The Mysterybike
The Mysterybike
I've inherited a bicycle and I know neither its make nor its quality.
from what I can tell it has not seen much use, though it was put into storage wet (judging by rusty chain)
so I busted out my camera and took some pictures. maybe you all can help me pin the tail on the donkey, or, rather, pin the make/quality on the bike.
here is a picture of the bike from a distance:
Larger version here
In the interests of dialup users (like myself) i'll link to the pictures so you dont have to wait till the cows come home before the pictures load.
here's a Tubular Intersection (frame meets fork downtube, or something)
Intersection of seatpost, top tube and the one that terminates at the dropouts
click
closeup of rear sprocket, derailleur in shadow, and some welding. click
If I was chasing you, this is what you'd see. front shot of cycle.
Whatever turns your crank, baby (crank from non-sprocket side)
she's a dropout excuse the artful angle. (rear dropuout)
hubba hubba, she spoke (shot of front hub, and some spokes too)
very large, very closeup view of downtube/welding. (if there was such thing as bike porn, this would be hardcore)
if you have any questions, or would like a picture of a certain part, please ask.
I apologise for any incorrect terminology, too
Thanks in advance for any help/input.
Larger version here
click
Gravity Is Yer Friend
From: "Over the Hill" and going down fast in the 805.
Bikes: Scott Gambler, Scott Ransom, Kona Bear, Bianchi 928 Carbon/Chorus, C'Dale Rize4
I have no idea as to the make but there is what looks to be a crack in the welds by the drop out.
Footballus vita est
Bikes: Trek 4500, Kona Dawg
I'm not sure that is a crack by the dropout, I think it's just a small shadow from the beads of the welds, but you should still take a closer look at it.
Looks like it could be a good project. Good luck with you ID search
"The internet is a place where absolutely nothing happens. You need to take advantage of that." ~ Strong Bad
good idea
I'm surprised I didn't think of that.
I checked in the dropouts as well, but as far as I could tell nothing was stamped there.
I'm just surprised that save for the serial# there appears to be nothing stamped on the frame. anywhere.
DEADBEEF
From: Catching his breath alongside a road near Seattle, WA USA
Bikes: 1999 K2 OzM, 2001 Aegis Aro Svelte
It looks like an early 90s (ca 1992-1994) Cannondale. The fork looks to be an MRC fork.
1999 K2 OzM
"Be liberal in what you accept, and conservative in what you send." -- Jon Postel, RFC1122
1999 K2 OzM
2001 Aegis Aro Svelte"Be liberal in what you accept, and conservative in what you send." -- Jon Postel, RFC1122
DEADBEEF
Originally posted by tFUnK
i was thinking cannondale but did they have internal cable routes? and also many of their bikes had the headshok system in the 90's.
And I think the Headshok system only started becoming available on the higher-end models sometime around late 92 or 93. While this bike has a DeoreXT rear derailleur, it looks like it may not have been top-of-the-line. The brakes look like DeoreDX rather than DeoreXT (mixed group commonly found on the one-step below top bikes).
The straddle cable and holder looks to be of the thinner variety leading me to believe the components and possibly the bike date closer to 1990 or 1991. Later Shimano cantilever brakes (ca. 1992+) started coming with thicker cables and a round straddle holder rather than the "thong-wedgie" one you see here.
The most indicative portion of the bike that leads me to date it to pre-1992 is the bottom bracket which looks to be of the older non-cartridge bearing type. I believe Shimano went to cartridge bearing BBs (at least for anything above Exage) in 1992.
I also notice a slightly raised front end (assuming this isn't an optical illusion) as compared with what was (I'm assuming) supposed to be a horizontal top-tube which leads me further to believe that this bike was retrofitted with an aftermarket suspension fork that was pre-threadless. That also narrows down the years some although I know many fork manufacturers offered threaded and non-threaded versions for quite some time throughout the 1990s.
While I can't be 100% certain, the large aluminum tubes combined with big fat welds and the "dating" of the bicycle via its components to around the very early 1990s strongly points to it being a Cannondale.
1999 K2 OzM
1999 K2 OzM
Bikes: Lots
My first though was like Khuon's that this is a Cannondale. After looking at the close-ups, I'm almost certain.
My room-mate in college had nearly an identical bike but without the suspension fork. I'm guessing late 80's or early 90's vintage. I graduated in '93, and at that point, his frame was a good 4 to 5 years old.
His was painted, and stipped to raw aluminum. Looks like this was done to this frame as well.
Send Cannondale an e-mail and see if the serial number matches up with any of their fabrication numbers.
L8R
L8R
"Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming, "WOW, What a Ride!" - unknown
"Your Bike Sucks" - Sky Yaeger
Thanks for the insight khuon and psyklnut
one thing that might be important to note is that the fork is NOT suspended, but could still be aftermarket. (it doesn't look conventional)
The brakes are XT (at least that's what it says on the pads)
early '90s sounds about right for this bike, I think.
and live 311... the front tire is on the right way now
EDIT:
I just called Cannondale and from what they could tell me the mysterybike was not made by them; the serial number is in the wrong format for any cannondale manufacuturing year.
EDIT:
DEADBEEF
EDIT:
EDIT:
1999 K2 OzM
1999 K2 OzM
Originally posted by khuon
This is actually kind of a fun game. |8^)
Okay... I figured out what the fork is. It's one of a variety of Tange forks that could also have been marketted by Bontrager.
There is a "B" logo on the front of the fork, and on the top of each leg. Bontrager it probably is
I remember Supergo trying to unload a bunch of no-name fat-tubed frames around the early 90s. Could this possibly be a generic frame-up build?
I called up the person who gave me the bike (not sure why this didn't occur to me earlier.) He couldn't tell me much more than "it's an American. Good Bike" (He's a Swede with limited English skills)
i don't know whether he meant the bike is American made, which would sort of go without saying, or if a company named "American" manufactured it. I only know of American Eagle and American Maverick, so I fired an email off to both places.
we'll see.
I've finally got some closure on this.
in my inbox this morning:
now does anyone know anything about " The American Manufacturing Group?"
Hello Seth,
Thank you for your e-mail and question. Your bike is an "American". The American manufacturing group produced aluminum hardtail mountain bikes all through the 80's and 90's. They also produced frames for many other brands.
They were cool. Maverick American did not produce this bike.
Best Regards,
Tim Johns (T.J.)
Maverick American
Best Regards,
Tim Johns (T.J.)
Maverick American
DEADBEEF
1999 K2 OzM
1999 K2 OzM
