IRO Mark V
Nope, being riding fixed since last october. I thought you might be on to something for a second, but I used to be able to do it with a conversion. I like what Jamtastic said about the arms though...
無くなった
Bikes: I built the Bianchi track bike back up today.
Maybe tighten your headset? It could be that the front wheel is picking up more subltle variations in your lean/shift while pedaling... That's all I can think of.
Campy or bust :p
Bikes: Surly Karate Monkey commuter build
I think what people say about you fixie riders being a bit eccentric is true
speaking of balls... I don't think I have the balls to ride fixed just yet.. I have to say I admire you fixie riders.
"Word Bond"
Bikes: MTB
Originally Posted by labratmatt
Be sure you have one ball on each side of the saddle. You want an even weight distribution.
SuperstitiousHyperrealist
Bikes: unknown road conversion, half built Benotto track
Then you definitely may have a much more severe problem than balance.
He drop me
Bikes: '03 Marin Mill Valley, '02 Eddy Merckx Corsa 0.1, '12 Giant Defy Advance, '20 Giant Revolt 1, '20 Giant Defy Advanced Pro 1, some random 6KU fixie
Quoted: 138 Post(s)
Liked 12 Times
Could the saddle be a bit too high causing you to rock on it?
The views expressed by this poster do not reflect the views of BikeForums.net.
ambassador of good will
Bikes: many.
could also be an alignment issue. Does it tend to go to one side when you let go, or is it random?
the same force (centrifical? nerds?) that keeps you from falling over when riding keeps your front wheel tending straight. a tight headset counters that force.
F*** Corporate Beer
Bikes: On-OneIROOlympiaYetiLeMondZanella
Originally Posted by boots
<low blow>then how does lance ride no hands?</low blow>
Originally Posted by Msngr
actually, make sure your headset isn't too tight. i purposely keep a tight headset (because i have to carry my bike a lot and i don't like the bars flopping around)
Radfahrer
It could be the headset as mentioned above, or the head tube angle, or the rake of your fork, or you have balancing problems (e.g. because of an ear infection), or combinations thereof.
Team Beer
Bikes: Too Many
Quoted: 114 Post(s)
Liked 159 Times
Is your rear wheel centered? When I rode my fixie after respacing but before redishing I couldn't ride no-handed.
I'm not one for fawning over bicycles, but I do believe that our bikes communicate with us, and what this bike is saying is, "You're an idiot." BikeSnobNYC
Originally Posted by BostonFixed
Doesn't this **** up the headset? (balls, races, etc.)
chopsockey
Bikes: Monkey SS everythingbike, Ti frankenroadbike
it's not centri[pital/fugal] force, nor the gyroscopic action that really keeps the bike going. it's simpler than that. if you hold a bike on level ground and lean it one way, the front wheel turns in the direction of the lean. this straightens the bike out. bikes want to go straight, even when seriously perturbed.
i'd look into headset issues. or if you have speed wobble, it may be an issue of resonance (does it only happen if you sit straight up, or are going downhill)?
easiest way to learn is to get as upright as possible with as little weight as possible on the bars and then take all weight off for short periods of time.
- nerd
- nerd
flaneur
Bikes: IRO Mark V
thanks for the help guys. i've solved the mystery. apparently the reason i can't do it was that... i can. quit being a ***** today and tried it. good as new.
