Dahon Speed TR -
Bikes: Dahon Speed TR and Dahon Speed Pro TT
Dahon Speed TR -
hi all,
AN UPDATE: finally done ( i think so) with the upgrades on my Dahon Speed TR.
here are the changes i made:
1) removed front and rear racks
2) changed flat handlebar to ritchey and trimmed 1 inch on both side
3) change the MKS EZY pedal to MKS FD-6
4) installed kojak tires
5) installed front kinetix pro wheel (removed the TR hub wheel)
6) installed Selle Italia seat (from previous bike)
7) installed TURNER aluminum cnc 33.9mm x 600mm seatpost (got it for $15)
8) removed ergon grips with bar end and installed ergon GP1-L grips.
9) i was able to fix the gap between the tires and fenders. had to fabricate my own fender wire support.
with all these changes, my dahon speed tr went from 30lbs to 20+/- lbs. (i still need to get an accurate scale). based on my arm lifting, this is now a VERY LIGHT Dahon Speed TR.
future upgrades:
1) i might put shimano FC5600 105 52T chainring and hallowtech bottom bracket.
My Dahon Speed TR when i first got it:
Speed TR after some adjustments/upgrades: as you will notice, there is a big gap between the tires and fenders. this is due to the change of tire from 20x2.0 to 20x1.35 (kojaks)
This is the NOW picture after all the changes/upgrades i did to my speed tr. 20+/- lbs baby.....
front wheel: upgraded to Dahon Kinetix Pro wheel. gone is the GAP between tire and fender.
rear tire: no more gap between the tire and fender after i fabricated my own wire support.
the ritchey handlebar (2 inches shorter than the normal dahon handlebar lenght.
future upgrades:
Bikes: Joey Sport; Mezzo D9;Curve D3; Surly LHT self build cargoesque
Also, for someone who wants to keep their TR as a mainly touring bike, but doesn't like how slow it is (ie me) which of your mods would make most difference. Tires ?
Bikes: Lynskey R230 DA DI2 ENVE 3.4 SES, 6KU Fixie, Cheap Aluminum Slapstick Trainer only bike
+1 on this. Weight I am not even bothering... (between my ortlieb and +1 pannier of extra stuff...) it is like 25-30lbs extra weight I carry anyways... but any rolling resistance from tire, I've been wondering.
i had my true test ride with the bike ( with all its upgrades) just yesterday and i will say that I LIKE IT A LOT. shift good, handlepost is not too flexy as my bike friday, having a dual drive is really nice. the 24 speeds are all usable. kojak is fast and i like how it is air pumped almost to the max of 95psi. i like my tire hard and boucy. weight is so light and nice to lug around. I am loving it now. buying it was not a bad decision after all. plus i love working on the bike - changing anything or upgrading something.
yes. the tires. kojaks are fast compare to big apple 2.0. in fact i was thinking of getting the stelvio which is even narrower than the kojaks as i really want it to go faster but i heard a lot of negative reviews about the stelvio.
keeping it as a touring bike may not work for kojaks although i like it a lot as it is way faster than the big apple.
cyclopath
Bikes: Surly Krampus, Surly Straggler, Pivot Mach 6, Bike Friday Tikit, Bike Friday Tandem, Santa Cruz Nomad
Narrower tires does not equal faster speed - especially for a small wheeled bike. The passive suspension offered by the Kojaks [assuming you pump them to allow for 3-5mm vertical drop when you are on bike] will reduce rolling resistance compared to a smaller volume tire at higher pressure.
Bikes: Brodie Force w/ Xtracycle, Dahon Helios, Merida Folding, Pacific Carryme, Softride Classic
The single best upgrade to make a bike faster is tire selection followed by tire pressure choice with the chosen tire.
Weight is entirely dependant on the bicycle's design for intended use. A touring bike will be heavier than a road design optimized for speed. Unless you are lifting and carrying the bike multiple times a day, the bike's static weight is not the primary deciding factor for a good riding experience. Any bike can feel "fast" if you run the right tire and gear it appropriately. Far better to get the tires, then figure out your riding style and natural cadence. You will only find this out by riding enough miles.
Then figure out if the gear spacing is working for you for your type of riding, your natural cadence and your terrain. Change the gearing to fit these variables appropriately. Once you do, the bike will feel live, responsive and an extension of your body in covering distance. That's when the fun *really* begins.
Bikes: Brompton S2L-X, Bridgestone Moulton, 1963 & 1966 Moultons, Scott Mountain bike
It looks as though you have made some worthwhile mods to that bike. I’m not a Dahon fan anymore..... I do know how heavy the Speed TR is as standard.
As regards Kojaks, I love them... I first encountered them in May 2008 on a Dahon MU SL with 20” wheels. I have been using the 16” version on my Titanium Brompton since March 2009.... used most days in all weathers and on all types of roads / trails. Ran through glass plenty of times and it is only recently that I had my first ever puncture with these tyres and I think that is more down to the fact that they are getting a bit worn and a very small slither of glass managed to find its way through the race guard protection.
I have just bought another set but will see if I can get this winter out of the existing pair and then fit the new ones in the spring.
I have Stelvio’s fitted as standard to my Bridgestone Moulton but I think these are difficult to get now in (17”) so I bought 6 spare tyres just in case.....
it's not one of the best pedal out there. my TR has the MKS EZY pedal but to much hustle in taking it out and putting it back on so i decided to put the FD-6. all i can say is this is a nice and better upgrade than the standard pedal that dahon used and for the price it's a good investment.
i heard good reviews about this pedal:
https://cgi.ebay.com/2010-QR-Wellgo-B...#ht_3505wt_861
Bikes: Bianchi, Miyata, Dahon, Rossin
if you want to use a hollowtech II double with the FD clamp from thor, buy a triple hollowtech II crankset.
The triple hollowtech II crankset sits the chainrings out further and you won't run into problems with the FD bottoming out on the frame. You, of course, can't use the granny ring, but you'll get a properly functioning double.
I've installed an ultegra triple to my dahon, and it works perfectly as a double with the FD adaptor from thor. A double fits, but the rings sit too inward for proper actuation.
Food for thought: if you aren't dead by 2050, you and your entire family will be within a few years from starvation. Now that is a cruel gift to leave for your offspring. ;)
https://sanfrancisco.ibtimes.com/arti...ger-photos.htm
The triple has a longer axle and spacers to allow it to sit out further from the frame.
So if you use a double, you will only be able to use one chainring at a time.
had a friend ordered it for me in china (taobao) and had someone brought it back home in california. i know with that price i could have bought at least 3 but at that time they only have red and gold color. now i have no contact with my friend in china as he moved to another city.
