French thread bottom bracket/spindle HELP
Old 01-01-11 | 07:54 PM
I have a 1960s Peugeot bike with a cottered bottom bracket that I want to convert into square tapered. I was told that this could easily be done just by replacing the spindle with a square tapered one. I measured the dimensions of the cottered spindle and found that the center, or B in this image from Sheldon Brown
was 56mm. If I buy a spindle with the middle length of 52mm, im think it would not work because the space between the bottom bracket shell and the spindle thing (dont know what its called) is too far apart for the loose bearings.
How do I solve this problem?
Buy a new french threaded bottom bracket? (or maybe just new bearing cups?)
or will the 52mm spindle work with the bottom bracket cups I already have?
organicmuch is offline
Reply
Old 01-01-11 | 08:10 PM
3alarmer's Avatar
Bikes: old ones
Hard To Say
First, if you decide to replace it with a
sealed cartridge unit from Velo Orange:
https://store.velo-orange.com/index.p...y-cups-26.html
I have one I just ordered for a PX-10
overhaul, and while I cannot testify with
regard to its longevity, it appears to
be a very high quality product.
If you want to simply replace the spindle,
whether your 4mm shorter spindle (between
the cone surfaces) will work depends on
how much adjustment you have to play
around with in your adjustable cup. As
long as you have enough thread left to
install and tighten the lockring after you
adjust the bearings, you're good.
There used to be a number of various
square taper spindle replacements available -
which is probably when whatever you read
was written. Now, unless like me you have
access to a pile of used parts or a bike coop,
the choices are more limited. Perhaps
someone else will post a suitable source for
a guaranteed replacement.
But if you really like the bike, plan on keeping
it for a while, and are going to replace
with a reasonable quality crankset, consider
the Velo Orange sealed unit.
3alarmer is offline
Reply
Old 01-01-11 | 08:54 PM
Grand Bois's Avatar
You could also do it the old fashioned way and buy your spindle and cups on eBay. You'll find both Campagnolo and Shimano sets in French thread there right now. You just missed out on a T.A.
If you buy the Velo Orange unit, you'll have to use a crank with a JIS taper. That's okay if it doesn't bother you to put a Japanese crank on a French bike.
I have four French roadbikes, so I have some experience with this stuff.
Grand Bois is offline
Reply
Old 01-01-11 | 09:45 PM
I also read somewhere that someone used a italian bb spindle for this. Im not sure under what circumstances it would work but im guessing italian bb spindles have a wider center section (maybe 54mm?) and i am still not sure if it would work to replace a 56mm...
Reply
Old 01-01-11 | 10:54 PM
Mike Larmer
I just tested how much thread I have left on the adjustable cap after installing everything and there was 2 levels of thread left. I dont think thats any more then 2mm of adjustable space meaning I would need to have an axle of no less than 54mm wide between both ridges?
Reply
Old 01-02-11 | 01:39 AM
3alarmer's Avatar
Bikes: old ones
Grand Bois:
As do I , amigo. Take it from me that even the
experienced can err from time to time. Certainly
there has been a great deal written and discussed
with regard to Square taper cotterless crank
interchangeability that would be largely unnecessary
if the situation were as simple as you describe.
Besides this: https://www.sheldonbrown.com/bbtaper.html
which as a summary of practical application of available
information works pretty well, I can quote from
Sutherland's Sixth 3-5 : (sounds sort of biblical, no?)
Old useful combinations that do work - Maxy type spindles
can be used to place chainline farther from the frame with
Stronglight or TA cranks.
and 3-8:
The square taper of JIS spindles is similar (though
longer) to that of older Stronglight and TA spindles.
While I appreciate your passion for period authentic
restoration, it can be somewhat limiting to search
continually for old parts on e-bay when what is
actually required for a repair is readily available,
albeit in a more modern format.
To organicmuch: From that same section of Sutherland's
Sixth 3-5 :
Old combinations that don't work - Peugeot
cottered spindles and cups will not interchange; its bearing
race diameter is much smaller than the others.
so there is an additional problem. My own feeling
(and I too own a couple of Frenchies that I enjoy riding
from time to time) is that they would be much easier to
work on if I lived in Paris. Meanwhile, I'm grateful for the
Velo Orange contribution because it is cheaper than a
Phil Wood BB and it makes my life a little easier.
Respectfully,
Mike Larmer
3alarmer is offline
Reply
Old 01-02-11 | 02:15 AM
I found this useful piece of information from Sheldon Brown's site answering my question.
French bottom bracket cups usually have thinner walls than Japanese ones, so the bearing ridges on the spindles are farther apart. If you use a standard Japanese spindle, the adjustable cup won't be able to screw in far enough to snug up the bearings, or if it does, it will sink into the bottom bracket shell so that you won't be able to install the lockring.
The good news is that a Japanese spindle made for an Italian size (70 mm) bottom bracket will usually fit! In the Sugino marking system, these are the spindles that are marked with a "5" code. Spindles for 68 mm bbs have codes beginning with 3. This trick often makes it possible to upgrade an older bike from cotterd to cotterless cranks at a reasonable cost.
Now, 3alarmer brings up another problem with interchangability between peugeot and other parts. Am I doomed to replace the entire bottom bracket?
Reply
Old 01-02-11 | 08:19 AM
Grand Bois's Avatar
An ISO crank will sit farther out on a JIS spindle. This not only creates chanline issues, but can result in a damaged crank.
The simplest way by far is to buy French cups and a 118 mm spindle and use a vintage French crank. All of the old French doubles use that length.
Here's one that I converted to cotterless. I used Sugino cups and a Sugino ISO spindle marked MW-68.
I used the cottered crank on my beater Jeunet.
This one has an ISO cartidge BB made by Edco of Swizerland. Velo Orange used to sell them. I had to use it because I was unable to find the correct spindle for the triple.
I used Stronglight cups and a 118 mm Stronglight spindle on this one. I see them on eBay all the time.
Reply
Old 01-02-11 | 08:53 AM
I think "doomed" is putting it a bit harshly. A Velo Orange bottom bracket and compatible crank will solve all of your problems at reasonable cost.
I fully agree with 3alarmer that insisting on an authentic period restoration is a very limiting approach for a bike that is going to be used as a practical rider. If you were restoring it to be a museum piece, fine, but not if the bike is to be put to practical use.
HillRider is offline
Reply
Old 01-02-11 | 01:41 PM
3alarmer's Avatar
Bikes: old ones
We're Doomed !
I prefer to think of it as following the path of least resistance.
3alarmer is offline
Reply
Old 01-02-11 | 02:29 PM
Bikes: 8
If you can find a spindle with the same B measurement, you can Use your Cups,
if they are not pitted
A,C and D are all dependent on the crank you get, and its requirements..
fietsbob is offline
Reply
Old 01-03-11 | 12:24 AM
3alarmer's Avatar
Bikes: old ones
What part of:
did you not understand?
3alarmer is offline
Reply
deux jambes
Classic & Vintage
20
08-10-18 10:36 AM
Narhay
Classic & Vintage
6
04-28-15 08:04 PM
Altbrewer
Bicycle Mechanics
12
05-25-13 07:54 AM
jpsawyer
Bicycle Mechanics
5
07-28-11 11:33 PM
jonwvara
Classic & Vintage
11
07-03-11 01:01 PM
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
