Split top tube design- yea or nay?
Thunder Whisperer
Bikes: '06 Kona Smoke
Quoted: 275 Post(s)
Liked 6 Times
First post here in this forum, and probably only thread I'll participate in. Thinking about getting a Giant Via 2*. It's a cro-mo frame with a split top tube. From a structural integrity point of view, is this design something I should be wary of long term?
*I intentionally linked to the Via 1 model, due to it having an alternate view that shows the split tube.
Community guidelines
Decrepit Member
The top tube is under compression when riding, and that tubing looks awfully small to me even though there are two tubes. I'm not sure what purpose the split top tube serves.
Randomhead
Liked 3,706 Times
there is nothing wrong with the design. You could make the argument that it doesn't use the material as efficiently as a single top tube, but that probably doesn't matter in this case. Was there a small framebuilder that made a bike like this so the big companies could all copy it? Trek also has a bike like this now.
Thunder Whisperer
Quoted: 275 Post(s)
Liked 6 Times
Randomhead
Liked 3,706 Times
My LBS reports that the Earl has been selling well. The nice thing about the split top tube on that bike is that there is a u-lock mount.
Bikes: Raleigh Companion, Nashbar Touring, Novara DiVano, Trek FX 7.1, Giant Upland
Quoted: 22 Post(s)
You must be referring to the Earl? I think that I like the geo on the Earl better than that Giant. I've been toying with the idea of going SS...
Decrepit Member
Randomhead
Liked 3,706 Times
I'm trying to figure out how the Via has a cleaner seat cluster than the Earl. The only significant difference I see is that the Earl has a brazed on binder bolt.
Decrepit Member
That's what I get for not looking at the Earl link.
Found a light thin Mixte frame's 2 tubes being thin wall and small diameter, Noodly. I could twist the head-tube and move the bars
and see the wheel move sideways .
I built up a loaded touring frame around a bent twin tube that comprised the rear triangle and top tubes.
They are 3/4" ..049" wall tube , Mandrel bent twice, 4130
Tig to BB shell , brazed to seat tube,
welded gusset behind the head tube
the tubes plugged solid and attached to the sides of the head tube by welding them ..
Human Powered Machines in Eugene was the shop I got to help building it ,
and a stainless welder in Killarney Eire, whose main trade was stainless A/C duct work
when the design sorted out some weak spots , the gussets were added there.
the joint was brazed on a hollow tube, originally ..
Now it's a solid working design.
I can put my pump in between the top tubes,
so It doesn't pop off when I lift the bike..
The earl looks like a size larger on the tubing. Cheapness wise dropping 3 butted tubes sounds like a win. When it won't be stronger, is if any load bends the tube up or down like a fall or denting on a parking meter. That axis is sacrificed, which is probably ok in the use.
You gonna eat that?
I have a bike with a similar design that was built in 1960, had the tar ridden out of it by a paperboy. When it got to me, the rims were trashed, the cranks were bent, but the frame is fine. I don't think it's a concern.
Double top tubes always remind me of the Torker BMX frame (similar to this one) that I rode in the early 80s. When I was a kid, I loved the double top tube design because it looked different and it served as a platform to stand on. I doubt many people are going be bike surfing on the Trek Earl or Giant Via, but I do think that aesthetics are the primary reason for both of those designs. They are just trying to make a simple steel city bike stand apart from the competitors.
You gonna eat that?
I agree that generally double tubes are less efficient. It seems you can have similar stiffness because of the triangulation (provided you have adequately sized tubes; the 1/2 tubes found in mixtes indeed are too small) but it'll be at the expense of extra weight and complicated fabrication. But a proper design is fine. For instance it seems having 2x 3/4 tubes instead of a single 1-1/8 DT is stronger (that's from my bicycle design book from 1896).
You gonna eat that?
RunningBulldog
Framebuilders
21
08-23-13 06:10 PM
