PSA: Winter Tire Inflation. pV = nRT Content
Old 11-21-11 | 12:32 AM
Oregon Southpaw's Avatar
Larger Chainring
Bikes: 1988 Schwinn Circuit. Bike-Boom-Puegeot. First "real bike" Trek 720 Hybrid in gross disrepair.
Or: use a tire gauge.
If you ride high-pressure tires in cold weather, make sure to drop a few PSI in them before you bring them back inside. I blew a tire today - not a tube the actual tire - and it was not a pleasant sound. I mean we're talking bad "bikes may never be allowed in the building ever again" bad
I stole the pressure*Volume = mu(number of moles of gas)*R(Universal gas constant) *Temperature(in Kelvin) from another similar thread, but long story short, bringing a bike in from a 1.5hr commute in 34* temps to a heated building can up the tubes inflation something like 15psi. Again, this is a PSA, particularly useful if you like having a bike anywhere near your workplace. Then again most y'all ride at 70psi and it doesn't matter!
Oregon Southpaw is offline
Reply
Old 11-21-11 | 04:13 AM
WNG's Avatar
WNG
Spin Forest! Spin!
Bikes: I used to have many. And I Will again.
It's official, you're a terrorist.
WNG is offline
Reply
Old 11-21-11 | 05:14 AM
LesterOfPuppets's Avatar
The space coyote lied.
15 Anniversary
Community Builder
Community Influencer
Bikes: everywhere
Maybe it's time to get some sewups!
170 psi rating should give you some breathing room
LesterOfPuppets is offline
Reply
Old 11-21-11 | 05:51 AM
pastorbobnlnh's Avatar
Freewheel Medic
Titanium Club Membership
Sheldon Brown Memorial - Titanium
20 Anniversary
The Doc checked my PSA back in September and all was good for another year.
I've never had this problem. In the winter I'll pump the tires to 110-120 psi, go for a ride in sub 20F, come home and park the bike in my heated basement.
But consider this thought experiment: Let's say my tires were 60F at full inflation, and 85% at 20F while riding. Wouldn't they return to something close to 100% after the ride when parked again in a 60F basement? Certainly they would not rebound to 115%.
Do you start out with your tires at 34F, inflate them to your desired PSI, ride the bike in 34F temps, and park in 70F? This would explain the increase in PSI and the explosive nature of your tires. Solution: Park your bike next to your bed at night.
Bob
pastorbobnlnh is offline
Reply
Old 11-21-11 | 09:06 AM
southpawboston's Avatar
15 Anniversary
Nitrogen and oxygen, the two gases that make up 99% of air, are ideal gases, and therefore they SHOULD follow the ideal gas law, PV=nRT, wherein T is the temperature expressed in kelvin.
According to the ideal gas law, a drop in temperature of 50 degrees should only cause a decrease in pressure of 10%. Conversely, an increase in temperature should only cause in an increase in pressure of 10%. So, if you pumped up your tires to 80psi at 0F, then brought your bike into your garage and allowed it to warm up to 50 degrees, the pressure should only increase to 88psi.
I suspect, however, that water vapor (which does not conform to the ideal gas law) in the air used to fill tires causes a more radical change in pressure as temps vary, especially when the fluctuation in temps crosses the free/thaw threshold. So, the best way to pump up tires is to use air with as low moisture content as possible. This will minimize temperature-related pressure changes.
southpawboston is offline
Reply
Old 11-21-11 | 09:50 AM
cudak888's Avatar
www.theheadbadge.com
20 Anniversary
Community Builder
Read = the sound of a gunshot.
Ask the landlord if he'd prefer to hear domestic violence and a real gunshot from his replacement tenants as opposed to the quite infrequent sound of a tire blowing off from his otherwise complacent, respectable, current occupant.
-Kurt
cudak888 is offline
Reply
Old 11-21-11 | 09:53 AM
tugrul's Avatar
You pump up your tire outside?
tugrul is offline
Reply
Old 11-21-11 | 10:06 AM
miamijim's Avatar
Sheldon Brown Memorial - Donating
20 Anniversary
3 words:
Hook
Bead
Rims
miamijim is offline
Reply
Old 11-21-11 | 10:11 AM
Pompiere's Avatar
20 Anniversary
Bikes: 1984 Miyata 310, 1986 Schwinn Sierra, 1987 Ross Mt. Hood, 1988 Schwinn LeTour, 1988 Trek 400T, 1981 Fuji S12-1977 Univega Grand Rally, S LTD, 1973 Sears Free Spirit 531, 197? FW Evans
Police: "Ma'am didn't you hear any gunshots?"
Neighbor: "Well I heard a noise, but I thought it was just that guy's bike tires again."
Seriously, the thumb rule for car tires is about a pound for every ten degrees. If you pump them up inside and then go outside, then they will have lower pressure in the cold and come back up when you come back inside. If you pump them up outside in the cold, then you would see the most effect from the thermal expansion. Unless you are testing the limits of the max sidewall numbers, there shouldn't be any issues. A lot of people go well past the max inflation numbers when mounting tires to get the bead to seat correctly.
Pompiere is offline
Reply
Old 11-21-11 | 10:24 AM
For an ideal gas, the ratio of the pressures is equal to the ratio of the temperatures (assuming the no volume change or adding/subtracting gas). So
P1 / P2 = T1 / T2
The temperatures HAVE TO BE IN KELVIN. It just doesn't work without the temps in kelvin. 32 degrees F = 0 degrees C = 273 K. 100 degrees F = 38 degrees C = 311 K. This would be one hell of a temperature swing, but would increase the pressure by just under 14%. So that 100 psi tire would go up to 110 psi. Honestly I don't see how the temperature-induced pressure change alone can cause a blow-out when sitting on the bike doesn't. Your butt in the seat has to add more than 14% to the pressure in the tires, even when the weight is spread out over the whole volume of the tire.
Either there is water in the tire and the vapor pressure of the water is changing things (also unlikely; change in vapor pressure is only 6.5 kPa (1 psi) over temp range above) or the bike warming up makes the rubber more pliant and/or the rims expand a touch and a not-quite-properly-installed tire can slip and cause a blow out.
stausty is offline
Reply
Old 11-21-11 | 10:34 AM
bbattle's Avatar
20 Anniversary
Bikes: 2014 Trek Domane 5.2, 1985 Pinarello Treviso, 1990 Gardin Shred, 2006 Bianchi San Jose
Thanks for bringing us the sanity of science, Stausty. This urban myth gets told so often it ought to be on Myth Busters(maybe it already has).
OP probably had something else wrong with his tire and tube.
bbattle is offline
Reply
Old 11-21-11 | 10:37 AM
Anonymoose's Avatar
I would think the friction of the tire rolling as you ride it should help maintain pressure slightly as well.
Anonymoose is offline
Reply
Old 11-21-11 | 10:55 AM
P1 / P2 = T1 / T2
Agree with the first part (although I believe everyone in the thread so far has been using absolute temperatures), but not with the last sentence. The only way having your butt on the seat will raise the pressure is by reducing the tire volume. But the volume is unchanged except in the immediate vicinity of the contact patch which only comprises a few percent of the tire circumference. And even in that few percent the volume change is pretty minor. The volume change (and therefore also the pressure change) from sitting down on the bike will be well under one percent - i.e. insignificant.
But the temperature-related changes in pressure, while larger, are still well within the safety margin of tires when inflated to their nominal maximum even in arctic temperatures and then brought inside a normally heated house.
prathmann is offline
Reply
Old 11-21-11 | 12:39 PM
Larger Chainring
Brand new tire. Brand new tube. Rim strip OK.
And it was a hook-beaded rim.
Reply
Old 11-21-11 | 12:42 PM
Larger Chainring
I was running the PSI very high after having an awful streak of pinch flats. I understand the doubters in this and other similar threads, but I have no other explanation of why it would happen other than a post-ride expansion.
Tires were inflated indoors.
Reply
Old 11-21-11 | 12:53 PM
ThermionicScott's Avatar
10 Anniversary
Good that we're discussing this, if nothing else.
I figure that I should put in a little extra air if I'm pumping up the tires indoors, but this thread has been enlightening as to how much.
- Scott
ThermionicScott is offline
Reply
Old 11-21-11 | 12:58 PM
Freewheel Medic
20 Anniversary
Hmmmmm. I would guess something else caused the explosive outgassing since the tires were inflated at approximately the same temperature as your office is maintained.
Bob
Reply
Old 11-21-11 | 01:02 PM
DiabloScott's Avatar
It's MY mountain
15 Anniversary
Bikes: Klein, Merckx, Trek
Can't think of any reason the rim strip would be a factor - maybe for a pinhole leak but not a blowout unless it was crooked and interfered with the bead-rim interface.
I've seen a dozen or so tire explosions while the bikes were parked - usually a sidewall failure but sometimes a bead blowoff. It's certainly more likely to happen with higher pressures and warmer temperatures but sometimes it happens for no discernable reason at all. Could be you got the new tube pinched in the new tire and it held on just long enough to make it a mystery.
DiabloScott is offline
Reply
Old 11-21-11 | 01:16 PM
10 Anniversary
Another thought, Oregon Southpaw: what kind of tires are you using? Seems like the wild temperature swings between indoors and outdoors in winter would favor big, low-pressure tires. Using the ideal gas law, I should only have to put an extra 6psi or so in my MTB tires to go from 70F indoors to -30F outdoors.
- Scott
Reply
Old 11-21-11 | 01:20 PM
15 Anniversary
Community Builder
Bikes: everywhere
Yeah, the only tire blown off the rim situations I've had were clearly from tube pinched under the bead. Sometimes they'll hold for quite some time before blowing off. I've been lucky, the couple of times I've done it the tire survived.
Oh and one time using a gas station compressor on a steel rimmed Motobecane. The tire blew off shortly after putting a little too much pressure in there.
Reply
Old 11-21-11 | 01:41 PM
squirtdad's Avatar
15 Anniversary
Bikes: Kirk Custom JK Special, 86 De Rosa Pro, '84 Team Miyata,(dura ace old school) 80?? SR Semi-Pro 600 Arabesque
OT.... My brother once worked at a service station while in high school. The had on LOL (little old Lady.... the original LOL) who would come in in the fall and have the tires deflated and filled with "winter" air and come back in the spring and repeat to get "summer" air. She was sharp...she watched them removed the valve cores and made sure the old air was out and the tire truly flat.
Life is too short not to ride the best bike you have, as much as you can.
squirtdad is offline
Reply
Old 11-21-11 | 02:16 PM
JohnDThompson's Avatar
Old fart
20 Anniversary
Community Builder
Then: defective tire and/or faulty installation.
JohnDThompson is offline
Reply
Old 11-21-11 | 02:29 PM
KonAaron Snake's Avatar
Fat Guy on a Little Bike
15 Anniversary
Bikes: Two wheeled ones
I think you're all missing the relevant information here:
"I mean we're talking bad "bikes may never be allowed in the building ever again" bad "
Oregon - as a generous person, I will gladly "hold" your bikes for you until such time as you can store them responsibly inside
Please don't read the fine print on the contract I'm sending granting bicycle power of attorney!
KonAaron Snake is offline
Reply
Old 11-21-11 | 02:33 PM
cudak888's Avatar
20 Anniversary
Community Builder
Did we determine yet whether these are wire bead or Kevlar bead?
-Kurt
cudak888 is offline
Reply
Old 11-21-11 | 02:59 PM
I went off to do something else and realized this as soon as I rethought it. The pressure only changes if the volume changes and the tires don't squish much at 100 psi, so the pressure change is truly negligible.
stausty is offline
Reply
