Shimano Alfine 11 speed IGH -- Strike Two!!
Don from Austin Texas
Bikes: Schwinn S25 "department store crap" FS MTB, home-made CF 26" hybrid, CF road bike with straight bar, various wierd frankenbikes
Quoted: 11 Post(s)
I built a really nice custom bike around this hub. After two weeks something came apart inside it and the shifter would no longer go into 9th, 10th or 11th gear. I paid a very good LBS to pull the wheel back apart so I could return the hub -- wheel building, frame fabrication and powdercoating are the only aspects of building a bike I do not do myself at this time. They sent a replacement hub which shifted weirdly from day one. A totally clueless and condescending d--head at Shimano tried to blame it on my inability to adjust the shifter properly. There is only one adjustment and its easy -- you line up two marks in 6th gear. But I was way ahead of that and tested it to either side of the marks -- no dice. 11th gear is actually something like 7th until or if something finally engages three blocks later -- etc. and etc. I finally got through to a much better rep at Shimano tech support who said there was obviously something wrong with the hub and it should work straight out of the box -- to which I agree. The bike is at the LBS and they have all the paperwork including the name of the better contact person at Shimano to, presumably, fix it under warranty.
We shall see how it plays out.
I am not exactly ready to take my custom bike on a long road trip any time soon which sucks.
Don in Austin
Don in Austin
Quoted: 11 Post(s)
Don in Austin
Quoted: 11 Post(s)
So is anybody else running one of these? Good or bad?
Don in Austin
Don in Austin
Senior member
Quoted: 943 Post(s)
Liked 659 Times
Well, this is a bummer.I had high expectations of this hub, but yours is not the first horror story I've read.
Sure hope they get the wrinkles ironed out.
Bikes: Vassago Moosknuckle Ti 29+ XTR, 90's Merckx Corsa-01 9sp Record, PROJECT: 1954 Frejus SuperCorsa
Quoted: 174 Post(s)
Liked 157 Times
Agreed - bummer to hear it.
I have had very high hopes for this hub as an alternative to Rohlhoff, based on my own (very good) experiences with the Nexus and Alfine hubs.
Keep us posted.
Keep us posted.
Bicycle Repair Man !!!
This seems to be a similar situation to when Shimano released the Nexus 8 which has not been the most reliable hub either... a lot of that stems from Shimano not thinking that the hub needed an overhaul after breaking in and more regular service... the seals on the original Nexus hubs were also not as good as later models.
I have had to deal with quite a few Nexus failures with the 7 and 8 speed Nexus models.
If more problems manifest with the much anticipated 11 speed, Shimano should recall them and address any design issues and not use customers to do their beta testing for them... since many people want to use these for touring having a hub failure could leave you stranded for a good long while and ruin what was supposed to be a pleasant journey.
Quoted: 11 Post(s)
Don in Austin
I was looking at the 11 speed to fit to my folding touring bike and if I found it worthy and would look at fitting in to some our custom frames if there was a demand and for retro fits.
Shimano should send me an 11 speed to demo and test... I ride 400 - 500 km a week in the summer and would ride that thing as hard as anyone.
I have retro fitted several Shimano equipped bikes with new SA hubs after their original hubs failed... folks would rather have a bulletproof five speed with good range and easier serviceability rather than an 8 speed that was not reliable and much harder to service.
Other than the used '03 one I had to get external seals upgraded from leaking nylon to normal neoprene.
my Rohloff experience has been positive..
Quoted: 11 Post(s)
Quoted: 11 Post(s)
Quoted: 11 Post(s)
Nowhere in the instructions does Shimano warn you never to shift while pedaling. Or, if they do, could you give me a link? Shifting while pedaling is out about the ONLY thing that the first Shimano rep didn't try to blame my troubles on.
The entire bike with the second hub is a LBS where an extremely experienced senior tech agrees the hub -- without even 3 miles on it -- is bad . He is getting in touch with Shimano today to work out warranty arrangements.
Don in Austin
Bikes: -1973 Motobecane Mirage -197? Velosolex L'Etoile -'71 Raleigh Super Course
This is a total letdown for me, and I'm sorry to hear about it. I'm doubly sorry to hear that Shimano is using their customers for R&D testing.
this would have never happened with SunTour!!
afraid of whales
Quoted: 347 Post(s)
Liked 5 Times
Every IGH needs to have the torque removed to shift. I know you're very angry but the fact remains that lots of people are riding these hubs with no failures. You can give up or look to people that ride these kind of hubs for tens of thousands of miles trouble free.
Quoted: 11 Post(s)
The replacement one was checked by riding VERY gently in the parking lot next door to my shop and did not shift properly from the beginning.
And there have been other reports of problems with 11 gear.
We shall see.
Don in Austin
Quoted: 5793 Post(s)
Liked 2,594 Times
I'm a big believer in IGH for many applications and would like to see better acceptance for IGH in the USA market mix.
But, I think Shimano is shooting itself in the foot by trying to stuff too much into the can. IGH hubs make the most sense for applications where not too many gears are required, like city bikes, commuters, and beach type applications. These don't need many gear choices, and gain the most benefit from the simplicity, cleanliness and comparative bulletproof nature of IGH.
Those needing or wanting more gearing for mixed terrain riding are probably best off with derailleur systems.
Using IGH for those applications works against it's strengths. IGH also becomes less efficient under high load than derailleur systems, making it less suited for hard riding.
If I were Shimano, or SA Taiwan, I wouldn't keep trying to stuff more gears into the can, but would focus on simplicity, lower weight, and gear ranges more suited to the best target market.
I, for one, find the typical 3/4, 1, 4/3 gearing of AW hubs too wide for my city needs and would kill to have an IGH with maybe 5 speeds in 10% steps. I'm currently using vintage narrow range SA hubs, but these won't last forever.
FB
Chain-L site
FB
Chain-L site
Palmer
Quoted: 1671 Post(s)
Liked 1,828 Times
The subject line of the thread is "Alfine 11", which reached retail just four months ago. So far posters have reported problems with this hub on mtbr.com, hubstripping, this forum and on the yahoo IGH group.
Palmer
Liked 1,828 Times
For the record, in the last two years Sturmey-Archer has introduced new 2-speed models, a new 3-speed design, a fixed gear 3-speed model and a new 5-speed design.
Would you rough someone up for a narrow-OLD six speed w/ 13% steps? [There's one inside the S-A XRF8(W).]
Liked 2,594 Times
I never rough anybody up, it leaves witnesses. As I said, I'm riding a number of vintage SA hubs, so I'm OK. Having reached the age where I no longer buy green bananas I expect my current stock to outlast me, so I'll pass. I just think that Shimano is missing opportunities targeting an audience least disposed to stay with IGH.
FB
Chain-L site
FB
Chain-L site
Quoted: 11 Post(s)
This is all a bit depressing, Shimano seems to be shoving stuff out before it's ready. Ah well, I had already decided to go Rohloff anyway, as long as I get a new job before my savings disappear.
