Pedals too tight to remove (help!)
Old 04-09-05, 04:07 PM
I'm trying to remove some Ritchey clipless pedals to switch over to my new bike. The problem is that the pedals have been on the old bike for 8-9 years, most of which the bike has been in storage. I'm worried they are rusted on, any suggestions as to how to oil them up or something and get them loose? I even tried hammering the end of the wrench to free them up but they are too tight. I'm clueless mechanically and would appreciate any help. THanks!
blockzilla is offline
Old 04-09-05, 04:12 PM
Ferrous wheel
Bikes: 2004 Gunnar Rock Hound MTB; 1988 Gitane Team Pro road bike; 1986-ish Raleigh USA Grand Prix; mid-'80s Univega Gran Tourismo with Xtracycle Free Radical
I would try squirting some Liquid Wrench around the thread area. Sometimes applying heat helps, too.
spider-man is offline
Old 04-09-05, 04:34 PM
Bikes: 2 many
Quoted: 1266 Post(s)
Liked 323 Times in 169 Posts
Put some penetrating oil on the threads and leave it over night.
Are you using a bicycle pedal wrench? This is a big help. The left (non drive side) is reverse thread. Hold the bike still ( put the bike on the ground) and push down on the wrench towards the floor. If this does not do it or you are not sure about reverse threads take it to a bike shop.
2manybikes is offline
Old 04-09-05, 04:40 PM
I'd rather be riding
Noif666's Avatar
when you get the pedals off and before putting them on your other bike, grease the threads to prevent this problem next time.
Hace fun!
Noif666 is offline
Old 04-09-05, 04:45 PM
Bikes: Specialized Sirrus Sport, Specialized Stumpjumper Comp, Brompton, Trek 1500
Take it to your local LBS and then put grease on them next time. Local LBS will be able to get them off, will have big wrench etc.
motorhommmer is offline
Old 04-09-05, 05:26 PM
SJK
All you need is leverage. Get a long pipe and put it over the wrench. Use this leverage to free your pedals. Make sure you are loosening them in the correct direction – I believe to the rear of the bike.
SJK is offline
Old 04-09-05, 06:48 PM
I couldn't car less.
jeff williams's Avatar
Bikes: Ritchey P-series prototype, Diamondback, Nishiki Triathelon Pro.
Is there a hex key slot on the end of the spindle? (otherside of the crank arm.)
If so, use a hex key and a wrench.
jeff williams is offline
Old 04-09-05, 07:50 PM
Bicycle Rider & Mechanic
Trekbikedude's Avatar
Bikes: Superlight, Dragon Team, Eclipse, Om Flyer
I encountered this problem today what I did was flipped my bike upside down and I had my priend hold the pedal down with his foot and I pushed the wrenchtoward the rear wheel, it was only my right pedal that was giving me trouble though. I recommend trying this as it worked for me.
Trekbikedude is offline
Old 04-09-05, 07:51 PM
friend* sorry about that typo
Old 04-09-05, 08:00 PM
Thanks everyone for the help. I decided to play it safe and took it to my LBS to pop them off for me. They are now happily at home on my new ride.
Old 04-09-05, 08:01 PM
cool
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
