School me on quill stems...
Still tossing around different fixed gear choices, currently considering a Langster Steel or a Masi Speciale.
The new langster steel's have the quill stem. I'm not too familiar with these, so I'm looking to weigh the pros and cons of them against a removable stem (not sure of the technical term for the stem on my Allez, but I'm sure it gets the point across).
Are they sturdier? Harder to position up or down to fit your riding preference?
Height is easy to adjust, they are usually pretty flexy, it's a PITA to change bars on them. I don't have a problem with them, as both of my bikes come with quill. One has a threadless adapter, but that doesn't make it less flexy. The only thing I hate, is when people go out of their way to change from threadless to threaded because it's a lot of time, effort, and money to switch to a pretty inferior system.
No, it's threaded for sure. I wish it were threadless, but no worries. The fixed gear is closer to being threadless since I have an adapter.
Bikes: Bianchi, Miyata, Dahon, Rossin
with a threadless stem, you just swap it out for a stem with sharp angle.
Food for thought: if you aren't dead by 2050, you and your entire family will be within a few years from starvation. Now that is a cruel gift to leave for your offspring. ;)
https://sanfrancisco.ibtimes.com/arti...ger-photos.htm
This is a very good point.
Threadless can look damn good too btw
True, what stem is the one you posted? I want.
Woah, woah, woah, woah, woah. You're telling me that stem has a removable face plate? That's the only threaded stem I've seen with a removable face plate that doesn't look like complete ass. I didn't realize it was your bike either. What's the rest of the ride look like?
then the frame was upgraded to this:
the eurus wheels are off my other bike. i am in the process of building "proper" wheels for the tommasini. silver campagnolo hubs laced laced to silver campagnolo tubular rims (all NOS, 28h, 2x)
edit:
you can see one of the new rims hiding in the second picture. (tan sidewalls will return)
Bikes: raleigh gran prix converted to fixed
They are flexier, heavier, there are fewer choices(and fewer and fewer everyday) I'm not saying you can't find them but at somepoint when you ask for one at a bike shop they're going to give you odd looks and offer the only option(maybe by pyramid?) it'll be heavy, black and awkwardly angled but you'll take it because you need one and eBay is full of scammers, while your at it look for some fixed gear that use 27 inch tires, it's the next "old school" trend we are going to watch people embrace(because they look so classic)
Thanks for the advice. Definitely seems like quill stems are or should be obsolete technology for good reason, but as some of you mentioned, their looks and nostalgia attract. I get that, but I want versatility. The stem has been one of the key components when looking at FG bikes. Has to have a certain kind...not quill, at least for what I want.
https://www.bikebits.ie/product.asp?i...uct_type=Stems
Had this stem on my Colnago Master Olympic. Not easy to handle as a Deda murex, but nicer.
I read even a lot of mixed reviews about the murex.
Or look at this
https://italiancyclingjournal.blogspo...rstem-for.html
Or look at this
Once you find a quill stem and bar setup you like, and fits you well, little change is required thereafter. Unless you like to constantly change things out. The only threadless stem I have is on my 29r singlespeed mtn. bike, and I haven't changed anything on it other than swapping the grips for ourys. So a removable faceplate is nice but not essential for most riders I think. I recently scored a dura ace quill stem for my fuji track bike, it is amazing - no stem clamp bolt visable anywhere!
1989 Schwinn Paramount OS
1980 Mclean/Silk Hope Sport Touring
1983 Bianchi pista
1976 Fuji Feather track
1979 raleigh track
"I've consulted my sources and I'm pretty sure your derailleur does not exist"
1983 Bianchi pista
1979 raleigh track
Bikes: Miele Azsora, Kuwahara Cascade
There are people here who have come up with all kinds of reasons to dislike quill stems, but it's mostly hyperbole. If threadless stems are stiffer, it's at an order of magnitude impossible for mere mortals to detect. Maybe they're slightly more versatile, since you can flip them. Is this really such a big deal?
There are advantages and disadvantages to both. Neither is clearly superior. I suspect that the primary reason the bike industry has moved to threadless is because it makes things cheaper to manufacture (even though consumers have never seen a price drop that reflects this).
The way I see it, if threadless was truly superior, there wouldn't be so many bikes still being manufactured with quill stems. Think of any other 20+ year-old design improvement on bikes—if they were any good, they became 99% standard.
There's really no disadvantage to threadless stems over quill stems, other than price, which is evident in that no one would recommend switching from a threadless fork to threaded fork for the sake of using quill stems. You don't see a cost saving in threadless, because manufacturers can use more complex materials or draw tubes thinner to take advantage of the better interface and that costs more money.
the one place you find a lot of quill stem usage are on are cheap department store bikes made from hi-ten steel. keeping the quill stem on these sorts of bikes also makes it cheaper to hobble together useful bikes from older junk bikes.
you can visually see the flex difference between the two. that said, the deda setup is much nicer for long relaxed ride. (i also have a very stiff ITM threadless setup but its a very oversized stem and bladed road drops.)
if you still think its price, count the threadless stems here:
wal-mart
and here:
excel sports
find the average price, weight, and percentage of quill stems in use.
i'm not hating on quill (i love my murex) but technology has advanced. threadless just ha no place on my tommasini
