What lube to use for installing pedals
You want grease in there. It doesn't have to be fancy or expensive, it just has to fill the small gaps in the threads so that water can't wick in and start a corrosion process. Tri-flow won't do that.
FB
Chain-L site
FB
Chain-L site
Bikes: Bianchi, Miyata, Dahon, Rossin
automotive shop.
get something like white lithium, marine or PTFE synthetic grease.
Food for thought: if you aren't dead by 2050, you and your entire family will be within a few years from starvation. Now that is a cruel gift to leave for your offspring. ;)
https://sanfrancisco.ibtimes.com/arti...ger-photos.htm
Crazy ole cat lady
Bikes: One built up on a Nashbar frame, one built up from a Paramount frame
Isn't that a steel spindle/aluminum arm joint? I used anti-seize compound (the silverish stuff) when I built up a bike last winter (first time). Would grease have been a better choice?
I suspect anything thick enough to not flow would work.
Old fart
No, anti-seize is fine. I would have gone with a copper-based anti-seize but I doubt you'll have a problem with the aluminum based product you used.
Cycling Skier
Bikes: 2019 Moots Vamoots DR, 2008 Pedal Force ZX3, 2006 Jamis Eclipse, 1997 Marin Indian Fire Trail
Anti-seize is best, waterproof grease next best, white lithium grease works well enough. Liquid is better than nothing at all, but only a little better.
I have always used white lithium grease and my bike has lived outdoors 24/7 for years in damp, coastal town.
