What to check when buying from bikes direct?
Old 08-30-11 | 04:16 PM
Jaytron's Avatar
Brown Bear, Sqrl Hunter
Bikes: CAAD 10 4, Dolan DF4, Fuji Track Classic
Hell yeah, the title rhymes.
But seriously. One of my friends is getting her bike in from BD on Thursday, what should we check on the bike? I have the following:
BB greased/tightened
Chainring bolts
Lockring
Anything else? Or should we just tear it apart and rebuild it?
Jaytron is offline
Reply
Old 08-30-11 | 04:20 PM
Bikes: Windsor Timeline , Cannondale Synapse 105
Probably going to have to do a lil truing of the wheels. Grease pedals and check all the bolts.
boymonkey is offline
Reply
Old 08-30-11 | 04:28 PM
LesterOfPuppets's Avatar
The space coyote lied.
15 Anniversary
Community Builder
Community Influencer
Bikes: everywhere
From the stories I've heard, strip it down to bare frame and rebuild. I don't think I'd go that far though, cuz I'm lazy.
LesterOfPuppets is offline
Reply
Old 08-30-11 | 04:29 PM
Jaytron's Avatar
So am I, but I also don't want her bike asploding on her. Haha If a full teardown is needed I suppose I can do that.
Jaytron is offline
Reply
Old 08-30-11 | 04:52 PM
hairnet's Avatar
Fresh Garbage
Bikes: N+1
This.
The BB will need to be torqued down, hubs will need to be greased and set correctly,wheels will need to be tensioned and trued. grease various other things with threads
hairnet is offline
Reply
Old 08-30-11 | 04:57 PM
Cyclomania's Avatar
Bikes: American Eagle, Nishiki.Semipro. Great bike.
Originally Posted by hairnet
This.
This probably holds true for any bike you buy, from LBS or anywhere else for that matter!!!
Cyclomania is offline
Reply
Old 08-30-11 | 05:04 PM
TejanoTrackie's Avatar
Veteran Racer
Titanium Club Membership
15 Anniversary
Bikes: 34 frames + 80 wheels
It depends. Which model is she buying ? For example I have a Kilo WT with sealed cartridge bearing hubs that require no maintenance or adjustment. I also have a Moto Mesenger with loose bearing hubs that needed adjustment and will need periodic cleaning and repacking with new grease. Also, the wheels on the Moto needed a lot more truing and tensioning than the Kilo. The cranks on the Kilo were pretty tight and only needed to be retightened a few times but the Moto needed about a dozen retightenings. The chainring bolts on the Kilo were tight from the git go, but those on the Moto were all loose. Then, there may be bad or ill fitting parts or even missing parts. The seat binder bolt on my Kilo was stripped and the stem and bar on my Moto were the wrong size. So, it needs to be thorougly checked, and remember to not force anything.
What, Me Worry? - Alfred E. Neuman
Originally Posted by Dcv
I'd like to think i have as much money as brains.
I see the light at the end of the tunnel, but the tunnel keeps getting longer - me
TejanoTrackie is offline
Reply
Old 08-30-11 | 05:07 PM
Veteran Racer
15 Anniversary
Any LBS that would require the buyer to do all this isn't worth buying from them.
Reply
Old 08-30-11 | 05:18 PM
Jaytron's Avatar
Windsor The Hour.
If I have to literally take the whole bike apart, I might as well have her take it to a shop
I don't have a truing stand nor do I know how to true wheels :\
Jaytron is offline
Reply
Old 08-30-11 | 05:22 PM
You might get lucky on the wheels. My dawes didn't need truing, but pretty much everything except the headset needed to be greased. Knowing how to true a wheel doesn't make it any more enjoyable from my experience. It's one of those things I'd rather just pay someone to do if its more than a few quarter turns out of true.
Verbose is offline
Reply
Old 08-30-11 | 05:31 PM
hairnet's Avatar
Fresh Garbage
Bikes: N+1
that is generally recommended. I wonder how the shop will look at you/the bike
hairnet is offline
Reply
Old 08-30-11 | 05:41 PM
yoked
Like this:
homebrewk is offline
Reply
Old 08-30-11 | 06:45 PM
George Krpan
I've bought two bikes from BD, Motobecane Phantom Uno and SE Stout 29er. Both are good bikes, BTW.
The Uno has cartridge bearing hubs so no worries there but the cones on the wheels of the Stout were tight.
I automatically put the wheels on the truing stand no matter where I buy a bike.
Check the crank and chainring bolts, it only takes minutes, if there's no creaking I wouldn't go any further.
GeoKrpan is offline
Reply
Old 08-30-11 | 07:13 PM
Scrodzilla's Avatar
Your cog is slipping.
Sheldon Brown Memorial - Titanium
15 Anniversary
Bikes: EAI Bareknuckle
All machine-built wheels need truing/tensioning. ALL of them.
Scrodzilla is offline
Reply
Old 08-30-11 | 07:45 PM
I haven't touched the BB/cranks (chainring bolts were/are tight) of my Kilo. Rear wheel got trued but front is still fine.
But what do I know.
hamish5178 is offline
Reply
Old 08-30-11 | 08:31 PM
yoked
Originally Posted by hamish5178
But what do I know.
Nothing.
Reply
Old 08-30-11 | 08:38 PM
Scrodzilla's Avatar
15 Anniversary
hahaha
Reply
Old 08-30-11 | 09:48 PM
****, what am I doing in college**********??
Reply
Old 08-31-11 | 02:29 AM
Nash Deluxe's Avatar
definitely check the cones on your hubs, mine were pretty tight out of the box and the wheels weren't spinning smoothly. other than that, you should be greasing and checking everything that you assemble on the bike anyway. the cog/lockring on my kilo were already greased and properly tightened when the bike arrived.
besides truing the wheels, it really only takes about 30 minutes to setup and tune everything and cut brake cables/housing.
Nash Deluxe is offline
Reply
Old 08-31-11 | 10:13 AM
yoked
Partying, riding
Reply
Old 08-31-11 | 10:49 AM
Bent Life's Avatar
Originally Posted by homebrewk
Like this:
No exaggeration, especially around here (Austin). I can think of one shop out of about 5 that I went to with my Moto track from BD that didn't give me that look when I asked for their help. Then I was so touchy that by the time I got to that one good shop I basically just asked them for their advice and to borrow tools, even though they were receptive to actually helping me.
This is on my mind b/c of the recently revamped "go to your LBS" thread. If you live around here, I recommend you do not go, except maybe to Clown Dog bikes. And please, for the love of god, avoid Freewheeling Bikes on 24th and San Gabriel. They will treat you like the speckled turd you are ;0;0
Bent Life is offline
Reply
Old 08-31-11 | 10:58 AM
hadeone's Avatar
I'm in the same boat. I have a Windsor coming soon.
What type of grease should I to lube up all the parts during assembly?
Any write ups on how to check the cones on the hubs?
hadeone is offline
Reply
Old 08-31-11 | 11:01 AM
Jaytron's Avatar
or
Jaytron is offline
Reply
Old 08-31-11 | 11:08 AM
hadeone's Avatar
hadeone is offline
Reply
Old 08-31-11 | 03:44 PM
15 Anniversary
Community Builder
Bikes: everywhere
I use Valvoline. Used to serve it up with a plastic knife from 7-11 but went out and got a mini grease gun a couple years ago. I still use a plastic knife to fill the gun.
You can get both of these for just a buck or two over the cost of a tube of bike grease if you don't mind hitting auto parts store then the Harbor Freight.
Reply
