Rear Axle Position On Older Bikes
Old 01-12-11 | 01:48 PM
zandoval's Avatar
Titanium Club Membership
15 Anniversary
On most of the older bikes I have worked with, the stamped or forged dropout is worn or marked where the ideal axle positions have been - BUT - What are the caveats for proper positioning? - Campy puts the axle just a above or about 2mm behind the mounting hole for the rear dérailleur - Shimano directly above - Lately I have had to bring axles farther back than normal in order to accommodate 34 tooth freewheels - I have not had any problems - Yet...
So... Are there rules???
zandoval is offline
Reply
Old 01-12-11 | 01:49 PM
ColonelJLloyd's Avatar
I'm interested in hearing the responses here. To be clear to others that coming along, Zandoval, you are referring to horizontal or semi-horizontal dropouts, correct?
ColonelJLloyd is offline
Reply
Old 01-12-11 | 02:16 PM
zandoval's Avatar
15 Anniversary
Yes - Here are some pics from Sheldon...
File Type: gif
File Type: gif
zandoval is offline
Reply
Old 01-12-11 | 02:32 PM
15 Anniversary
Great idea for a thread! Looks like I will learn something today.
ColonelJLloyd, very cool avatar. For some unknown reason though, when I see it I think of a 60's version of Max Headroom.(I have no idea why)
seypat is offline
Reply
Old 01-12-11 | 02:38 PM
auchencrow's Avatar
On stamped DO's, usually there is a stop at the rear of the mounting for the derailleur claw, which I position full rear.
-Thus, the left side is free to float fore or aft, as required to align the wheel.
On forged DO's there's usually an adjuster screw, which I set to mimic the above situation, and then net the opposite side adjuster screw to wherever the axle ends up.
( I would be interested to know if there is a better way.)
- Auchen
auchencrow is offline
Reply
Old 01-12-11 | 02:48 PM
Chombi's Avatar
Bikes: 1986 Alan Record Carbonio, 1985 Vitus Plus Carbone 7, 1984 Peugeot PSV, 1972 Line Seeker, 1986(est.) Medici Aerodynamic (Project), 1985(est.) Peugeot PY10FC
My Peugeot's forged Simplex DO's do not have any marks to show any ideal axle position, so I always just mount the wheel as far forward on the DO's as I can, making sure the QR's still have full engagement with the DO's. I figure, I might as well minimize the bike's wheelbase if I can. Don't know If it really has any perceptible effect to handking, but the bike seems to ride just fine, RD shifts OK too.
Chombi
Chombi is offline
Reply
Old 01-12-11 | 02:57 PM
Thanks. It's the blond pompadour (although, Headroom's wasn't a full pomp).
Reply
Old 01-12-11 | 03:03 PM
zandoval's Avatar
15 Anniversary
Chombi - Hey I like that - That also kind of moves the dérailleur farther behind the axle to give more room for more teeth...
zandoval is offline
Reply
Old 01-12-11 | 03:15 PM
SJX426's Avatar
15 Anniversary
Bikes: ? Proteous, '65 Frejus TDF, '73 Bottecchia Giro d'Italia, '83 Colnago Superissimo, '84 Trek 610, '84 Trek 760, '88 Pinarello Veneto, '88 De Rosa Pro, '89 Pinarello Montello, 'Litespeed Catalyst'94 Burley Duet, 97 Specialized RockHopper, 2010 Langster
Good topic, although I think we have disucussed this before! Having said that, I don't remember the outcome! There must be an impact to shifting quality. That topic alone is worth several pages!
What have you expereinced vs what do you think.
SJX426 is offline
Reply
Old 01-12-11 | 03:17 PM
zandoval's Avatar
15 Anniversary
I have used this pic as a template when welding on dérailleur hangars to stamped dropouts - Are there critical considerations for axle position?
File Type: jpg
zandoval is offline
Reply
Old 01-12-11 | 03:23 PM
triplebutted's Avatar
Bikes: Lemond, Gios, Fuji, Trek, too many to write
I've always scooted my wheels as close to the downtube as possible to shorten the wheelbase. With the limit screws, its easier to do.
triplebutted is offline
Reply
Old 01-12-11 | 04:25 PM
20 Anniversary
Axle position in the dropout affects the following characteristics:
1. Handling: Moving the wheel forward shortens the wheelbase, making the bicycle more nimble. It also shortens the effective rear triangle, making it slightly stiffer and more responsive to pedal input.
2. Chain angle: Moving the wheel forward increases chain angle, increasing chain, cog and chainring wear when the chain is crossed-over, particularly when using stiff, bush style chains.
3. Gear capacity: Moving the axle farther back allows you run a slightly larger cog.
4. Chain wrap: Moving the axle back wraps more chain around the cog and decreases the probability of skipping, particularly with worn chain and/or cogs.
5. Chain Gap: This is the biggy. It directly affects derailleur performance. It’s the distance along the chain from were it contacts the cog to where it contacts the jockey pulley. Derailleurs with long chain gaps tend to be late shifting, that is they require more effort and overshifting with the lever in order to execute the shift. Derailleurs with short chain gaps shift early.
Optimum chain gap depends on the chain and cog type. Stiff chains and pointed cog teeth require long chain gaps, usually around 7cm. Most vintage bush type chains and flat top cogs requite about 5cm chain gap. Bushingless chains and flat top cogs require about 4cm chain gap.
Proper chain gap is critical, particularly for optimum performance of indexed derailleurs and is the prime reason that vertical dropouts dominate indexed bicycles. The manufacturer’s don’t want you to screw things up by changing the axle position! Proper chain gap for indexed systems is about 4cm.
The bottom line is that changing the axle position can affect various characteristics, depending on what you are trying to achieve. Optimizing one characteristic may mean compromising other(s).
T-Mar is offline
Reply
Old 01-12-11 | 04:32 PM
sailorbenjamin's Avatar
From: Rhode Island (an obscure suburb of Connecticut)
Bikes: one of each
You meant MM, not CM, right?
Thanks for the detailed explanation.
sailorbenjamin is offline
Reply
Old 01-12-11 | 04:35 PM
91MF's Avatar
i'll probably break it
Chombi
i do this too. i have never noticed a shifting issue on any of the bikes i have done this with.
91MF is offline
Reply
Old 01-12-11 | 04:51 PM
Bikes: Cinelli, Paramount, Raleigh, Carlton, Zeus, Gemniani, Frejus, Legnano, Pinarello, Falcon
I bought that CD recently...
dbakl is offline
Reply
Old 01-12-11 | 04:54 PM
There's a screw mounted stop available for the other side to get the wheel centered all the time once installed.
dbakl is offline
Reply
Old 01-12-11 | 07:48 PM
I must admit I've never thought about it.
RobbieTunes is offline
Reply
Old 01-12-11 | 07:52 PM
Grand Bois's Avatar
My Peugeots have screw mounted stops on both sides, I mount the stops all the way back and pull the axle up against them. This puts the axle approximately in line with the seat stay. I could move the axle forward a bit, but I doubt if I or anyone else would feel a difference.
I removed the stops and pulled the axle all the way one time as an experiment. For some reason the chain skipped on the two smaller cogs. This doesn't make sense to me because the effect was to increase chain wrap, but it happened.
Grand Bois is offline
Reply
Old 01-12-11 | 08:40 PM
Used to be Conspiratemus
15 Anniversary
Agree with T-Mar's Point 5): Moving the axle forward or back in the dropout achieves with classic derailers what is now accomplished with the B-adjusting screw: optimizing chain gap for crisp shifting (and keeping the jockey pulley from rattling against the largest cog.) Interesting observation from Grand Bois about skipping with the axle all the way back.
conspiratemus1 is offline
Reply
Old 01-12-11 | 11:43 PM
zandoval's Avatar
15 Anniversary
Great T-Mar - Thanks for taking the time to put it down - I am going to print it out and put it in my notebook - You should consider sending your info to Sheldon's site - It certainly explains why I have, by sure luck, not had any problems so far...
Finding dérailleur placement is kind of like balancing the carbs on a 1960 Covair - Once you find that sweet spot - You are there...
zandoval is offline
Reply
Old 01-13-11 | 01:34 AM
old's'cool's Avatar
curmudgineer
Bikes: 2 many 2 fit here
Not sure what to make of that statement...
A. I've never heard of a 1960 Covair
B. I've heard of a 1960 Corvair, but I wasn't aware that any had multiple carbs (not that I'm any authority).
old's'cool is offline
Reply
Old 01-13-11 | 01:45 AM
gaucho777's Avatar
15 Anniversary
Bikes: 72 Cilo Pacer, 72 Gitane GT, 72 Peugeot PX10, 73 Speedwell Ti,l, 75 Peugeot PR-10L, 80 Colnago Super, 81 Zinn, 85 ALAN Cross, 85 De Rosa Pro, 86 Look 753, 86 Look KG86, 89 Parkpre Team, 90 Parkpre Team MTB, 90 Merlin
Originally Posted by T-Mar
Axle position in the dropout affects the following characteristics...
T-Mar, thanks for this clear and very informative reply.
-Randy
'72 Cilo Pacer (x2) • '72 Peugeot PX10 • ‘72 Gitane Gran Tourisme • '73 Speedwell Ti • '74 Motobecane Grand Jubile • '74 Peugeot UE-8 • ‘80 Colnago Super • ‘81 Univega Super Special • ‘82 Zinn • ‘84ish Mystery Custom • '85 A.L.A.N Cyclocross • '85 De Rosa Pro • '86 Look Equipe 753 • '86 Look KG86 • '89 Parkpre Team Road • '90 Parkpre Team MTB • '90 Merlin Ti
Avatar photo courtesy of jeffveloart.com, contact: contact: jeffnil8 (at) gmail.com.
gaucho777 is offline
Reply
Old 01-13-11 | 04:02 AM
Road Fan's Avatar
20 Anniversary
Re B: as soon as you have two carburetors in a non-progressive arrangement, you have a balancing problem. Given the length of manifold run, I'd not be surprised if they used one carb per bank. Some of the similar VWs used twins (mid-70s Buses). With say, four carbs, it just gets more fun.
Road Fan is offline
Reply
Old 01-13-11 | 06:55 AM
15 Anniversary
Where might that be purchased or what is the correct name I am looking for?
seypat is offline
Reply
Old 01-13-11 | 07:07 AM
SJX426's Avatar
15 Anniversary
One source is:
https://store.velo-orange.com/index.p...ent-screw.html
SJX426 is offline
Reply
