hydraulic brakes
POWERCRANK addict
hydraulic brakes
Does anyone out there remember the hydraulic brake levers with aero hoods? It's been a while since I last saw them.
If so, who made them? Do you know where I could get a pair?
shameless POWERCRANK plug
Recommended reading for all cyclists - Cyclecraft - Effective Cycling
Condor Cycles - quite possibly the best bike shop in London
Don't run red lights, wear a helmet, use hand signals, get some cycle lights(front and rear) and, FFS, don't run red lights!
POWERCRANK addict
yeah - my thoughts too
I'd like to try this:
Frame – Cyclocross with disc tab option
Fork – 700c disc
Headset –
Stem – 10cm
Handlebars – 44cm
Brake levers – aero hydraulic
Shifters – Rohloff twist shifter
Derailleurs – Rohloff speed hub cc disc 32 hole 15tooth
Front hub – disc 32 hole
Skewers - Shimano
Spokes – stainless straight gauge
Rims – Mavic CXP33 black 32 hole
Tyres –
Crankset – 172.5 38 tooth
BB –
Seat post –
Saddle –
Brakes – Hope Mono mini
Pedals –
It will only happen toward the end of the lifespan of the current bike though.
Fork – 700c disc
Headset –
Stem – 10cm
Handlebars – 44cm
Skewers - Shimano
Tyres –
BB –
Seat post –
Saddle –
Pedals –
POWERCRANK addict
Thanks for the help gents.
I've just spoken to Drew(UK sales manager) in Magura's German office. 50 pairs only of the last ever production run of HS66 aero brake levers is due sometime in the next couple of weeks. The only Magura disc brake calipers compatible are Julie. Other manufacturers brakes MUST be a mineral oil, low pressure system to be compatible. Also check the hose fittings.
The levers may (depending on a number of factors) be more or less expensive than GBP116 per pair. Factors like Magura weren't quite sure of a final price yet.
So if you want some for that cyclocross or SS project bike I suggest you get in there quick. I know you can order them through Condor Cycles but I am biased.
There is a pair on ebay just now:
https://cgi.ebay.com/ws/eBayISAPI.dll...147126880&rd=1
I am not the seller nor do I know her/him.
