intercom - cheap - prdouct review
Nigel
Bikes: 1980s and 1990s steel: CyclePro, Nishiki, Schwinn, SR, Trek........
Quoted: 384 Post(s)
Liked 6 Times
We got this a few days ago, and used on yesterday's ride: https://www.amazon.com/GSI-Waterproof...ef=pd_sbs_hg_1 .
It uses a pair of AAA batteries, and comes with a couple of ear buds with microphone booms.
The good:
* the box is small, we clipped it to the back of my shirt collar - at the label. Good location so that Diane could plug in/out when she got on/off, and I did not even feel it.
* we could hear each other, even along the road with heavy traffic.
The not so good:
* the ear bud mic combo is intended to be velcro'd inside an full coverage motorcyle helmet - doesn't work so well on a bike.
* the hook up (single three conductor 3.5mm plug) is different from our computer (Skype) head sets.
We have ordered a couple of different kinds of headsets to try.
You can also attach a CD/MP3/whatever to it for both people to listen to. We probably will never use that feature.
Bottom line: great price, works well, but plan on spending some more money on different headsets. Even then, it will be a sub-$40- communications solution - a great bargin in my book.
The good:
The not so good:
Bikes: 2013 Co-Motion Robusta, Litespeed Classic,Litespeed Bella
Kool...... keep us informed as to what "headsets" you try and work better with this set up. I might just give it a try!! Thanks
Nigel
Quoted: 384 Post(s)
Liked 6 Times
the two alternative headsets are problomatic. The Cellet handsfree comes with a 3.5mm TRRS plug - the box has a 3.5mm TRS - the ear peice speaker works great, the mic not. The Jabra C510 comes with a 2.5mm TRS plug and an adapter to a 3.5mm TRRS. Again, ear piece speaker works great, but no mike. Bought a 2.5mm TRS to 3.5mm TRS from Radio Shack - still no mic.
https://www.amazon.com/Cellet-211555-...9642452&sr=1-5
https://www.amazon.com/Jabra-C510-Cor...642483&sr=1-44
Next step is to make an adapter where I can try different circuits or take one of the nicer ones apart to adapt the microphone. I am not looking forward to either option. Next trials will be in August when I get back from a long business trip.
Quoted: 2495 Post(s)
Liked 739 Times
What I would do is work on the problem of getting the OEM ear bud/mic to work with a regular bike helmet. I don't think it is the circuit if you are getting audio. It is more likely some kind of impedance mismatch with the microphone. Modifying an expensive headset/mic IMO defeats the kool factor as there are probably existing tandem cyclist talk units that work, out of the box, for an equivalent amount of money.
H
H
Nigel
Quoted: 384 Post(s)
Liked 6 Times
So far, I have spent $15- on the original box, another $20- on different headsets/earsets and an adapter for $4 from Radio Shack.
After discussions with the Rear Admiral; I am going to mechanically modify one of the new earsets to hold the original earbud/mic for her. For me, I found that the original one works pretty well with my helmet.
Nigel
Quoted: 384 Post(s)
Liked 6 Times
After some issues; I took it apart, found a cold solder joint, reflowed, now works great all the time.
josephjhaney
18
10-20-17 11:41 PM
