Bench vise + socket = cotter press
Quoted: 835 Post(s)
Liked 2,158 Times
I know this isn't a new idea, but I tried it last night and it worked like a charm! I've been debating buying one of the bikesmith cotter presses for some time, but I've been discouraged by the $59 price +$7 S&H. I've set various alerts for cotter presses, but people rarely seem to sell used cotter presses. In the meantime, I've used Sheldon's method of supporting the crank arm and whacking with a hammer--with less than adequate success, especially when installing a new cotter pin. I've also tried the VAR cotter press at my LBS, which is awesome but even more pricey than the bikesmith tool, if you can even find one.
So, there I was late last night, struggling to knock out a cotter pin with a hammer, and thinking about making plans to go to Harbor Freight this weekend to give Amesja's ingenious idea for modified cotter press a try. Then I said, why not just put this thing in my bench vise? So, I taped an empty socket to the crank arm as a receptacle for the cotter pin, took off the wheels, and put the frame/crank in my bench vise. (The tape was just to hold the socket in place while I lifted the bike.) I added some scrap wood between my workbench and the frame so it wasn't just held by the clamped cotter pin/socket. This also helps support the frame once the pin releases. Then I tightened the vise on the socket/cotter pin, and...voila!...out came the cotter pin. (Alternatively, I suppose you could also remove your vice from your bench, and bring it to your bike.)
I'll still keep an eye out for a VAR cotter press (I'm a sucker for tools as much as vintage bikes) but I'm in no hurry to buy a cotter press now that I know my vice and socket are up to the task.
Thought this tip might be useful to other cheapskates with cottered cranks.
-Randy
'72 Cilo Pacer '72 Peugeot PX10 '73 Speedwell Ti '74 Nishiki Competition '74 Peugeot UE-8 '86 Look Equipe 753 '86 Look KG86 '89 Parkpre Team Road '90 Parkpre Team MTB '90 Merlin Ti
Avatar photo courtesy of jeffveloart.com, contact: contact: jeffnil8 (at) gmail.com.
-Randy
Hopelessly addicted...
Bikes: 1949 Hercules Kestrel, 1950 Norman Rapide, 1970 Schwinn Collegiate, 1972 Peugeot UE-8, 1976 Raleigh Sports, 1977 Raleigh Sports, 1977 Jack Taylor Tandem, 1984 Davidson Tandem, 2010 Bilenky "BQ" 650B Constructeur Tandem, 2011 Linus Mixte
Liked 10 Times
I've used that technique in the past, and it does work. I only used it to remove the cotter, but bought a press by the time I was ready to install the cotters. Since the vast majority of my bikes have cottered cranks, it is really a necessity to have a cotter tool, because if a cotter is loose on a fully assembled bike, I don't want to have to try lifting it up to the vise. If I only had one or two bikes that were cottered, I'd probably not have opted for the tool.
missing in action
Quoted: 42 Post(s)
Liked 49 Times
That's the method I've been using too, and it's never failed me! The only hassle is clearing off enough space on the workbench to lay the frame up there horizontally
I've never had much luck with the jumbo c-clamp method, but the vise always works.
Quoted: 835 Post(s)
Liked 2,158 Times
Yes, this is a problem. In fact, I nearly knocked over my beer!
-Randy
-Randy
elcraft
I saw video on Youtube Where a 6" bench vise was wheeled up to the cottered crank on top of a Skate board. It was at the perfect height and allowed for removing or installing the cotters without either stripping the bike or needing to support the sideways mounted frame. I acquired a cheap indian-made bench vise for just such occassions. In the past, I have also used a "heavy-duty" 'C' clamp (the kind that require a wrench to tighten), with great results. Of course, in both cases, a socket is needed to complete the arrangement.
missing in action
Quoted: 42 Post(s)
Liked 49 Times
I've been working around a partially disassembled espresso machine for a few months now. I have to get around to brazing some new water lines before I forget how to put it back together...
The bench vise sounds like a good idea and was probably quicker than my approach.
I used a socket and c-clamp to remove one of the cotters on my old Raleigh but sprung the c-clamp on the second. So I just took a break from the bike work and made myself a cotter press. It's only been used a couple of times but has performed flawlessly on two different early 70's Raleighs so far and cost me nothing but a little time and scrap material.
Really Old Senior Member
I've used a 4" MACHINIST (fine threads) C clamp. (and a few hours pre soak with penetrating oil)
I'm 4 for 4 cotters so far.
Quoted: 835 Post(s)
Liked 2,158 Times
What's a thread without pictures? Here's the victim (with my first oxalic acid bath in the background).
-Randy
-Randy
Bikes: enough bikes to qualify for Hoarders......
If you need to borrow my cotter press to re install let me know.
Quoted: 835 Post(s)
Liked 2,158 Times
Many thanks for the offer. I'm encouraged by the preliminary results with the vice, but I've been working on low-end bikes. If I get my hands in a nice bike with cottered cranks, I may just take you up on that.
-Randy
-Randy
Liked 10 Times
I guess that must be a universal experience when using a vise to remove cotters! I like beer enough that between knocking over a beer and dropping a frame, I'm not sure which would win out in that circumstance!
16 dollar cotter press that someone here showed us how to make. Works everytime for me.
3SS
3SS
