Cable Attachment Point on Shimano 600 FD?
Bikes: 1997 Specialized M2Pro
I'm replacing the shift cable on my M2 Pro Specialized that has a Shimano 600 FD.
The old cable was attached on the top left side of the bolt, however, there seems to be a clear cable guide groove on the lower right side.
Which is right?
Which is right?
Quoted: 1438 Post(s)
Liked 1,092 Times
TromboneAl: If something is working my preference is not to change it. "Never Fix A Running Piece."
Don from Austin Texas
Bikes: Schwinn S25 "department store crap" FS MTB, home-made CF 26" hybrid, CF road bike with straight bar, various wierd frankenbikes
Quoted: 11 Post(s)
Don in Austin
Quoted: 2026 Post(s)
Liked 1,096 Times
Quoted: 1529 Post(s)
Liked 718 Times
IME the cable is meant to pass over the bolt, as in the picture.
Perhaps the groove is either for changing the derailleur's ratio for some unclear purpose, or to assist with routing the cable as I do on all FDs - all the way around the bolt for tidiness.
But the way that groove sits, following it would mean a loop above the bolt, which isn't tidy, so I guess the former.
Just do it like this for the win ; )
Liked 6 Times
That model was unusual, it had two grooves to accomodate both STI and downtube shifters. If you're using downtube shifters or bar-cons, use the routing shown in your photo. If you're using STI, use the other groove.
Bikes: Raleigh Companion, Nashbar Touring, Novara DiVano, Trek FX 7.1, Giant Upland
Quoted: 22 Post(s)
Isn't one side for Dura-Ace shifters and the other side for all other shifters?
Bikes: 2013 Specialized Roubaix Expert, 1987 Centurion Ironman Expert
Oooh if we could get a definitive answer that'd be awesome because I'm using downtube with these right now, but will be getting the STI levers soon to upgrade.
Liked 6 Times
Bottom line, it has two different actuation ratios. So if you wire it one way and the FD doesn't move outboard far enough to center up on the big chainring when you shift, then you need to wire it the other way And vice versa.
I have STI shifters. I wired it the same way that it was, and it works fine. Thanks for the help.
Quoted: 443 Post(s)
Liked 27 Times
I have bar end shifters and mine is routed the same way as yours. It works, so I'm going to follow dsbrantjr's advice leave it alone. It would be nice to have a definitive answer, though.
Liked 6 Times
I rummaged among our old Shimano tech manuals, but they don't go back quite far enough to cover that version. With non-indexed shifters, there's really no "wrong" way as long as your shifter's not running out of travel before reaching the big ring.
Liked 6 Times
Update: for those interested in this bit of trivia, the lower groove does seem to be the right one for STI. Had a bike in today needing shifter flush/lube, and it had one of these that needed its cable routing switched in the process. Working better now
lineinthewater
Bicycle Mechanics
13
02-01-13 09:51 AM
