French Threaded Crank
Old 02-17-11 | 08:04 AM
-holiday76's Avatar
No one cares
15 Anniversary
A while ago I picked up a Stronglight 93. It's a beauty. Well, it was marked as english threaded. I recently put it on a bike.
It's french threaded.
hence my ISO posts for french threaded pedals.
So, I think I can have the threads retapped to english since Frenchy threads are smaller.
It would exponentially open up my pedal options. Not to mention if I use this bike for a brevet (which I most likely will), I'll probably throw spd's on it. I'd like to be able to do that without changing the beautiful crank out.
In fact I don't even have a puller for this crank yet.
So, any opinions on re-tapping? I'm not sure how I feel about modifying an original piece like this, even though it's most definitely the practical answer.
What would you folks do? It's only original once or just retap it and be done with it?
I have some bikes.
-holiday76 is offline
Reply
Old 02-17-11 | 08:07 AM
mudboy's Avatar
Bikes: Ruckelshaus Randonneur, Specialized Allez (early 90's, steel), Ruckelshaus Path Bomber currently being built
Retap and be done with it. Even better, retap and helicoil, the threads will hold better.
mudboy is offline
Reply
Old 02-17-11 | 08:10 AM
Grand Bois's Avatar
All of mine are retapped. Helicoil? Ridiculous!
Grand Bois is offline
Reply
Old 02-17-11 | 08:13 AM
ColonelJLloyd's Avatar
The crank was marked as English threaded or the auction was marked as such?
I ran into the same issue recently. I was going to tap my 93 but had the same reservations. I began looking for pedals and found a couple pairs of Lyotard rat traps. I really like them with clips and straps. Now I have two French threaded 93s and no real desire to tap them to 9/16" x 20.
The Stronglight 93 was not a rare crankset by any means so far as I know. If you're a dedicated SPD guy then I don't see an issue having them tapped or you could just continue to look for one that already has English threads.
ColonelJLloyd is offline
Reply
Old 02-17-11 | 08:20 AM
-holiday76's Avatar
No one cares
15 Anniversary
i was actually hoping you'd chime in, and I was expecting you to yell at me for considering the retap
the auction was marked as english thread. That, or even more likely I didnt read it entirely and just bid at the last minute...
I WAS a dedicated spd guy, but I've started riding platforms on some bikes and it's starting to grow on me. That said platforms are ok for a short ride, but I don't think I'll be switching over for longer stuff.
I guess I'll see about having Curtis at Via retap..it's the last thing keeping me from finishing this bike and I want to ride it!
I have some bikes.
Reply
Old 02-17-11 | 08:22 AM
The Carlton? The little 4M adjuster should be delilvered to you today.
Reply
Old 02-17-11 | 08:23 AM
-holiday76's Avatar
No one cares
15 Anniversary
i'm not telling.
I have some bikes.
Reply
Old 02-17-11 | 08:24 AM
Sheldon Brown Memorial - Titanium
20 Anniversary
Community Builder
Tap 'em! I bought a set of the Park pedal taps a while back, and they've been invaluable.
Neal
nlerner is offline
Reply
i'm not telling.
I suppose that's better than telling and NOT showing.
Reply
Old 02-17-11 | 08:29 AM
-holiday76's Avatar
No one cares
15 Anniversary
soon enough. two more minor details and the pics will be flowin'. I've been trying so hard for the past few months not to show anything until I'm done on the 3 builds I have going on.
I have some bikes.
Reply
Old 02-17-11 | 08:30 AM
-holiday76's Avatar
No one cares
15 Anniversary
Neal
that would be these right?
https://www.treefortbikes.com/product...l-Tap-Set.html
maybe I should just get a set since I'll probably spend half of that having someone else do it.
I have some bikes.
Reply
Old 02-17-11 | 08:31 AM
rhm's Avatar
rhm
multimodal commuter
You could just see if anyone has a set you can borrow. Come to think of it, I have a set you can borrow. Problem solved.
rhm is offline
Reply
Old 02-17-11 | 08:32 AM
20 Anniversary
Community Builder
Yup, those are they. You'll also make your money back with what you save buying eBay cranksets that *are* marked French threaded. They usually go for significantly less than English threaded.
Neal
nlerner is offline
Reply
Old 02-17-11 | 08:33 AM
Neal
Shhhh! Shush it!
Reply
Old 02-17-11 | 08:34 AM
20 Anniversary
Community Builder
Shhhh! Shush it!
It did occur to me that I just gave away a C&V state secret. Well, not anymore.
Neal
nlerner is offline
Reply
-holiday76's Avatar
No one cares
15 Anniversary
Neal
that's probably why I scored the one I have so cheap, come to think of it...
I have some bikes.
Reply
Old 02-17-11 | 08:55 AM
Grand Bois's Avatar
The T handle for the taps may cost you almost as much as the taps. I used an adjustable wrench to turn the taps until I broke down and bought one. Very little material is removed and the taps go through the aluminum like butter. It's not even necessary to remove the crank from the bike.
Reply
Old 02-17-11 | 09:08 AM
Noah Scape's Avatar
can't member
20 Anniversary
...you save buying eBay cranksets that *are* marked French threaded. They usually go for significantly less than English threaded.
Neal
Conversely, it seems to make French threaded pedals more valuable. I sold some Frenchy threaded Lyotard 45CAs on ebay last summer and got twice what I thought I'd get.
I've retapped a dozen or so Frenchy threaded cranks... I wouldn't hesitate in recommending it.
Noah Scape is offline
Reply
Old 02-17-11 | 09:11 AM
Zaphod Beeblebrox's Avatar
PanGalacticGargleBlaster
Bikes: Upright and Recumbent....too many to list, mostly Vintage.
LBS did my LA Cyclotouriste's for 10 bux.
after seeing how well it worked I bought a Tap and Die set from lowes that included a handle, the taps and the Dies to cut threads on a bolt. Just used em last night to thread a hole for a fender mount. Infinitely useful!
--Don't Panic.
Zaphod Beeblebrox is offline
Reply
Old 02-17-11 | 09:49 AM
20 Anniversary
Community Builder
I also used to use a small crescent wrench to turn the tap, but then I got a real handle at a used tool/junk store. Very old school and cost $1.
Neal
nlerner is offline
Reply
Old 02-17-11 | 10:24 AM
randyjawa's Avatar
Titanium Club Membership
15 Anniversary
Most bike shops will have a set of taps in the drawer, somewhere. Chances are they will be a great help if you approach them. And, for what it is worth, I too have purchased a set of taps, keeping in mind that you will need the proper taps, both right and left hand thread.
As for the helicoil idea - not!
randyjawa is offline
Reply
Old 02-17-11 | 11:08 AM
JohnDThompson's Avatar
Old fart
20 Anniversary
Community Builder
Are the arms marked as English thread? Look on the back of the arms -- French thread will have "14 - 125" and English will have "9/16 - 20"
If they're marked English, chances are they just need to be chased out. If they're French, you may as well tap them anyway to allow a wider selection of pedals.
JohnDThompson is offline
Reply
Old 02-20-11 | 06:42 PM
-holiday76's Avatar
No one cares
15 Anniversary
thanks rhm for the taps. they worked great! I now can put my carbon fiber spd's on my '68 Carlton. Should look great.
I have some bikes.
Reply
Old 02-20-11 | 06:47 PM
I'd like to see a picture of this...
DRietz is offline
Reply
Old 02-20-11 | 07:25 PM
-holiday76's Avatar
No one cares
15 Anniversary
soon, very soon.
I have some bikes.
Reply
