Installing tight tires without tools: my method
Old 04-19-11 | 06:30 PM
Puget Pounder's Avatar
Wookie Jesus inspires me.
We've all put holes in tubes trying to tires on a rim by using a lever (maybe it's just me). Not all of us own a tire jack or want to buy one.
My solution: Use your heel.
There is that last little section of the bead that you want back on and it's suuuuper tight. You can't do it by hand, but you can use your heel.
Take the wheel and place it on the edge of something raised off the ground (that won't scratch your rim). Step on the bead that is off the rim with your heel and push the rim down on the other end. Voila.
Maybe other people are way awesome and think that post is a no-duh thread, but I was pretty amazed at how easy this is. I got pretty frustrated the other day when I put holes in 3 new tubes trying to use a lever...
Puget Pounder is offline
Reply
Old 04-19-11 | 08:16 PM
auchencrow's Avatar
That's a very useful thing to know, Puget Pounder. (Why didn't I think of it?) Thanks !
- Auchen
auchencrow is offline
Reply
Old 04-19-11 | 08:57 PM
Used to be Conspiratemus
15 Anniversary
Thanks for that suggestion. I never would have thought of it.
conspiratemus1 is offline
Reply
Old 04-19-11 | 09:01 PM
worth a try
RobbieTunes is offline
Reply
Old 04-19-11 | 09:16 PM
15 Anniversary
Tried to put a Pasela on a CR18 rim last night.
Awful experience.
I'll be happy to try this after I buy some more tubes.
Talk about tube carnage!
gomango is offline
Reply
Old 04-19-11 | 09:32 PM
Originally Posted by Old Fat Guy
I guess the OP has never tried to change a flat on the road where the rim is a Campy.
Good luck on a new tire. A quick stick/speed lever is the best/easiest solution. Or gorilla hands.
Not quite following you here.
Good luck on a new tire? I did this on an A17 and a brand new Vittoria Rando the other day for friend after breaking 2 levers trying to get the last piece on. Works just fine.
Reply
Old 04-19-11 | 09:34 PM
15 Anniversary
I haven't broken a qwikstick yet.
Problem is, I have one, and it's never where I am when I need it.
gomango is offline
Reply
Old 04-19-11 | 09:35 PM
southpawboston's Avatar
15 Anniversary
Thanks, I think I might try your tip!
I had the toughest time mounting Grand Bois Hetres on Synergy rims, which included breaking a tire lever, blurting repeated profanities, stamping my feet and pouting. The same tires mounted without tools, or effort, onto VO Diagonale rims.
southpawboston is offline
Reply
Old 04-19-11 | 10:17 PM
unworthy1's Avatar
Stop reading my posts!
20 Anniversary
Community Builder
I don't think I'm way awesome. I need to see a picture, cause I can't follow this from your description (and I'm SURE that I will use this tip in future).
unworthy1 is offline
Reply
Old 04-19-11 | 10:20 PM
Yeah, pictures would help me too.
DRietz is offline
Reply
Old 04-19-11 | 10:43 PM
Bikes: 2013 Specialized Roubaix Expert, 1987 Centurion Ironman Expert
Video is even better! =D
Kuotient is offline
Reply
Old 04-19-11 | 11:02 PM
Hope you can tell what's going on. I am pushing down with my hand opposite to the side of my heel on the wheel. Eventually, the wheel will go down past the horizontal level and the bead should slip right on the rim as long as you sandwich the bead between your heel and the rim. The reason why it need to be a raised surface is to use the edge as a fulcrum to get some leverage on the stubborn bead.
Stairs work great for this!
File Type: jpg
Reply
Old 04-19-11 | 11:04 PM
I'll consider a video if people are still confused/I'm not too lazy.
Reply
Old 04-20-11 | 04:36 AM
Michael Angelo's Avatar
Titanium Club Membership
15 Anniversary
Bikes: Treks (USA), Schwinn Paramount, Schwinn letour,Raleigh Team Professional, Gazelle GoldLine Racing, 2 Super Mondias, Carlton Professional.
That makes perfect sense. If you think about it, that's very similar to the way a car tire goes on. You have to push the opposing tire bead in the rim cavity so the tire bead 180 degrees can be slipped over the rim. I'll have to try this next time.
Michael Angelo is offline
Reply
Old 04-20-11 | 04:47 AM
Looks like it's going to hurt if your foot slips. I use Ronnie John's harden the **** up and use your hands method.
Dan The Man is offline
Reply
Old 04-20-11 | 05:40 AM
Chris_in_Miami's Avatar
missing in action
It won't hurt a bit if you HTFU.
Chris_in_Miami is offline
Reply
Old 04-20-11 | 05:45 AM
norskagent's Avatar
car dodger
20 Anniversary
I can usually get the tire on with my hands, but often need a lever or two to remove the first section of tire when I start fixing a flat.
1989 Schwinn Paramount OS
1980 Mclean/Silk Hope Sport Touring
1983 Bianchi pista
1976 Fuji Feather track
1979 raleigh track
"I've consulted my sources and I'm pretty sure your derailleur does not exist"
norskagent is offline
Reply
Old 04-20-11 | 06:01 AM
rhm's Avatar
rhm
multimodal commuter
Awful experience.
All right, if I get you for Secret Santa this year, I'm getting you a patch kit!
rhm is offline
Reply
Old 04-20-11 | 06:09 AM
15 Anniversary
Thank you.
At 52 years of age, one would think I could figure this stuff out.
But my mom always said I better make my living talking, as I wasn't able to open a door without a little bit of help growing up.
I still can't believe I managed to install the windows in our home. None of my friends can either.
gomango is offline
Reply
Old 04-20-11 | 06:12 AM
rootboy's Avatar
If you do a video, would you consider using a nineteen old woman with nice legs? Bare feet? Thanks.
rootboy is offline
Reply
Old 04-20-11 | 06:27 AM
divineAndbright's Avatar
I've developed powerful hands after years of frustrating tires; the muscles on my hands and fingers have their own muscles. |But I'll still watch the video though cause they are always funny.
divineAndbright is offline
Reply
Old 04-20-11 | 07:43 AM
triplebutted's Avatar
Bikes: Lemond, Gios, Fuji, Trek, too many to write
Brilliant!!! Thanks
triplebutted is offline
Reply
Old 04-20-11 | 08:10 AM
rhm's Avatar
rhm
multimodal commuter
Interesting idea, indeed! I haven't tried it yet, so maybe this is a stupid question... but does it matter what kind of shoes you're wearing?
rhm is offline
Reply
Old 04-20-11 | 08:42 AM
khatfull's Avatar
FBoD Member at Large
Probably anything but this?
khatfull is offline
Reply
Old 04-20-11 | 10:31 AM
Not really. Maybe something that isn't heavily treaded so you don't tear them up? I'd be worried more about the shoe.
Reply
